Question about Pioneer VSX-1014 Receiver
RECEIVER WORKING PERFECT FOR YEARS. STORED IT IN THE GARAGE FOR A COUPLE OF MONTHS. FINALLY TURNED IT ON WORKED FOR AROUND ONE MINUTE THEN STOPPED AND DISPLAYED AMP ERROR. NOW WON'T TURN ON AND THE L.E.D LIGHT JUST FLASHES ON AND OFF. WHAT IS THE PROBLEM?
    New Friend:
  • 83 Answers
You have a [ bug ] in the unit..a real insect and it has made an unauthorized bridge ina circuit....just a guess,,, so if you have air in a can i would suggest that you blow the bodies out and then reconnect and see if you have solved the problem...good luck
Posted on Jul 12, 2007
98 monte carlo wont shift into gear? and fluid level is good,no leaks
Going in and out of gear are situation of low fluid pressure, The transmission pump is what is needed for the clutches to engage, you mainly have a failed transmission pump,
Apr 07, 2013 | 1998 Chevrolet Monte Carlo
2001 Monte Carlo battery goes dead over night
check for loose / dirty ground wires and points
indicates a voltage circuit being broken and the ECM is loosing voltage to work
Jun 27, 2017 | 2001 Chevrolet Monte Carlo
Car will not always start. Turn the key and nothing happens. Wait 5 to 10 minutes and usually it will start.
do you have alarm on it if so the alarm may be deffictive causing the busness interrupt to not allow the car to start
Apr 23, 2010 | 1997 Chevrolet Monte Carlo
My craftsman garage door is about 8 years old. It
Make a slight adjustment to the Upward force on the side of the machine. Turn the screw a 1/4 turn each time and test, see if that helps. Also, make sure there are no obstructions or friction when the door opens and closes. Try it manually first.
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
Check the electric eyes. If they don't see each other the door thinks there's something in the way. Blinking light is a safety alert to check the travel path.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Mitsubishi HS-412UR - Audio - Right Channel Not Working Properly
One of the strangest things that has happened to both the consumer and the technical field has been the use of a flexible adhesive on many of these machines' circuit boards. The glue in question is vanilla-colored, and has a tendency to react to electricity by inducing capacitance, resistance, and in some cases, even causing inductance issues. The fix, of course, is to remove as much of this material as possible, and following right behind with a nylon-based retainer. Then, if the problem persists, a followup with tried and true technical procedures...accordianman
Feb 12, 2008 | Televison & Video
KEYPAD WON'T WORK AFTER REPLACING BATTERY
A few questions...
Does the remote work very close to the garage, but not farther away - If so, then likely IS a battery problem....
Is the weather very cold where you live? - battery strength diminished quite a bit in the cold (try keeping the remote indoors for awhile & see what the results are). Also could be moisture in your unit - keep it inside & on a warm ( but NOT HOT ) surface for a day or 2
Did you get a good battery with an indicated shelf-life that is a couple of years into the future? (some 'dollar store' batteries are not very good). Also Alkaline batteries (if permitted by the user manual) are quite a bit more powerful than even the 'heavy duty' batteries of the same brand.
Finally, Is your unit at the garage powered electrically, or is it a battery also? If the garage portion is battery operated, try replacing that battery (in your receiving unit).
Hope at least 1 of these ideas helps...
-U.A.
Jan 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Pioneer VSX-1014 Receiver Logo
107 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
