Question about Dell Computers & Internet
Possible power supply problem
After hitting power button
- light turns amber and flashes
- monitor light is also amber
-have tried unplugging and restarting multiple times
  • 34 Answers
Open your computer case and disconnect/remove any hard drives, cd-rom/dvd drives, take out any extra cards installed (except video card unless you have onboard then take out the video card too) and all but one stick of ram. Turn the computer on
- if it turns on, plug in each item back one at a time turning back on and off each time ( power trip will cause the pc to not turn on)
- if you smell anything weird from the PSU unit DO NOT try anything further, replace the unit.
- if you have overclocked your computer, use the jumper on the board and reset your bios
In the event you need to replace your PSU unit if Antec is an option, go with that. They are very stable.
Posted on Jan 21, 2009
I have a dell optiplex sx280 computer and monitor that has lapsed into ''power save mode'' and I have been unable to ''awaken'' it (I'm not sure which is ''asleep'': the monitor or computer!) from sleep. I...
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Jan 08, 2010 | Dell OptiPlex SX280 PC Desktop
Amber light on in box and monitor no pics at all
if the Box (System Tower) is Flashing AMBER,seems to be Powersupply is gone.unplug all the cables,press the power button for more than 10 sec then put all the cables and try to turn on
Jan 02, 2010 | Computers & Internet
PC will NOT turn on;flashing amber lights
The power LED Flashing AMBER indicates the power supply in the tower has failed and needs replacement.
You can get a replacement here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817165004
Dec 20, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Samsung LCD TV LT-P2045U power issues
yes my friend check the capacitors in the power supply. some techs call them pregnant capacitors
open the set carefully and check the power supply.always remember to unplug the set before you do anything.
May 11, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
My pc turn on before I press the switch button. Then after it starts. It wasn't able to log-in in windows. Instead, the monitor turn off automatically then the orange or amber light is flashing. I'm glad...
If the front Light is flashing amber, the systems power supply has gone bad. Request you to replace the power supply and the front I/o panel and power switch . The issue would be resolved.
Thanks
mandeep
Jun 15, 2008 | Dell Dimension 4600 PC Desktop
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
No display on screen and solid amber light on pcs' power button
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Jun 06, 2008 | Intel Motherboard
Dell SX260...Wont Boot...Power Button Flashing Amber....grrrr!
Try these (un order of degree of difficulty) 1. Try replacing the battery on the system board. it is  typically a CR2032 button-style battery. This helps if the computer has been off for a long time.  2. Make sure all dust has been blown or vacuumed out of the computer. 3. Check to see if the USB pins are bent inside the connector on the back and the front of the computer. Straighten if possible. 4. Remove add-in cards, fans, shrouds, and heatsinks, then check the system board for leaky or mushroomed capacitors. If you would like, this may also be a good time to see if the processor is seated correctly or possibly short-circuited (burned black on the bottom, burnt or missing pins, etc). If it is any of these, you may need a new system board (motherboard) 5. It may be that you need a new power supply. Do your best to make sure that it will fit your computer case and have all the power connectors you need; they are not created equal.
May 05, 2008 | Computers & Internet
Vizio in stand by (amber lights) mode on monitor
Does the remote have one power button for on/off .... or, does it have separate buttons ?
Jan 13, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Computers & Internet Logo
209 people viewed this question
Alun Cox
