Question about Sony PlayStation 2 (PS2) Console
Hello!!  My children have a PS2 that has worked fine for quite a while.  But now--when a disc is inserted it won't rotate, AND the disc acts like it's going to play but it just goes to the system configuration screen instead.  Can anything be done except replacing the unit???
  • 535 Answers
Becose of the ps2 lense has limted life its around 1500 hurs thaty its will happen u need to replace the ps2 lence your problem will slove
Posted on Jan 21, 2009
Ps2 Disc won't respond to a Ps3 when inserted.
Only the first version of the PS3 had PS2 backwards compatibility, They did make a special edition Metal Gear Solid version with it included but other than that no other PS3 will play PS2 discs... No matter what Add-On you install.
Oct 07, 2012 | Sony PlayStation 2 (PS2) Console
PS2 format disc
did you insert any bad disk in that?
please try cleaning the lens using the lens cleaner
Oct 07, 2008 | Sony PlayStation 2 (PS2) Console
I had a gran turismo 4 that went out so I bought new and it does not act now, even though it is quite new
do you have a slimline ps2? the problem is more than likely with the drivers in your console. do all your other games work just fine? only gt4 thats not working? gt4 is a duel layered disc unlike most games.
my console won't play it either. plays all other games, even ones on the blue discs wiv no problem.
Aug 12, 2010 | Sony Gran Turismo 4 for PlayStation 2
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
How to get Rock Band to work no the ps2
Hi! Here are the tips to get Rock Band work on the ps2: Clean the disc well. Run another disc in the PS2 for about 5 minutes, then try the Rock Band disc. Plug in a standard controller, navigate to the browser screen, and if the PS2 reads the disc, simply select it with the controller. Insert a copy of Rock Band Track Pack (PS2) and let it run until it gets to the Harmonix screen. Quickly switch this disc for the Rock Band disc, and reset the console. Insert the disc so that the "K" in Rock Band on is pointed at roughly 6 O'clock. If the disc isn't read, then open your PS2 and rotate the disc one hour to the right. Repeat this until it is working or until it is back at 6 O'clock. Be careful with your Rock Band disc as some of them barely work to start with, and you don't want to damage it more. Save your receipt because if it doesn't work at all you will want to return it. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | MTV Games Rock Band for PlayStation 2
Please insert ps2 format disc?
Try inserting the disc in your computer. If it reads its fine. Then look if the Slus...... is compatible.maybe thats why it doesn't play. your ps2 must have an old bios system even if slim.
Mar 05, 2009 | Sony PlayStation 2 (PS2) Console
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Disc error on games only
The old PS2 had lazer calibration issues, which could differentley affect the discs.
How to tune
http://arstechnica.com/articles/paedia/hardware/ps2.ars
56K WARNING!!!
Feb 16, 2008 | Sony PlayStation 2 (PS2) Console
Slimline PS2 disc not spinning
my friend i have a ps2 that its cd does not rotate ( i open it completely ) and the lens is working the lens is producing a red ray and it is movinng up and down but just the cd motor doesnot rotate so i checked the smd fuses using my fluke dgital multimeter i found one that is open when i replace it the ps2 work perfectly fine for your information the smd fuses are marked ps1 ps2 ps3 ps4 etc
Apr 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
