Question about Samsung LN-T4061F 40 in. LCD HDTV
How do i fix my broken power button on my samsung 40 lcd tv?
Power button on the remote works fine. Power button on the side of the TV set no longer does anything when pressed. Originally the power button worked to turn the TV on and off. Over time, when this button was pressed while the tv was on, the tv reacted as if the Source (input) button was pressed! The other buttons on the side of the TV work fine, and all the remote buttons work fine. just this one button... I don't believe i ever exposed it to liquid/water. Nor has it been dropped. Thanks
  • Samsung Master
  • 8,617 Answers
You can easially just replace the button assembly with included circuit board just unplug your old and plug in the replacement. They are very inexpensive and you can get them for most models at www.tvrepairworld.com
Posted on Jan 10, 2013
  • 9 Answers
SOURCE: No picture
try chicking the horizontal section or vedio section...
Posted on Jan 29, 2008
  • 53 Answers
SOURCE: source in samsung 42 lcd keeps changing
it has something to do with the key pad assembly, i guess the source button may be sticking in. Has the key pad board been disconnected?
Posted on Mar 18, 2009
budmrtn
  • 11361 Answers
SOURCE: can I turn on the samsung flatscreen without a
Definitely. What is the model? Try find the user manul here: http://tv.manualsonline.com/homepage/
Posted on Nov 24, 2009
SOURCE: I have a Samsung LCD Tv, model LA37A450. Whenever
REPLACE THE IR BOARD AND FONCTION BOARD SOMTIMES THEY COME TOGETHER SOMETIMES SEPERATE
Posted on Apr 26, 2010
mikedenney
  • 150 Answers
SOURCE: Samsung 40" LCD Built in
Samsung sold thousands of big screens with a power capacitor issue--they have issued extensions of warranties on many models covering free in-home repairs by licensed regional technicians (sometimes not where you bought the TV). I know this one--at first, the TV would just behave this way maybe twice, then stay on...later, as the problem advanced, three, four, then five, and on, until finally it would keep cycling off and on until it completely stopped working. When my girlfriends' 46" LCD Samsung finally quit, we called Best Buy, who told us to call Samsung, who then did send a technician from about 60 miles away--he had the little capacitor replaced, and the TV working, within minutes. I asked him how they could afford to do this, and he informed me that he makes runs of these jobs, scheduling perhaps a dozen in one day. So, it's chronic, yes, and they're aware of it, and fixing it--hopefully still for free! So, I'd call my dealer, see if you have to call Samsung, then if you do, then call 'em--they should still be sending out the cavalry for this issue--they caused it by using cheap, poor-quality capacitors (the replacements are 'new and improved', and we've never had an issue since).
Posted on Feb 15, 2011
My Palsonic LCD TFTV81PBHDT remote is broken and buttons on side panel do not seem to work. How can I switch tv on to tune to universal remote? Do the side buttons have some sort of child lock function...
you can program most universal remotes to work the tv and menu the child lock is activated on the tv and the buttons will not work only power button will work as long as it has not been set to not work when made. some are set this way. but a remote with the right code set will turn on the tv.
Sep 20, 2013 | Televison & Video
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
Need remote code for samsung 5.1 home theater surround sound model#HWC560S
Welcome to Fixya. I would like to know who is the provider of the remote so we can provide you with the code. example: AT&T, Comcast or etc.
Please provide the information needed to be able to fix the issue.
Thanks
Sep 03, 2011 | Samsung Audio Players & Recorders
Hi, Can anyone recognise or diagnose this problem we are having with our Samsung LA32A450 LCD TV? It wont power up, no power on lights. Switch on side of TV wont turn on. Remote wont power it...
hi g_coopster,
Samsung LA32A450 LCD TV wont power up or no power on lights that indicated that no power line.
First of all, check the power line, cable AC cord is it installed properly, change ac cord if necessary. If you experience with electrical tool such as Volt meter, try it to measure the ac voltage from power line.
Or open your rear cover of unit, there are 2 board with difference color brown PCB (IP Board) and Greend PCB (main board). Check fuse on power board, if broken that may cause your problem. Change with the same type as labeled on it. But becareful, if after you change and try plug the power line in than broken again, thats mean power board have sort circuit.
My suggestions, try steps above and if it file, change power PCB block. You can buy it on Samsung cervice center.
Good luck.
Mar 22, 2011 | Samsung LA32A450 32 in. HD-Ready LCD TV
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Dec 09, 2008 | Samsung LN-T4071F 40 in. LCD HDTV
Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 22, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung LN-T4061F 40 in. LCD HDTV Logo
178 people viewed this question
Henry  Thomas
Henry Thomas
