Question about Ovens
Is it normal that a whirlpool oven current varies between 9.7 and 20 amps
When the oven is turned on the current measured on the line started at about 9.7 amps but 20-30 seconds later it increased to about 21 amps and continued to cycle at the same frequency of about 20-30 seconds for as long as we monitored it. Is this normal? If not do you know what would cause this?
  • Bruce Turriff Jan 14, 2013
    Thank you Bob but this stove is about25 years old and this problem just started to happen. I found a loose connection on the circuit breaker and fixed it so we will wait and see what happens. The stove is still drawing 52 amps when the FLAT marked is 45.5. Whirlpool seems to think the problem is the electronics control board.
    Genius:
  • Ovens Master
  • 1,669 Answers
The heating elements on any stove vary in resistance as they heat up and cool down. When cold, the elements offer more resistance thus less current flows. As the coil gets hotter, the resistance drops and greater current flow develops. The thermostat cycles the elements on and off to maintain the temperature measured in the oven, thus the cycling of power used.
Posted on Jan 10, 2013
cactus bob
  • 267 Answers
SOURCE: Maytag gas oven cycles every 20 seconds
yes it is normal . but i know your not the first to think its not , todays ovens are so tight , it only takes 10 seconds of heat to keep them at proper temp . it used to be that ovens where kept at a 3 degree sweep that is set at 350 turn on and up to 353 then off ,cool down to 350 and back on . this was a longer time off and a longer time on topday we keep to 1 degree ! 350 on to 351 off to 350 on and so on ....... so short berst of heat make for a more even oven ........ but i know i hate it too ! good luck
Posted on Jan 18, 2009
Maytag317
  • 1136 Answers
SOURCE: self cleaning oven won't unlock after cycle is complete
Hi, Try and restart the cleaning cycle. You might here the door latch motor run (unless you havve a handle you need to move to lock door) Once the clean cycle starts, cancel it and see if the latch releases.
Vic
Posted on May 21, 2009
protek480
  • 1723 Answers
SOURCE: I have a Whirlpool Super Capacity 465 oven Model#
The ignitor is not allowing enough 'current flow' to open the valve. The ignitor , even if it glows, can be 'low current' to valve.
(the ignitor current controls valve)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 03, 2009
  • 1340 Answers
SOURCE: Oven starts baking OK but will not stay hot.
This sounds like the heat sensor probe.If you open your oven,look at the back wall near the top.There should be a piece if metal clamped there.When you start your oven,the click is the on switch telling a relay to turn on power.After it gets to the certain temperature,the probe tells the relay to cut power.When you restart the oven after it's warm and cooling down,the sensor probe is giving the relay a "false" hot reading and the relay turns it off.Since it cycles only once or twice,the probe probably gets "stuck".Is the second cycle real short?Good luck! Greg
Posted on Aug 17, 2010
heatman101
  • 43501 Answers
SOURCE: Have a Whirlpool RF396LXEZ oven. It continually
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Aug 19, 2010
We just moved into new flat with a whirlpool oven Model No: 6AKP524/1X. There's no manual. What are the 4 buttons on top/front for.
Unfortunately we are unable to offer assistance to those residing outside of the United States. Please visit http://www.whirlpool.com.au for assistance in your region.
Jun 09, 2017 | Whirlpool Ovens
Replacing igniter on wallmount gas oven
If your gas oven isn't firing up, start your diagnosis by checking the ignitor for the proper current draw. "Uh, do what?" you ax, with glazed eyes. Don't be intimidated by techie-sounding procedures. This is simple stuff- if you can fog a mirror, you can measure current draw. This article explains how to make simple electrical measurements and this one explains what you're looking for in the gas oven ignitor.
Once you've proven that the ignitor is drawing insufficient current (and, therefore, is the correct part to replace to fix the problem), use this handy pictorial guide to hepya change it out. The wiring for most range ignitors is accessed underneath the oven by removing the pots drawer, as shown here. Why do you need to access the wiring? Two reasons: 1) so you can measure the current draw and 2) it's part of replacing the ignitor since the new one has to be wired in the same way as the existing one. Take note of where the wires go. The ignitor wires are not polarity-sensitive so don't worry about "reversing" them.
In this particular range (a Maytag), I had to remove a covering panel to expose all the wires.
Here, I have my clamp-on ammeter on one of the ignitor wires to make a current draw measurement. You can see the closeup of the meter in the next pic. You can see the current draw reading is 2.4 amps. For a square ignitor, such as this one (you'll see it in a subsequent picture), the minimum acceptable current draw is 3.4 amps, well above what I'm measuring here. Obviously, in order to make this measurement, the oven has to be turned on and the ignitor getting voltage. This is a LIVE test, meaning there's live voltage on the circuit. Fire in the hole! Fry yo ace if'n you ain't careful, Hoss, so... BE CAREFUL!On some ranges, you'll need to remove the back panel to get to wiring for one or both ignitors (there's one each for bake and broil). Yes, this means the range needs to be pulled out from the wall. In the case of a wall oven where the freakin' engineers didn't bother to make it service-friendly, you'll need to remove the entire wall oven from the cavity. If this is the case with yours, you'll quickly understand why I abhor wall ovens. Here's a typical bake ignitor. Note that this one is square. Some ranges, such as older Whirlpools and GEs, use a round ignitor. These two types of ignitors have different current draw specs and are made to be used with different types of valves. This means they are not interchangeable. So, if your range uses the square ignitors, you can only replace it with another square ignitor. The brand doesn't matter since, by convention, all square ignitors have the same current draw and all round ignitors have the same current draw. For replacement square ignitors, I find that the Maytag universal square ignitor kit is the most cost-effective and reliable. I use this kit in all brands that require a square ignitor.
Jul 26, 2012 | Magic Chef Ovens
Oven cuts itout when it gets hot but the power comes back on after it has cooled
as it is when your oven runs normally it usually does an on and off type of running in which the ignitor lights the flame from the gas which stays on until the oven tempreture sensor tells the control board that the oven is hot enough at which time it shuts off the gas until the oven starts to go maybe 10-15 degrees below the tempreture at which time it would let the gas go through the line again and turn on the ignitor try checking your ignitor usually if you stick an amp meter on them should be drawing 3.3 amps plz remember to shut off the gas from the gas shut of valve in the rear of the machine before measureing for the amps hope this helps
Jun 26, 2010 | Stoves Premier 600GRa Gas Single Oven
My Jenn-air oven won't turn on. It's model number
My Jenn Air 1995 wall oven was working fine until one day the oven and the oven gas burner did not turn ON. I had electricty (make sure you did not trip a breaker) since my front panel LCD and clock was OK. I had a good gas supply.
My oven is an "pilot-less" oven, it uses an electric igniter. Although the "ignitor" was "glowing red hot", the problem is that the gas valve depend on a certain amount of current. If you have a 120V house system, I think the valve needs 3.3 to 3.6 amps to turn on. The current flows through the igniter and then through the valve, as in a same path, like water. So you need an AMP meter to check proper current flow. I read 2.4 amps. I replaced the "glowing red hot" igniter with a new one, Vo"la it was fixed.
Bottom line if you have the oven plugged in OK and you see some life (clock), and you have the gas turned on, most likely the igniter is bad. Second choice would be the oven's thermostat (the temp knob that you turn, say to 350F), or it could be the gas valve.
All three are in same current circuit. The igniter gets the most abuse so I would start there first -good luck!
Sep 24, 2009 | Jenn-Air Ovens
I have a Whirlpool Super Capacity 465 oven Model# SF315PEG. The bake valve was being energized but not opening to allow gas into the burner. Bought a new valve assembly P/N 3195008 and replaced. Problem...
Sep 03, 2009 | Ovens
Circuit breaker 30 or 40 amp
Electric range normally takes 50 amp breaker. Are you installing new line for this range? Normal practice is seu aluminum cable #6/ 3 conductor
Apr 16, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Mar 24, 2009 | Ovens
My single glasstop oven
Will try to help here.. First off.. when you measure 120VAC at each terminal for the heating elements..what are you using as a reference? Ground? Since your stove is probably wired 220VAC, I would expect to see something across the two terminals to the element that isn't line voltage.. meaning, when you turn the controller to a setting, you should see something more than 120VAC across the terminals and the current will be controlled to maintain a heat setting. The burner that has an open element is indendent so that should not factor in. Heating elements are nothing more than a big resistor that generate heat when current flows thru them. Just because you have one leg of power doesn't mean you have current flow thru it and therefore that is where I think your problem is... You may have an open leg ..Check the power coming into the oven and make sure you have 220VAC across the two line voltage terminals.. Be careful ( very careful ) when doing this...
Hope this helps.
Sep 18, 2008 | Whirlpool RBS275PD Electric Single Oven
RBS305PDB6
The 350 as you stated is a default set point that you see before you start the cycle. What you should see afterwards (start bake) is the current temperature - which would normally be lower than the set or desired temperature - it will eventually get there
Regards
Jul 19, 2008 | Whirlpool RBS275PD Electric Single Oven
Gas Double oven (Built in)
It is definately not possible to change a gas to an electric. There are very few options for double gas ovens as electric is far superior. IF you have to go with gas , check out the local Habitat for Humanity store. You should be able to buy a used gas oven. It probably won't have the self clean feature. You would be better off trying e bay or a local scratch and dent outlet for a nice electric convection oven. It will need a seperate 220 volt circuit probably 40 amps. This isn't as expensive as you would think. Use the installer from the dealer you purchase the oven from. They are usually a lot cheaper than a union electricial worker. The 4 sizes available for built in ovens are the old standard of 24" the newer standard of 27" and the most common and useful 30" This is the current standard but you will also still be able to get 27" There is also a custom standard of 36" which would be for the very high end lines. These are all width measurements. The height will vary with the model. Most cabinets are made to accept various heights by removing one or more drawers underneath.
Jul 15, 2008 | Equipex PZ-330 Electric Single Oven
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
