Question about Garden
Stihl 034 motor rubber mounting bushings - Garden
SOURCE: removing handlebar on stihl ms 270 chainsaw
you have to take the top cover off of the engine and then remove the tab that holds the bushing in place alongside the engine. if you just start prying on the plastic plug from the outside of the handle you will damage the retainer. that holds it in place. If you have already done this, there is a solution.
Posted on Apr 20, 2009
  • 6 Answers
SOURCE: unable to crank Stihl 034 chainsaw because pull cord jams.
i had the same thing with a stihl hedgecutter its a part in the centrefruge that locks if you pull to hard pull slow and let all the cord come out let it in half way full choke on start just where it used to lock and it will start . the bad news .it wont last for long before you smash the wheel thats plastic and if its over about 5 years old they dont have a replacement part hope this helped
Posted on May 27, 2009
dontbother10
  • 2220 Answers
SOURCE: owners manual for a Stihl 034 AV Chain saw
Stihl Manuals
http://www.stihlusa.com/information/info_product2.html
For an IPL you must contact them.
HTH
Lou
Posted on Oct 19, 2009
dontbother10
  • 2220 Answers
SOURCE: pull start on a stihl 034 the black plastic piece
Stihl OE parts are propriatary, Try your local Stihl dealer for a new part replacement or watch eBay.
Lou
Posted on Jan 17, 2010
dontbother10
  • 2220 Answers
SOURCE: Does the centrifical clutch on a Stihl 034 AV
I cannot find a manual for an 034 so I must make my best guess (yes, left handed thread). Most Stihl saws have inboard clutches. I am going to reply as though that is true. The drive sprocket does not require (if inboard clutch) clutch removal. It must be removed to access the actual clutch. I reply as though you want to actually remove the clutch itself.
Do this first:
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
Continue using this as a guide:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If I missed any part of your question you can reply below and I will clarify. Good Luck with your project. HTH
Lou
Posted on Feb 09, 2010
Testimonial: "To Lou, Thanks very much for the advice re clutch on Stihl 034AV. came off easily and I was especially pleased with your tip re using some rope"
Replacement diagrams for Stihl chainsaw motor
There are several rubber mounts for Stihl saws. Go online with your model number and search parts list. If you come back with the model I can help further.
Sep 22, 2014 | Garden
Stihl fs 36 44 Motor wont rev
A very common problem I see with trimmers is the spark arrestor screen plugs up blocking the exhaust from exiting the engine causing the engine to not wind out like it should. If that doesn't solve the problem then check the diaphragm in the carburetor. Those units are obsolete and very difficult to find parts for so I wouldn't spend a lot of time or money on it to fix it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 13, 2013 | Stihl 36, 40, 44 Edger Trimmer 35mm Piston...
Have a 05 sebring sedan. front end squeaks in the suspension when it gets warm. have replaced everything in the the last year. what else could it be.
Usually squeaks are rubber bushings that need liquid soap lubrication. The anti-roll bar bushings and end links are common sources. So is the lower arm bushings that work with the strut assembly. Suggest getting under the car while someone pushes down on the front end to get it squeaking. Good luck!
Aug 15, 2010 | 2000 Chrysler Sebring
Pull start on a stihl 034 the black plastic piece that turnsthe sprocket to crank the saw is broke
Lou
Jan 17, 2010 | Garden
Is there a way to replace the rubber bushing on dryer motor
Motor is replaced as a unit and not individual parts. if that bushing wore out the motor needs replaced.
http://shop.ebay.com/?_from=R40&_trksid=p3984.m38.l1313&_nkw=303358&_sacat=See-All-Categories
Eric
Nov 22, 2009 | Washing Machines
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
