Question about MSI Wind U100-280US Netbook
Clicking noise like sounds like a clock ticking wanna no how to stop it wen it typing aswell
  • MSI Master
  • 27,725 Answers
The clicking noise is possibly the reader arm skipping across the platters on your hard drive a dirty hard first clean all of the dust from your computer using a fine air blower using a vacuum cleaner with no metal piping you might short your motherboard out if metal touches anything or a fine air blower from a compressor making sure there is no MOISTURE in the air line then give the hard drive a firm tap on one side to free up the read arm you could run the check disk utility Click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive don't do anything while the chkdsk utility is in progress any input may damage your computer it might be power or data trying to get a connection make sure all power and data leads are securely attached
if this fails you might have a dirty hard driver with the reader arm skipping across the platters on your hard drive
give the hard drive a firm tap on the side to free up the reader arm you might be able to get it going long enough to salvage your data or it might go for a longer time
or you might use the freeze hard drive
http://lifehacker.com/170257/macgyver-tip--save-your-hard-drive-in-the-freezer
Hope this helps.
Posted on Jan 10, 2013
I have a ticking sound coming from the dash and a whining noise when in 5th gear
Search Results
    Dash Ticking Noise - Car Forums and Automotive Chat - Automotive ...
    www.automotiveforums.com > ... > Silverado
    I have no idea what the problem is but I think I have the same thing you do. Does itsound like it's coming from behind the instrument cluster or maybe a little to ...
    Ford Taurus & Five Hundred Clicking Noise In Dash Repair ...
    ? 4:44
    https://www.youtube.com/watch?v=g0qWRPZBhFo
    May 24, 2014 - Uploaded by FordTechMakuloco
    Ford Taurus & Five Hundred Clicking Noise In Dash Repair .... I have a 2008 ford taurus. there is ticking rapidly coming from the driver side by ...
    09-10 - 06 Impala Dash Clicking Sound Repair
    www.howtoalmanac.com/Scott/.../10-09-06ImpalaDashClickingSound.ht...
    My Chevy Impala started a clicking sound under the dash. It stopped ... Change the A/C controls until you hear the clicking sound coming from under the dash.
Dec 16, 2015 | Cars & Trucks
Haier dryer ticking noises
ticking you hear is the timer motor,drive motor is most likley geeting too hot.check vent ,dryer pushed back too far?hose kinked ?stopped up?too long?vent should be short,straight and of hard pipe.clean vent twice a year,heating element will love you.you will not love to replace it.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
What does it mean when a dryer starts to tick like a clock
the ticking sound you hear is the timer motor.this is normal on timed dry.on auto dry you should only hear it when the heater is turned off.if the dryer shuts off and will not start after 20 to30 min. the motor has over heated and stopped to prevent over heating.venting is the no.1 cause of this.the vent system needs to be checked first.if it is a magic chef,admiral,or maytag under a few years the part below the lint screen needs to have all that lint removed every 6mo.
Strange clicking noise in front
It could be the internal combustion of the main valve being clogged or it has a loose spark plug that is constantly providing a spark without oil.
Sep 17, 2013 | Honda Cars & Trucks
There is a ticking noise everytime my car is on that sounds like the turn signal noise but theres no pattern or order to the ticking. i thought the hazard switch was bad, what could the ticking noise be?
It could be a relay clicking under the dash due to a bad ground circuit somewhere in the vehicle. It would be best to have a professional put an ear to it.
Jan 16, 2011 | 2003 Pontiac Grand Am
97 Merc Grand Marquise just started a loud
If sound comes from under the dash, it might be an hvac actuator that is having a problem? Sometimes you can put your hand on it and feel the vibration? Sometimes with a relay, you can do the same thing.
Mar 13, 2017 | 1997 Mercury Grand Marquis
Y it freezes wen in safe mode before starting windows??? it takes forever to load for windows to come on. It freezed and does not wanna start wen in the configuration nore eaither and wen in the safe more...
your windows has been corrupted so you can solve your problem by repair install your windows....insert your bootable isntaller in the cd room...boot should be oin cdrom....when the cd finishes inializing and told you to install press enter...it search for your previous operating system...when it recognize press R or repair install..do not choose the fresh copy install it should be a repair install procedure...after installing it it will come to normal your o.s now...hope this would help.
Oct 19, 2009 | Acer Aspire 3000 Notebook
Clicking sound coming from thermostat area - when it's clicking the temperature numbers are off - was clicking for short periods of time - now clicking for hours
Hi, The clicking noise sound like a clock ticking? If so, it is probably you defrost timer. The defrost timer has a motor on it that sounds like a clock and has four wires that go to it..
This is what I would check first.
Vic
May 10, 2009 | Refrigerators
Danby Air Conditioner
I have the same problem with my Danby AC unit...every 5-20 seconds it makes a god awful clicking noise...Make me wanna cry
Jul 09, 2008 | Danby DPAC8020 Air Conditioner
MSI Wind U100-280US Netbook Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
