Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I am facing Problem installing Windows XP with Asus P5RD1-VM series mothboard with SATA Hard drive. My harddrive doesn't get detected while installing Windows XP. While going for coping files for installation it didn't find hard drives on machine. Is there any BIOS setting for finding SATA hard drive?
    Scholar:
  • 54 Answers
I would go into the BIOS and make sure your SATA controller is using the AHCI or IDE setting and not RAID, if it is using RAID then it may need to load a special driver to install windows.
This is the most likely cause of your problem, can you also check and make sure the bios is seeing the HDD at all?
Posted on Jan 21, 2009
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
Can not installing windows xp & cant detecting the sata hard drive how can i installed the sata drivers
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive, this will make XP think it is a IDE/PATA hard disk.Then install XP normally. After Windows XP is installed then install all the device drivers (including the SATAdriver), then shut down and boot up and got into the BIOS and enable the SATAdrive.
Dec 15, 2010 | ASUS P5RD1-VM Motherboard
P5rd1-vm rev 1.0 motherboard 500gb sata harddisk installtion not winxp installtion problem
The Windows XP installation CD does not include a SATA driver.
For instructions on installing XP on a SATA hard drive, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Oct 04, 2010 | ASUS P5RD1-VM Motherboard
How to install windows xp in p5rd1-vm? when installing windows xp it goes no hard disk found. cant find sata hard disk. please help me about this problem.... thanks!
Make sure all the connectors are plugged in and in the correct spots. Then go to the bios and enable the SATA drives to be read. After that you should be able to boot from CD and install XP.
Jun 16, 2010 | ASUS P5RD1-VM Motherboard
Sata HDD NOT DETECTING IN XP SETUP
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Sep 11, 2009 | ASUS P5RD1-VM Motherboard
Hard disk is not detecting when I try to install windows 7
Hi
You should find the drivers you are looking for on the Asus website.
Here's the link to their download page,
http://support.asus.com/download/download.aspx?SLanguage=en-us
Hope that help,
MK Support
Mar 15, 2009 | ASUS P5RD1-VM Motherboard
Hi!
You need to copy the SATA drivers from the motherboard CD into a floppy diskette.
When you are booting with the windows xp installation CD you can see a message that says:
Press F6 for raid drivers
Press that key so windows installation CD look for the SATA drivers.
Jan 20, 2009 | Microsoft Windows XP Professional With...
Install SATA HDD for asus p5rd1-vm
The motherboard will support this drive.
I will assume you simple need it as additional storage set up as an additional drive?
If you do not see it in My Computer after connecting power and SATA cables, you will need Activate the Drive and Format it
To do this go to Control Panel - Adminstrative Tools - Computer management - Storage - Disk Manangement
You will see the harddrive here, right-cick it, Activate as a simple Partition and then format it.
You will now see it in My Computer and will be able to store on it.
Jan 05, 2009 | ASUS P5RD1-VM Motherboard
How to install window XP without floppy disk on asus P5RD1-VM
Hi sheikhun, just ignore windows F6 to add special SATA drivers. Install windows, when finished use your Asus CD and install missing drivers from CD. Than run windows updates.
You should not have a problem, if while in your bios your SATA drive is shown in the main menu. Than check the Boot section of bios. The boot order should be.
CDROM drive 1st. SATA drive 2nd.
Disconnect any other hard drives data cable while installing windows. When you finish installing windows & installing the drivers from the CD & windows updates you can shut down the PC & reconnect the data cables you may have disconnected.
If your bios does not see your serial ATA SATA drive than your SATA onboard controller is defective. Return to Asus for replacement/repair.
Mike
Mar 30, 2008 | ASUS P5RD1-VM Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
109 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
