Question about Uncle Milton Moon In My Room
Moon in my room is flickering
The remote no longer works and when we turn the moon on it flickers.
2 Suggested Answers
  • 6 Answers
SOURCE: Lost remote for moon in
well you should get one then.
Posted on Dec 24, 2010
The vizio set will not respond to remote to turn set on.
Point the remote at your cellphone camera and press a button. You should see a flicker from the remote if it is working. If no flicker then remote is defective. If you have a flicker then the problem lies in the t.v. could be the receiver or another issue in the t.v.
Jul 21, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
My freesat remote just stopped working. Ive put new battries in, turned box off and on, disconnected and reconnected it but the remote just wont work anymore please help me
Have you got a video camera? Here is the trick to find out if the remote doesn't really work, or it's the TV that is not picking up the remote signal. Most remote use an infrared led to beam signals to the TV's. And this trick will show you whether that remote's LED is actually working. You and a friend or member of the family is all you need to begin testing your remote. Ask your friend or family member to hold the remote and you hold the camera on without recording. Point the remote about 5-6 feet from the camera. You watch the camera monitor screen while your friend or family member presses the On button or presses the buttons that you think are not operating the TV. With a dim room light, you should be able to see a flickering light coming from the remote in the camera screen. If it's hard to see, which I doubt, since remote infrared LED are pretty bright, you can turn your room lights off and try again. If the flickering LED from the remote is seen and is bright, then try all the buttons on the remote, or at least try the ones that you say are not working with the TV. If all is well, then there is nothing whatsoever wrong with the remote, but chances are that though the remote may beam out infrared light, it doesn't mean it is the right frequency for the TV. It could have lost the frequency and no longer sends the correct signals for the TV. However, the problem can also be with the TV remote's LED receiver. This falls into the hands of a technician's inspection on whether the receiving end of the remote is effective or needs replacement. In this part, you need to have the TV checked.
Nov 17, 2014 | Televison & Video
We got the moon in your room and can't get it to work. Chnaged the batteries twice, made sure the moon was on, pushed all the buttons and nothing. please help.
Well.. without going into great detail
Assuming you placed the batteries in the Moon.. and switched it to ON..
A couple of things.. first.. the room lights must be out.. it has a sensor so it won't illuminate with lights on.
Also.. I know it's redundant.. but make sure the batteries are oriented correctly +/- per instructions in both moon and remote control.
And finally..the"Moon" must be hung on a wall.. in a vertical position using one of the three mounting holes.
http://unclemilton.com/in_my_room/moon_in_my_room/
Best of luck!
Apr 30, 2011 | Uncle Milton Moon In My Room
My GE Universal remote no longer works. The battery is fine but the signal is no longer working on my TV. I would like to try to reset the remote to my TV.
Please try to programme your GE remote to your TV
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Aug 04, 2010 | GE RM24930 Remote Control
Uncle Milton "moon in my room" can you get a replacement remote control as I' ve lost mine?
Uncle Milton sell replacement remote.
http://unclemiltonstore.com/?deptId=2056
Apr 26, 2010 | Uncle Milton Moon In My Room
The remotes are no longer working... we changed
Make sure the light in the wall control is not flickering. If it is press and hold the button with the lock icon for 3 seconds and release. If this isn't the case your receiver which is part of the logic board has failed.
Nov 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hampton bay CFL lights flicker when they are turned off
I believe the flickering comes from the way the CFLs extinguish themselves after the remote turns them off. As the other poster said, turning them off with the wall switch as well after turning them off with the remote stops the flickering.
It is because the remotes are a dual mesh type of signal, which uses the RF as well as the electrical power to activate and turn them off.
Actually, this type bulb is not designed to work as well in dimmers or remote switches as is incandescent. You will find if you replace them with regular incandescent they will not flicker.
Sirwriter
Apr 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Uncle Milton Moon In My Room Logo
41 people viewed this question
Top Uncle Milton Toys Experts
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you an Uncle Milton Toy Expert? Answer questions, earn points and help others
