Question about Dynex DX-32L151A11 32-inch Flat Panel LCD HDTV - 720p - 300 cd/m2 - 16
Black Screen - Can not get menu to show to adjust brightness.
How do we adjust the brightness on our tv, when all we see for a picture is a black screen? The sound works fine, but there is no picture when we turn the tv on. Can not get the menu to show on screen, either. Is this a "brightness/adjustment problem.....or possibly something else wrong with tv?
  • Dynex Master
  • 8,617 Answers
You need to replace the inverter board thats what preventing the backlights from lighting up so you can see the picture. You can get the inverter board from www.tvrepairworld.com
Posted on Jan 10, 2013
  • 8 Answers
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Posted on Aug 21, 2008
  • 27 Answers
SOURCE: dynex tv has green where is should be black in the picture
first check all componet wires in back make sure they are connected properly...if thats not it try reseting your color scheme thru your remote usually under the menu under picture or color and if thats not it it could be your bulb is going bad but try the first 2 things first
Posted on May 14, 2009
budmrtn
  • 11361 Answers
SOURCE: dynex tv no picture screen comes on and then goes black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Dec 18, 2009
pjbaldi
  • 8 Answers
SOURCE: dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Posted on Jun 02, 2010
  • 8457 Answers
SOURCE: my dynex flat screen tv's tint control is at 0 in
The best way is to just unplug,replug the tv back like an hour later.The tv setting and colors,will automaticly,return it to the Factory tv setting.
Posted on Nov 15, 2010
In dark scenes the picture is almost black, cannot see.
Open the settings menu with the TV remote.
Go to Screen/Picture menu.
Adjust brightness up until you are happy
Press save if necessary.
Mar 06, 2015 | Televison & Video
No picture
Sounds like you have a backlight problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flashlight on the screen. If you see a faint picture you have a backlight fault. It could be as simple as a bad capacitor in the power supply, or a faulty inverter board, or in rare cases a bad backlamp.
May 04, 2013 | LG 32LD350 32 in. LCD TV
My cable and tv is but my screen is black and I can hear the sound of the shows and commercials... I just can't see it!
go to the menu and look for the brightness adjustment. most tv's have this control as the brighter the picture the more electricity is used (i.e.your electric bill). also check out contrast and other picture controls. hope this helps. good luck
Jan 22, 2013 | Televison & Video
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
I have a Sony, 54" Projection Screen HDTV that I bought in 2002. I believe it is a 1080i. When I am waatching TV, I notice that when the screen is mostly black, for instance a night scene, the black areas...
Confirm the actual model number as the one indicated in the title is not HD.
Some of these sets had bad picture tubes that on a black screen or blank video input may in your case show faint curved lines and or some color (red,green or blue) present in the background.
If this is the case there is a fairly simple way to attempt to adjust something for this--not in the customer menu but fairly easy to get at and try.
Most of these sets were KP51ws500, 57500 etc.
SD TECH
May 11, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Screen dim, black has green in it, contrast and brightness = shin
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
Apr 03, 2010 | Samsung Televison & Video
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Dynex DX-32L151A11 32-inch Flat Panel LCD HDTV - 720p - 300 cd/m2 - 16 Logo
146 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
