Question about HP Pavilion dv6000z Notebook
How to replace left hinge on hp pavilion dv6 3019wm
Left hinge poped screw out pops when try to open n close want to replace hinge myself how do i do it?
  • HP Master
  • 32,281 Answers
These WEB sites show how to replace hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/ b>
Posted on Jan 10, 2013
Testimonial: "i'm still having trouble with finding the right hinge.is there a difference between lcd n led mines led thank u very much 4 your help"
frankzjm
  • 191 Answers
SOURCE: Tightening HP Pavilion DV9000 17'' LCD Hinges
you may find the hinges parts from eBay which is cheaper price:
http://shop.ebay.ca/?_from=R40&_trksid=m38&_nkw=HP+Pavilion+DV9000+hinges&_sacat=See-All-Categories
how to replace your laptop hinges:
1) take out the screws at back of laptop under the hinges base
2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
3) there are two cables connect between LCD lid and laptop base
you do not need disconnect those canbles. just careful them
4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
6) put back all screws step by step.
hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
Posted on May 18, 2009
RescueTechLA
  • 2653 Answers
SOURCE: New shell for my HP Pavilion DV6000z
Best place to get one is ebay for sure.
If you load some pics onto photobucket of the damage I can give you an idea of what parts you'll need.
Posted on Feb 25, 2009
gymowner
  • 679 Answers
SOURCE: HP Pavilion dv5000 screen black - related to broken hinge?
The ribbon that connects the lcd to the laptop circut runs through the hinged area, so when you moved it, the connector came out. Unless you feel confident in taking the frame off and replacing the connector it may be time to get it fixed if you have a warantee left from HP, if you want to try it yourself there are pictures on the site that you can look at, I can give youa link for them or you can just look up your Hp repair manual from the vast knowledge base on file
Posted on Mar 17, 2009
Geekman
  • 32281 Answers
SOURCE: Laptop hinge broken
You may be able to purchase parts from :-
www.lcdparts.net
Also from
www.ccflsurplus.com
Posted on May 27, 2009
  • 191 Answers
SOURCE: left hinge busted
There are six screws that attach the screen bezel. Remove the white screw covers and then the six screws. The bezel is now ready to remove, gently pry the bezel from the lid casing with a plastic screwdriver or an ipod tool. When the bezel is removed, you will see 3 screws holding the hinge to the lid. You will need to remove these screws and one underneath (bottom of the laptop).
It will be next to the battery and holds the hinge. Gently pry the power control panel and remove the connector, set it aside.
You will see 2 screws holding the hinge to the laptop. You will remove the hinge and replace with another one.
Replace in the order of removal.
Posted on Aug 04, 2009
How do I remove the hard drive from a HP XH485 Pavilion Notebook
I think the HDD is under the keyboard on that model (doh!), which is probably why you're asking. If you can't find it under any of the access panels on the bottom, you're in for a bit more work...
1: Close the laptop and view it from the rear where all of the ports are. There are 2 hinges for the screen. Remove the 2 screws that are in those hinges. They are only holding a plastic cover in place.
2: With the screws removed, open the laptop and open completely, so the laptop is laying flat open. At the top of the keyboard is the button panel and removes fairly easily. Use a small and thin flat tip screwdriver to carefully lift up this panel. I started from the right side as it is easier to pop off. The left side is a little more stiff. Once you get most of the right side up, gently pull to the right and wiggle carefully top pull the panel completely off.
3: The set screws for the keyboard are now exposed. There are 4 of them. Remove them and you should easily be able to lift the top of the keyboard and fold it gently towards the front. Do not pull or disconnect the keyboard.
4: The Hard Drive should be completely visible now. There are 4 screws holding the caddy down. Loosen these screws completely. They should not come out. After the screws are loose, pull on the strap at the front of the caddy. Pull straight up firmly and carefully. You may want to jiggle it slightly to work it up, and be prepared for it to pop out on you. It can be in there pretty stiff, and you don't want to damage any thing.
5: If you need to, remove the drive from the caddy, take the connector on the drive pins off first, and then remove the 4 screws attaching the caddy to the HDD.
Closing it up should follow smoothly in reverse order.
Nov 09, 2011 | HP Pavilion xh485 Notebook
HP Pavilion dv9000 screen lock jamming on the hinge. Is there a key for the nominal padock on the hinge?
I just started getting this problem myself. I'll let you know if I find a solution. For the time being, I'm pinching the joint with my fingers as hard as I can when I open or close it.
Oct 25, 2009 | HP Pavilion dv9000z Notebook
Left hinge busted
Dunt open and close lcd too muh otherwise it will damge your lcd cover and lcd bezel than it will cost u more. Remove all lcd screw cap and remove screws than slowly pull out lcd bezel and check is really hinges is gone or screw is loose. For Key u have to check it that any of latch of behind key is broken or fine. If its fine than just put that parallel to other keys and press it. it will seat back on jumper.
Jul 28, 2009 | HP Pavilion dv4000 Notebook
HP DV 1000 Loose Hinges?
I have replaced hinges on HPs and other laptops. I have found laptop hinges have no adjustments and have to be replaced.
Jun 28, 2009 | HP Pavilion dv1000 Notebook
I have a hp pavilion dv9000. and i need the screw for it.
Check out page 86 for the display schematics. Page 120 outlines the dis-assembly. Page 154 actually describes the screws of which you speak. You may be able to purchase them locally.
http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
Jun 06, 2009 | HP Pavilion dv9000t Notebook
May 18, 2009 | HP Pavilion dv6000z Notebook
Mar 17, 2009 | HP Pavilion dv6000z Notebook
My computer wont open
Hi woc169! Your problem may be related to an HP recall/repair announcement regarding left side hinge defects. Go to http://www.hp.com/#Support or call the number at the end of this message. Hope this helps!
HP Limited Service Enhancement for Left Display Hinge
HP has identified a hardware issue with certain HP Pavilion dv9000, dv9100, dv9200 and dv9400 series notebook PCs.
Step 3: Identify the symptoms Ifyour computer’s product number is listed above, and the notebook PCexperiences one or more of the symptoms listed below, contact HP duringthe Duration of the HP Limited Service Enhancement to determine whetheryou are eligible for a free repair. Symptoms of a broken left display hinge include but may not be limited to the following:
  • Whenopening or closing the display panel, you may hear popping or cracklingsounds from the bottom left corner of the display (left hinge area).
  • When opening or closing the display, the display may feel loose or wobble in the lower left corner.
  • The plastics surrounding the left display hinge may show cracks or breaks.
Service enhancements and free shipping
NOTE: This HP Limited Service Enhancement program is available in the United States and Canada through May 31, 2009.
  • Free shipping Ifyour notebook needs to be returned to HP for repair, the shipping costsare free. HP will immediately send you a postage paid container inwhich to send in your computer, and we will pay the return shipping. AfterHP receives your notebook PC, HP will use its best efforts to repairand ship your notebook to you within 10 to 14 business days.
  • Post-service warranty The HP repair warranty covers the left hinge repair for 90 days after HP returns your notebook PC.
Contacting HP To contact HP in North America call 1-866-671-7362 from 6:00 am to 11:00 pm MST, 7 days a week.
Dec 16, 2008 | HP Pavilion dv9000z Notebook
UNABLE TO CLOSE LAPTAP NO FREE MOVEMENT ON LEFT SIDE
I believe that's the hinge screws on the computer that's too tight. If you have screwdrivers that can fit into the hole of the left hinge, you can just loosen them up & that should fix it. If you're not sure what to do, just take it to a local store and have them loosen them up.
Hope this helps.
Oct 03, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv6000z Notebook Logo
545 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
