Question about GeneralAire 7014 990-53 Solenoid Valve
My huminifier furnace stopped working , I don not know the reason. I cleaned it also replaced a new one , but it not work , no water come out
    Genius:
  • GeneralAire Master
  • 1,033 Answers
Is there 24 volts to the solenoid?
Posted on Jan 10, 2013
  • 3 more comments
  • doug nguyen Jan 10, 2013
    yes ,It is. GeneralAire model 1042 LH 24 volts /60 watts/150 psi
  • Robert Jan 10, 2013
    If you have 24 volts the the solenoid and it is new check the water supply on the inlet side, sometimes sedeiment can cog the saddle valve
  • doug nguyen Jan 11, 2013
    I try to clean solenoid , put each part in CLR about 15min , then assemble them back. I also check the water supply, it ok. Do you think the problem from electric or humidistat
  • Robert Jan 11, 2013
    Check for 24 volts from humidistat
    may be that problem .Thanks , I will check it
Honeywell he240 no longer working. It is less than 2 months old. I noticed water had stopped flowing out of drain tube. The filter tray is not filling up with water. Humidistat clicks when turned up and...
Maybe the hose is blocked. Take the hose off the supply side, and blow into just enough to add pressure to it and see if that works.
Try this site for more details or a similar issue:
Honeywell HE240 new install not working
Feb 12, 2015 | Honeywell Humidifiers
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
Water is continually feeding humidifier even when furnace is not running
I would recommend that you shut off water supply and remove solenoid valve.Disassemble valve and clean it making sure that there is nothing stopping the valve from fully closing. If you can not find any problem after cleaning then reassemble and leave the outlet connection loose.Turn on furnace and see if the valve is even trying to close. If not then you need to replace the solenoid valve. Hope this helps. Thank you.
Feb 05, 2011 | Aprilaire 550 Humidifier
Our aprilaire humidifier is only 4 years old and it does not seem to be working. We have static in the house and when I did test mode it never drained water like it was supposed to. Any ideas what I can do...
Hope this helps, check and see if humidistat is set to 35% humidity and that bypass damper on humidifier is in the open position or winter position.(humidistat is usually located on cold air return duct near furnace). Next, replace humidifier media pad, remember to replace media pad (filter) annually, you also may want to clean any lime deposit out of humidifier housing with a solution of warm water and white vinegar before installing your new media filter.Remember to turn power off at side of furnace when cleaning humidifier and replacing media. Before installing new media turn power back on to furnace, set humidistat to the on position, turn furnace thermostat above room temp., and inspect humidifier to see if water is running from top,(you may want to have a bucket under humidifier when checking for water), if you see water running, turn power back off to furnace, properly install new media filter, reconnect humidifier cover & set humidistat to 35%. If you do not see water present, check water supply valve to humidifier and make sure its turned on. If water supply valve is open, then check water supply tubing for blockage.And the last things to check is to make sure all registers through out your home are open and not blocked by any objects, also make sure furnace filter is cleaned, if none of this works refer to installation manual to see if humidifier was sized and installed properly, Good luck.
Mar 03, 2010 | Aprilaire 600 Humidifier
Moldy smell
Replace humidifier media pad (filter) with a new one, and clean interior of humidifier housing with a solution of warm water and vinegar, also replace or clean furnace filter, Good luck.
Mar 02, 2010 | Humidifiers
Why won't the water stop running?
When my humidifier refuses to turn off, it is always because the plunger in the electronic valve is stuck.
When the rheostat senses low humidity, it sends current to a coil, this creates a magnetic field that pulls a plunger up into a tube away from a rubber gasket (hole in center to match plunger) and water flows thru the hole. When humidity is high, the rheostat stops the current, and a spring/gravity push the plunger back against the gasket.
The plunger or the tube can get deposits, or just rust ever so slightly, and then the plunger gets stuck in the up = on position.
Buy a new solenoid valve $$$, or take your solenoid apart and clean the plunger and the tube with steel wool.
Jan 09, 2010 | Aprilaire 600 Humidifier
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Water runs out back humidifier into plenum & onto floor
Hi John Your whole question did not show up (maybe you can re-post) . I can answer what part i understand though. If the humidifier was wired in right it will not send power to the humidifier until the furnace is on, and calling for heat. This stops the unit from working in the cooling mode in summer.Make sure your furnace filter is clean as well
Hope that helps
Mar 05, 2009 | General Filters 1042-LH Humidifier
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
GeneralAire 7014 990-53 Solenoid Valve Logo
104 people viewed this question
Top GeneralAire Humidifiers Experts
Mack Baxter
Dennis
Are you a GeneralAire Humidifier Expert? Answer questions, earn points and help others
