My printer started making this noise today after a started printing a document. I have opened all the access doors, checked for paper jambs, and it wouldn't stop until I unplugged the printer. The
    Genius:
  • 1,669 Answers
Your video is not working. I can only assume your problem is in the print carriage. Does it move back and forth when you first turn the printer on? If not, the carriage may be jammed or its belt drive jammed.
Posted on Jan 10, 2013
pattersj78
  • 70 Answers
SOURCE: Dell printer problem
Sounds like you may need to replace the pick up rollers on the machine.  Without knowing exactly where the jam error happens during the print process, it's hard to say.
Posted on Oct 19, 2007
jaylex
  • 417 Answers
SOURCE: HP LaserJet 1100 not printing
Firstly PRESS THE BIG BUTTON
Secondly if this doesn't work remove toner cartridge and look inside there maybe a piece of paper in there.
Thirdly Remove paper look down the paper feed entrance check there is no paper there.
Finally Replace toner cartridge.
Hope this is of help and please rate me
Cheers J
Posted on Dec 31, 2007
CompuFirm
  • 89 Answers
SOURCE: Samsung CLP-315 prints half a page and then stops
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
Posted on May 26, 2009
SOURCE: Olympus Camedia P-10
According to the Manual, when both the Access and Paper light go on simultaneously, there is a paper jam. Check to see if there is, also check to make sure the paper is loading from your tray correctly. You have the paper face down right?
Turn off the printer after you fix he jam or paper, and turn back on before you try to print again.
Hope this helps
Posted on Aug 18, 2009
  • 1752 Answers
SOURCE: HP laserjet 1200 series printer makes a groaning
Sorry, it's old, cranky, and worn out. Live with it, or buy a new one, it's not cost effective to fix it.
Posted on Oct 15, 2009
Hp 2410 loads paper but stops and says out of paper then paper jamb
Jamb:either of two stones, timbers, etc., forming the sidepieces for the frame of an opening.
Do you mean paper jam?
May 06, 2012 | HP PSC 2410 All-In-One InkJet Printer
I was printing a document while the paper jam occurs then I shut the printer to stop the noise it produces. When I try to print again, the printer's cartridge got stuck on the right side and produces...
Hello there.
Remove the cartridges first and check if some paper is still there.
Also check the back of your printer, you will see that there's something like a door which you can open. Open that and check for remaining paper and remove it.
After you removed all paper and reinserted the cartridges, restart the printer and computer.
Some help for paper jams: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864438&tmp_task=solveCategory&cc=gb&dlc=en&lc=en&product=2510767
Instructions on how to open the back door: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01943615&tmp_task=solveCategory&cc=gb&dlc=en&lc=en&product=2510767
Aug 21, 2011 | HP Deskjet 2460 InkJet Printer
Light flashes next to "check printer cartridge"
For an illustrated version of the text below go to: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00095617&cc=us&lc=en&dlc=en&product=306895&tmp_track_link=ot_search
Check Paper Light Blinking
Figure 1: Check Paper light blinking At the start or in the middle of a print job, the Check Paper light begins to blink. The unit will not print. If the unit is connected to a computer and the HP software has been installed, one of the following messages is displayed:
  • There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume, or Okay button on the hp psc.
  • The unit is out of paper. Load more paper and press the Enter, Resume, or OK button on the hp psc.
If both the Check Paper and the Check Print Cartridge lights are blinking simultaneously, or if the computer message is The print cartridge carriage is stalled , click here for troubleshooting information . Step 1: If the unit is out of paper, load more paper
  1. Move the paper guide out, load the paper, then adjust the paper guide. Make sure the paper is flat in the tray. Figure 2: Load paper
  2. Press the On/Resume button. Figure 3: On/Resume button
If the unit is loaded with paper and the light is still blinking, go on to the next step. Step 2: Remove jammed paper from the rear of the unit
  1. Unplug the product.
  2. Press the tab on the left side of the rear access door and remove it. Figure 4: Unlatching the rear access door by pressing the tab on the left
  3. Remove all the jammed paper and foreign material. Pull the paper slowly and gently to avoid tearing it or damaging the print mechanism. Avoid touching the internal components.
  4. Replace the rear access door. Put the pins on the right end of the door into the holes on the right side of the rear access area. Then snap the door shut. Figure 5: Door pins in product holes
Step 3: Check the front of the unit for jammed paper
  1. Open the cartridge access door in the front of the unit. Figure 6: Open the cartridge access door
  2. Pull out any jammed paper or other foreign material you were not able to remove from the rear. Pull the paper slowly and carefully to avoid tearing it or damaging the print mechanism.
  3. Close the cartridge access door and plug the product back in.
How to avoid paper jams
  • Only insert paper into the paper tray until it meets resistance - do not push it farther in.
  • Make sure the paper is flat in the paper tray and the guide is adjusted to the width of the paper.
  • Do not add paper while the unit is printing.
  • Remove printed pages frequently.
  • Do not use paper that is too thin, too slick, or that stretches.
  • Do not use torn or creased paper. Paper that has been printed previously may cause jams.
  • Make sure the rear access door is securely fastened.
  • If you follow all these guidelines and still have frequent paper jams, you may need to clean the paper rollers.
Cleaning paper rollers
  1. Turn off the unit, then unplug the power cord.
  2. Remove the rear access door. See the picture above.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 7: Paper rollers
  4. Allow the rollers to dry completely, then replace the rear access door. Put the pins on the right end of the door into the holes on the right side of the rear access area, then snap the door shut.
  5. Plug the unit back in and turn it on.
Please vote if this is helpful. :)
Dec 11, 2010 | HP PSC 1350v All-In-One InkJet Printer
Copier makes a noise when first turned on and then it tells me to open the door clear carriage jam and press enter. But that does not work. The printer has been sitting for a little...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 29, 2010 | HP PSC 1600 InkJet Printer
When you print it starts to pick up the paper and halfway in it makes a strange noise and the paper just jambs
May be problem on mechanical.or fuser section.
if you itself,please open your copier or printer and troubleshooting which broken or out of work replace damage part or not fix please go to workshop.
Mar 04, 2010 | Samsung SCX-4216F All-In-One Laser Printer
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
The carrage goe "bang" then the displayy claims that a paper jamb caused the problem. However, there is no paper anywhere near the carrage. Any ideas? Thanks John
Hi there again here is the web site for you to troubleshoot your problem ok best regards michael
  1. Troubleshooting Printer Noise When printing, The HP Deskjet 600 series printer makes strange noises such as: ... periodically slams or bangs against the left side of the printer while it is ...h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpd07280&... - 75k
Sep 14, 2009 | Computers & Internet
How can i remove the paper inside the printer
For the paper jam issue turn around the printer and open the back door to pull the paper.
and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Paperjam
1. Clear the paper jam
a. turn the printer off and unplug the power cord from wall outlet
b. check if there are paper jammed in the input and output tray
c. check if there are paper jammed in the rear door
c1. open the rear access door by pressing the handle to the right and then pull out the door
d. check if there are any paper jammed in the document feeder (if you have any document feeder)
2. Clean the rollers of the printer using a lint free cloth that is moist with water
3. Close the rear access door and then turn the printer on
4. Try to print again
Aug 08, 2008 | HP Office Equipment & Supplies
24 people viewed this question
jasbo
jasbo
