Question about Dell Latitude C810 Notebook
Max, what is a HDD?
You said test HDD and put back. Don't know what HDD stands for??
  • Dell Master
  • 32,281 Answers
HDD is the hard disk that is inside the laptop.
Posted on Jan 10, 2013
Samba 1845 won't boot how can I make it do so?
From what I can tell it would be HDD related. Have you test the HDD, is good? Do you have a Recovery disk of your OS? The machine has some miles on it ,right? I would start trying to load the disks (CD) that came with the machine, (I don't know your OS), If you don't have them, you can search for a windows repair disk online.
Nov 18, 2012 | Computers & Internet
My amp will turn on and even when I have the guitar and amp connected no sound comes from the amp. I don't know what to try to fix it, so I have left it alone, testing it every once in a while (it...
Possibly a loose connection, or bad solder connection. unplug it from power.
If you think you are up to it geta soldering iron and some solder, and a screwdriver, and take the amp part out. be careful of the speaker wires. put some tape on each one and label them so you know where to put them back. after you got it out you might have to take some more screws out to get the board off of the chasis, so you can see under it. this is where all the components are soldered to the board. maybe use a magnifying glass. touch up anything that looks questionable.
do all over. you don't need to know what everything does if you just go all over. careful not to cause any shorts. you might see something that obviously needs to be fixed. you have found a problem. you can't fix something if you don't find a problem. do all over anyway if you think you still have to.
Put it back well enough to test it. then put it all the way back together, or continue to look for a problem, or take it to someone, like me!
Good luck
PLEASE RATE THIS ANSWER
Aug 23, 2011 | Marshall MG15DFX 15 Watt Compact 2...
I have a pyramid amp and i don't know what watt it is and it doesn't say. the model no. is PB-700A. it's an older amp thank you
  • 4-Channel
  • 350W X 2 Max @ 4ohm
  • 700W X 1 Bridged @ 4ohm
  • Dim: 2.4"H X 10.7"W X 6.9"L
  • Mosfet Pwm Power Supply
Jun 07, 2011 | Pyramid Car Audio & Video
After about 100 miles or so my header tank slowly fills with water,i can **** it out of the header tank back to the max then put it back in the rad, so the rad is full and the header tank is at max,with...
G'day.
I guess your wondering what is going on- no loss of coolant but it's moving from the radiator to the catch tank.You put it back in the radiator & back it goes to the catch tank again- seems like somthings wrong but the answer is simple really.
As your bike warms up,the cooant in the radiator expands with the heat & moves excess to the catch tank.
Then the water contracts when the bike cools down & some of the coolant is now in the catch tank & the radiator a bit low.
So what to do.
Run it & this time don't put the excess back in the radiator.
Set the catch tank to max & then just moniter whats going on from there.
It's normal for the radiator to be down just that bit when cold to allow for the water expansion when it gets hot.
If the radiator gets too low ,coolant will be drawn out of the catch tank to fill it up.
This is called a coolant recovery system & is commonly fitted to liquid cooled bikes.
The part to check is the radiator cap.
You will see two rubber parts on the under side of the cap.
One black rubber on a spring & the other seal just under the lip of the cap.Check that these are not damaged.
If either is split replace the radiator cap.
I hope this has been of some help.
Kind regards Andrew Porrelli
May 11, 2011 | kawasaki ZX-6R Ninja Motorcycles
What should I get to power 2 jensen jo25w speakers
Their Max power handling is 175W but they don't need anything near that to operate. Nearly any stand alone receiver or amp should work.
Apr 19, 2011 | Audio Players & Recorders
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Dell Latitude C810 Notebook Logo
Alun Cox
