Question about Brady TLS 2200 Label Printer
How do get the tape to feed? - Brady TLS 2200 Label Printer
Calc tape feeds crooked :(
The tape feed path may have to be cleaned.
Mar 19, 2014 | Sharp EL-2630P Calculator
I am trying to load a new roll of labeling tape into the Dymo Organizer 1610. But the tape doesn't advance properly into the front part of the machine that does the printing.
Before inserting the tape into the feed mechanism, bend the last 1/8 inch of the tape upward at a slight angle. This will insure that the tape feeds properly. I just learned this by trial and error.
Aug 03, 2011 | Office Equipment & Supplies
I have a Brother label maker, model number pt65. How do I install the tape. I cant get it to feed through. Thank You
1) Remove the back cover by pressing in on the rough
area at the top end of the machine and pulling off the
back cover.
2) If a tape cassette is already installed, pull it straight out
and remove the paper tab from the new tape cassette.
Make sure that the end of the tape in the new cassette
feeds under the tape guides.
3) Insert the tape cassette, making sure that it clicks into place.
Check that the cassette fits properly around the two
metal guides in the cassette compartment.
4) Attach the back cover by inserting the two hooks on the
bottom end of the back cover into the slots on the bottom
end of the machine, then pushing down firmly on
the cover until it snaps into place.
5) Feed the tape by holding down and pressing ,
then cut the tape by pressing in on the tape cutter button.
The amount of tape remaining is visible through the
window in the back of the P-Touch.
When the usable tape is finished, green ribbon appears
Hope this helps
Bruce
Jun 14, 2011 | Office Equipment & Supplies
How do I thread the tape on an Akai GX210D reel to reel tape deck?
When facing the deck, the feed reel goes on the left and the take-up reel goes on the right. Make sure to secure each reel by engaging the reel locks on each of the spindles. Place the feed reel with the free end of the tape on the left and hanging downwards (like the letter "P"). Pass the tape to the right of the tension spindle (which is above and to the left of the play/record heads unit. Pull the tape down and pass it underneath the heads from left to right. Then on the right hand side of the heads unit pass the tape between the guide wheel and the first guide spindle to its left and just above. Then pass the tape over the top of the second guide spindle. Finally, loop the tape under the right hand tension spindle and pull it up and feed onto the take-up reel from the right in an anticlockwise direction (like the letter "g"). Once you have it through the slot in the centre of the reel, hold the tape end there with your finger and wind the reel around a few times to hold the tape in place and ... Voila!
Feb 19, 2009 | Audio Players & Recorders
Recording
you can use an a/v to rca adapter cord to transfer from dv tape to vcr or dvd recorder. If you dont have the cord , you can get 1 cheap on e-bay, at walmart or radioshack.
Dec 18, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Reloading tape roll on a Casio DR-T120
Place the tape between the two posts; then put back portion of cover down followed by the removal front portion - press feed button and it should feed. Remember it will only print on thermal paper ----
Dec 08, 2008 | Casio DR-T120 Calculator
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
Brady TLS 2200 Label Printer Logo
20 people viewed this question
Top Brady Office Equipment & Supplies Experts
pkwc
Bob Rambo
Level 1 Expert
The Vanguardian
The Vanguardian
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
