AutoPlay - Windows XP
Prompt isn't working.. yes I have gone on properties, autoplay tab and selected take no action/restore default.. yet it still doesn't prompt.. also my autorun inf file isn't working.. I have tried everything.. I have formatted my usb and tried again but it still isn't working. it will however if i select an action to perform open to view files but that is it.. i have tried microsoft autoplay fix as well.. it hasn't worked :'( please help?
  • Fred Flinstone Jan 10, 2013
    Thanks for all your help guys! Even though I had done everything to fix the new update to xp, with autorun, the autorun was still not working. I found the update file and uninstalled the autorun update by microsoft and now the autorun file is coming up with a promt to run TrueCrypt but! i cannot select the little box saying 'always perform this action'. It used to do it automatically. Thanks again guys! any solutions on how to get it run automatically again?
  • 27,725 Answers
Autorun is a feature of Windows XP that brings up a screen with actions that the user can perform any time a storage device or piece of media is inserted into a computer. This feature can be disabled by changing a value in the system registry. If the Autorun feature is not working on your Windows XP system, fix the computer so that the Autorun options will be displayed when a USB device is connected.
Select the "Start" button and choose "Run." Type "regedit" (no quotation marks) and click "OK." Click on the key "HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\NoDriveTypeAutorun" in the left side of the window. Right-click on the value "NoDriveTypeAutoRun" in the right side of the window. Select "Modify" from the menu. Enter "91" into the "Value data" box. Select "Hexadecimal" as the type. Click "OK" to enable Autorun on all types of drives, including USB devices. Close the registry editor and reboot the computer. Hope this helps.
Posted on Jan 10, 2013
  • 310 Answers
SOURCE: ",.exe" (comma.exe) causing a problem
Its your OS affected by virus..
Posted on Mar 04, 2008
worldvet
  • 859 Answers
SOURCE: Funny UST scandal virus
Right click My Computer, select Properties, choose System Restore and turn off SR on all drives.
Then, do all the manual removals you posted before. Then, go to this url:
http://www.kaspersky.com/virusscanner
and run the full virus scan on all drives.
Because the files you note as infected are actually required by XP to run, you may not actually be able to go online, still try not to remove those files if possible, once they are removed you will have to restart your machine with the XP Disc and tell it to install, load any specific drivers needed such as those for your raid array if you have one, only when Setup tells you Windows is already installed, select Repair instead of New and Windows will heal your system.
So, because of those critical files being corrupted, don't be too surprised that when your online scan asks you to clean your system that your system freezes or halts at some point. Just be prepared with your Windows disc and Product Key.
I'll be available for any follow up questions you may have just comment back to me by clicking on my user name and then Ask Me.
Regards,
Worldvet
Posted on May 21, 2008
MJS_1
  • 150 Answers
SOURCE: file sharing between windows 2000 and XP
1) I believe that Windows XP is not setup for that by default,
you may need to install the old BETBUI service.
2) Also, if the 2000 machine has a login password installed,
it will NOT allow any other machine to browse it, without
logging in.
3) Password-less file sharing over NETBUI was available
on the consumer side of windows:
Windows 3.11 for Work groups
Windows 95, 98 and Millenium.
The professional versions of windows, built on NT
technology require a login:
Windows NT 4.0, Windows 2000, Windows XP,
and now Vista.
4) The best work around is to login to the 2000 machine when
it prompts you for a password, using your regular USER ID
and PASSWORD.
If the 2000 machine is not setup with a secure login,
just create a new account, ranking power user or higher.
5) Note that you only need to login over the network ONCE,
because windows XP can REMEMBER your password,
and login automatically the next time.
6) Make sure that the firewall (or A firewall) is not
blocking access to either machine, just disable the
firewalls for testing.
Similarly, if your LAN is behind a residential router, using
the router as a smart hub or switch, make sure that
the routers MAC address access blocking is disabled,
until you get everything setup and tested.
7) Finally if a PC is not visible in a work group, this does not
mean that it is not accessible. This is a Windows quirk.
You can try to access another computer by using the
default/administrative shares. These shares cannot be
disabled in XP, at least they will not stay disabled, as
they will restart during every reboot, whether you like it
or not.
This means that you can ALWAYS access all the drives
on another machine, whether you share them or not, unless
you take extreme measures in the local policies.
To access drive "E:" on a computer called "Henry" on a
machine in the same work-group,
open up windows explorer, and tyr the following into the
address line:
\\Henry\E$
This should access drive E:, after some delay, and possibly
a login prompt, even though drive is is NOT marked as
shared.
Down you just love windows ?!
Security by obscurity ?!
Microsoft is getting very good at hanging massive steel doors
on paper walls.
Hope this solves your problem, or gets around it.
Please rate my answers,
Martin
Posted on Jul 05, 2008
i would sugess a very small av utility "Smart antiviru" which remove funny ust scandal, smms, autorun.inf and also new folder.exe.. this also contain an option for USB flash drive to be cleaned.
just serach the download URL on google and download it.
Posted on Oct 19, 2008
richard191
  • 691 Answers
SOURCE: trojan herss or soolo
Hello
Thank you for using
FixYa for your problem
Ok, can you download "combofix " on another computer, put on a CD
Can you now start in Safe Mode with internect connection
run the combofix, and give it 15 mins maybe
You might need to download direct to the faulty computer if you can
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 19, 2009
Disable autorun on hard drives
How To Enable/Disable Auto run (Windows 95/98/Me)
Access the System Properties Dialog. Using Control Panel: My Computer: Properties or Explorer: My Computer: Properties.
Select the Device Manager tab.
Select the CD-ROM folder.
Select the entry for your CD-ROM drive.
Select Properties.
Select the Settings tab.
Turn on or off the Auto insert notification option.
Select OK.
Select OK
How To Enable/Disable Auto run (Windows NT/2000)
Start RegEdit (regedt32.exe).
Go to HKEY_LOCAL_MACHINE/System/CurrentControlSet/Services/Cdrom.
Edit the Autorun value to '1' to enable auto run, and '0' to disable auto run.
Close RegEdit
How To Enable/Disable Auto run (Windows XP)
Open Windows Explorer by pressing the Windows + "e" key.
Right-click the desired CD-ROM and select Properties from the menu.
Select the AutoPlay tab.
Select each item from the pull down list and for the Action to perform, select "Take no action" to disable auto run, or pick the appropriate action to take if enabling auto run.
Select OK.
How To Enable Autorun for Other Removable Media
Autorun can be enabled or disabled for all Removable media types, such as a floppy or Zip disk. Windows systems are configured to enable CD Notification, other removable media are by default disabled.
The System Properties User interface only exposes the CD Enable or Disable selection. The setting reflected in this dialog makes an entry in the System Registry. It is in this same location that other media types are configured.
Notes:
Modifiying the Registry is not for the inexperienced user. Anyone will tell you, be VERY careful.
The modifications made in this case use Hex not Decimal numbers. If you are unfamiliar with the Registry or the characteristics of base numbering and Hex, studying these topics prior to making these modifications is advisable.
To Modify these Registry Settings, Use Regedit and navigate to the following Key:
HKEY_CURRENT_USER
Software
Microsoft
Windows
CurrentVersion
Policies
Explorer
The default value for the setting is 95 0 0 0. Change the first byte to 91. Restart the computer to make the new setting take effect. You may have to right-click on the floppy and choose AutoPlay from the menu to see the AutoPlay behaviour.
Additional Technical Info
The first byte defines which drive types to EXCLUDE from Autorun behaviour. The hex value of the byte is the sum of all of the drive type values to exclude + 128.
DRIVE_UNKNOWN 1
DRIVE_NO_ROOT_DIR 2
DRIVE_REMOVABLE 4 (floppy disks and removable cartridges)
DRIVE_FIXED 8 (hard disks)
DRIVE_REMOTE 16 (network drives)
DRIVE_CDROM 32 (CD-ROMs)
DRIVE_RAMDISK 64
The default configuration excludes UNKNOWN (1), REMOVABLE (4) and REMOTE (16) which would be 16 + 4 + 1 + 128 = 149, which is hex 95. If you take out REMOVABLE you get 16 + 1 + 128 = 145, which is hex 91.
The calculation for this value is 1 + 4 + 16 + 128 = 149. 149 Decimal is 95 Hex
The new calculation is 1 + 16 + 128 = 145. 149 Decimal is 91 Hex
You may have to restart for the system to recognize a floppy or Zip as an Auto play drive. If your floppy drive does not show a custom icon or AutoPlay in the menu when right-clicked, double-click on the icon for your computer on the desktop and press F5 to refresh the information in the Explorer window. Zips and floppies will not auto launch when media is inserted. You must double-click their icon or right-click and choose AutoPlay from the menu.
hope this helps
Jul 21, 2012 | Microsoft Computers & Internet
When disc is inserted it will not play
Enabling AutoPlay in Windows XP Enable through Windows Explorer
  1. Open My Computer
  2. Right-click the CD-ROM drive or other drive and click Properties.
  3. Click the AutoPlay tab. Within this section you will be able to specify all Windows AutoPlay features.
May 04, 2011 | Computers & Internet
When i insert my discs eg software or cd's the lap top doesn't automatically load as it used to
There should be an AutoPlay in the control panel if your running windows vista or windows 7
Nov 18, 2009 | eMachines M6811 Notebook
How to turn off autoplay?
Any OS
  • If you hold down the Shift key when inserting the CD, the autorun is bypassed. (although it's not exactly graceful trying to insert a CD while holding down keys on the keyboard.)
Windows XP - Solution 1
  • Right-click on the drive icon for your CD drive, CD recorder, or DVD drive, and select Properties.
  • Choose the AutoPlay tab, and choose the desired action for each type of CD. For example, choose Music CD, then click Select an action to perform, then select Take no action.
Windows XP - Solution 2
  • Obtain and install TweakUI (part of the PowerToys for Windows XP package), and then start TweakUI.
  • Expand the My Computer branch, then the AutoPlay branch, and then select Drives.
  • Turn off the checkbox next to each drive letter for which you want AutoPlay disabled.
Windows 2000/XP
  • Run the Registry Editor (REGEDIT.EXE).
  • Navigate to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetServicesCdrom.
  • Double-click the Autorun value, and type 0 for its value. (If it's not there, create it by selecting Edit -> New -> DWORD Value, and typing "Autorun" for its name.)
  • You may have to log out and then log back in for this change to take effect.
  • Note: With this solution, Windows will no longer be notified when you insert a new CD. To make sure the correct icon and title for the current CD are displayed in My Computer and Explorer, press F5 to refresh the window.
May 14, 2009 | Microsoft Windows Media Player
Usb port does not detect autorun
Okay in XP
  1. Open Windows Explorer by pressing the Windows + "e" key.
  2. Right-click the desired CD-ROM and select Properties from the menu.
  3. Select the AutoPlay tab.
  4. Select each item from the pulldown list and for the Action to perform, select "Take no action" to disable autorun, or pick the apporpriate action to take if enabling autorun.
  5. Select OK.
Ryan Frame
Creative Energy Associates Technical Center
Apr 29, 2009 | Microsoft Windows XP Professional
How do i get option to download,playl rip from cd's diff prog
go to my computer, find the DC/DVD drive and right click on it the select properties, a windows will appear, click on AUTOPLAY, on the AUTOPLAY tab select MIXED CONTENT from the drop down menu. after selecting the mixed content option please click on RESTORE DEFAULTS and the click ok.
Try inserting a CD to see if it worked.
Feb 09, 2009 | Dell (0K724) for Inspiron 8100 40 GB Hard...
Problem regarding my laptop
Do you mean after you put in a CD/DVD they are not starting up/loading?
For Windows XP:
You can open up My Computer, Right Click the CD/DVD Drive and choose Properties. Click the Autoplay Tab at the top of the box that opens up and see what option is selected.
You will see a drop down menu box that you can choose the different types of Autoplay features: Music Files, Pictures, Video Files, etc.
Under Actions, is Select an Option to perform selected and is Take No Action the option selected? Below that box is the option to "Prompt me each time to choose an Action" selected?
You can go to each category and set your preferences to tell your computer what action to take for each type of media you put in the CD/DVD Drive
Jan 27, 2009 | HP Compaq dc5700 Microtower - Free Flat...
I have a Nikon Coolpix P2 camera that I love. I used to have Picasa 2 software loaded and it automatically detected when I attached the camera to a USB port. I've accidently upgraded to Picasa 3, and that...
It's probably because Picasa 3 is not your default import program for photos. You can fix this by:
In Windows XP, your default import setting must be adjusted on a device by device basis:
* Connect the import device (your camera or card reader) to your computer.
* Double-click My Computer on your computer desktop.
* Right-click the listing of your import device.
* Select Properties.
* Click the Autoplay tab.
* Select 'Pictures' from the content drop-down menu.
* Choose from two possible actions:
* Select an action to perform: Select an application to handle import by default each time photos are detected on the specific piece of hardware.
* Prompt me each time to choose an action: Choose an import application each time you attach your hardware.
* Click Apply.
* Click OK.
Windows Vista
Windows Vista allows you to set a global import preference for all photo or videos files.
* Click Start > Control Panel.
* Select Autoplay.
* Under 'Picture' or 'Video,' select your default import program.
* Click Save.
Dec 28, 2008 | Nikon Coolpix P2 Digital Camera
My computer does not have a AutoPlay feature in it so I can insert and run my Cd-ROM PC games. It must have come with one but I can't find it.
Enabling AutoPlay on a data and audio CD (Windows XP)
  1. Open My Computer or Explorer
  2. Highlight the CD-ROM drive, right-click the CD-ROM drive and click properties.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 26, 2008 | HP Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
