Question about Canon Rebel XT / EOS 350D Digital Camera
Built-in flash problem
On my Canon Rebel XT, on the automatic setting, the flash pops up & flashes for every picture. When it does this outside in full sun, my pictures are too light. Thank you for helping.
Move the mode dial to the no flash setting (full clockwise position)which is basically full auto with no flash (page 47 of manual)
Posted on Jul 18, 2007
SOURCE:
Reble xt flash will not pop up why?
It depends on what setting your main top dial is set on? The flash will not pop up if you have your main dial set on P, Tv, Av, M, A-DEP . If you are using one of these setting you have to manually turn on the flash by pressing the small button on the side of the lens with a Flash icon next to it.
The only time the flash will automatically pop out is if you are using AUTO, Portrait, Close Up...etc. these icons would be underneath the Auto setting which are called Scene Mode, hope this helps ?
Jul 07, 2014 | Canon Rebel XT / EOS 350D Digital Camera
I have a cannon rebel xt and when the flash pops it it will no longer take a photo but works fine outside if flash is not needed?? Help
Does the little flash lightening bolt light up in the viewfinder to let you know the flash is fully charged? If it does, but when you push release it goes out and then comes on again in a few seconds that is the sign of a bad flash board.
Does the flash go all the way up?
Is the switch that is under the flash come all the way up (not stuck down)?
Mar 12, 2013 | Canon Rebel XT / EOS 350D Digital Camera
When taking a picture is clicks a couple of times does not take a picture and says error 05
Check if something is blocking the in-built flash to pop up or if it is stuck. If the flash is stuck press the flash pop-up button and try pulling it up simultaneously.
May 02, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon Rebel. When I try to take pictures the flash "hood" or something automatically pops up but somehow the light doesn't flash and all I hear are 3 clicks. Then the screen says error...
Aprilm,
Error 5 is a flash error. What sounds like it happening is the mechanical part of the flash is working allowing for the pop-up, but the camera thinks there is an external flash present. A repair shop should be able to address the issue. Usually it's a problem with the micro switches "inside" the flash shoe.
Please let me know if you have any more questions.
Thank you.
Feb 20, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon Digital EOS Rebel XT and the built-in flash no longer pops up when needed. This started happening after using a Canon speedlite, but then removing it. I've tried resetting everything, and...
In addition to resetting all the camera settings you should also choose the "clear all custom functions" option that is also available from the same menu. Once that's done. Put the camera in Full Auto mode and see if the issue is resolved.
Sai.
Oct 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
We have a Canon rebel XT EOS the flash pops up no matter what the
Frustrating I am sure. I had the same problem on my first XTi. I cannot remember what the settings were, but I think I was set for portrait and had flash set as the white balance default source. Therefore the camera always popped up the flash assuming that I wanted or needed fill flash.
Change you white balance to sun/shade/tungston etc as is appropriate, choose a faster ISO speed in lower light levels and try using the P or Tv mode and use a shutter speed that generates a middle range aperature for your particular lens.
Jan 18, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt eos
Error 99 means lens communication error.
Try to clean the contacts on both sides.
and re-install lens
Jun 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Built-in flash
do you get an error message? if yes the screws which are on the sides that hold the stainless steel slider bars could be missing the nylon spacer shims. a common fault
Jun 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Built-in flash auto pop-up problem
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
May 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
163 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
