Question about Vizio 39" E390VL 1080p LCD HDTV
No picture or sound
I have orange Vizio logo, when I turn on TV Vizio logo turns white but I have no sound and a black screen. Main board or power supply?
  • Vizio Master
  • 8,617 Answers
Its the main board 90% of the time when a vizio has that symptom.
Posted on Jan 10, 2013
djchillsnyc
  • 151 Answers
SOURCE: Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Posted on Jun 25, 2009
  • 27 Answers
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Posted on Apr 09, 2010
Testimonial: "alteans is very helpful."
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
Sebin
  • 712 Answers
SOURCE: Model VS42LFHDTV10A. The TV is
This may be the problem of relay switches. It can be replaced to eliminate such errors.
Posted on Sep 11, 2010
TV #1
  • 129 Answers
SOURCE: my 32" lcd vizio vx32L turns on there's sound
Have you tried the T-con board?
Thank you,
Posted on Dec 18, 2010
Vizio tv sv420m need help
Sure that the other boards you used were any good? If so, then try the Power supply board since the other boards of your set other than the main board specialize in the video aspects. Since you have no audio the only two boards that could account for no audio are the main board and the PS board which powers everything in the set.
Nov 13, 2015 | Vizio SV420M LCD TV
VT420M no sound or picture and turns off by itself
this sounds like a main board failure but a defective power supply can mimic some symptoms of a bad main board. I would recommend you get a diagnosis done on the set. If I was a betting man, I'd guess the main board
May 27, 2013 | Vizio Televison & Video
I have a vizio tv and it wont turn on it showed the vizio logo and now it wont turn on and its been like this for 2 days
The main board will need replacement. Its very common issue where the set will freeze at the vizio kogo then eventually it wont turn the logo from orange to white so it can power up. Replacing the main board should solve the issue. You can get the replacement main board from www.tvcircuitboards.com
Jan 03, 2013 | Vizio L32 32 in. LCD HDTV
I have a 32inch vizio tv that has no orange light on the logo but when turned on there is a white light and no picture or sound can any one help
The power supply board has some issues with its stand by supplies which should turn the logo orange as soon as its plugged in if the logo doesnt turn orange replace the power supply board You can get the power supply board from www.tvrepairworld.com
Dec 13, 2012 | Televison & Video
Tv wont turn on fuse is good
does the vizio logo light up orange ? If so and it doesnt turn white then the main board would be suspect. If the logo doesnt turn orange when its pluuged in then its the power board. You can get either board from www.tvrepairworld.com
Aug 12, 2012 | Vizio VO47L 47 in. LCD TV
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Jan 13, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio 39" E390VL 1080p LCD HDTV Logo
402 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
