Question about Whirlpool WFW9050XW Washer Front Load White
WFW9050XW won't drain
It fills with water, gets the soap up (I use just a little he), keeps turning and then about halfway up the whole drum, it stops and beeps three times. The diagnostic indicates 8 - 1.
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: The machine gets stuck mid cycle
If the inlet valve and the pump work correctly then it must be a problem with the timer control.
Here you find a replacement for the timer control assembly, just enter the model number.
Same here, free diagrams, and you can buy parts, enter the model number.
Here instead you find repairing tips : What is wrong with your Washing Machine?.
Regards
Posted on Oct 11, 2008
  • 26 Answers
SOURCE: the softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Posted on Dec 19, 2008
Jahn27
  • 1554 Answers
SOURCE: Whirlpool Cabrio he washer stopped
You may perform an automatic diagnostic test to check the machine functions and view any saved fault codes. Fault codes may also appear during the test when a problem is detected. Be sure the washer is in standby mode (plugged in with all indicators off, or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, and STOP) and follow the steps below, using the same button (remember the button):
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
The program then automatically checks for saved fault codes. Record the fault codes and post it back.
Press the same button used above in activating the test to advance through the automatic test steps. The basket must be floating in order to agitate. Allow step C1 to complete before advancing to the other steps. Record any fault code shown during the tests and post it back including which step the code is displayed.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 20, 2011
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
Disconnect your mains from the wall and clean out your filter.
Pl click if helped.
Apr 28, 2013 | Whirlpool Washing Machines
My washing machine is a whirpool stylemaster model no. LXR9245EQ2 and it will not do anything besides put the water into it and it will only halfway drain. It does not agitate at all.
If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically.
Here is the switch to order.
The part comes with a 365 day, any part, any reason return.
Nov 07, 2012 | Washing Machines
I have a frigidaire affinity front load washer, it won't spin. When it does it's very slow, and I keep getting error messages e20, e41. Pleas help.
As you said in the question the error message is nothing but it is telling to call the Service Engineer .E20 error indicate to call the Service Engineer.This error indicates that due to long heating .Thanks for your question.
Jun 17, 2011 | Frigidaire Washing Machines
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer fills and drains at the same time.
Check for congealed soap in the Air Bell which is at the other end of the pipe for the pressure switch
Apr 02, 2010 | Kenmore HE2 Plus Front Load Washer
Water begins to drain into the detergent drawer but does not drain into drum fast enough so the drawer area begins to fill and then begins to spill out of the drawer area all over the floor. If I press...
remove the drain pump and check out.
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
its the problem in the pump and something is getting blocked in the pump so water is not getting out.
    Front-Loading Whirlpool Washers
  1. Unplug the washer. Remove the three screws along the bottom of the toe panel and pull the panel forward to remove it.
  2. Put your bucket or towels under the drain pump. Open the pump slowly so the water doesn't all spill out at once. If you have a wet/dry vacuum, you can connect it to the drain hose to remove the water from the washer before opening the pump.
  3. Open the door covering the pump wiring and disconnect the wiring.
  4. Remove the two drain lines from the pump.
  5. Remove the screw that attaches the pump to the washer frame and pull out the pump.
  6. if the pump is leaky or cracked it needs replacement.
  7. for prats you can get it from
  8. www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 05, 2009 | Washing Machines
I have a Samsung SW62ASP top load washing machine. I keep getting chunks of black flaky stuff turning up through my wash. I always empty the in bowl filter, is there another filter?
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution
Aug 05, 2009 | Samsung SW62ASP Top Load Washer
Spin cycle not working
try the door switch the washer will do everything but spin if the door switch is faulty
Jul 13, 2008 | GE Profile WPSR3120WWW
Whirlpool WFW9050XW Washer Front Load White Logo
186 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
