Question about GE Profile Harmony DPGT750GC Gas Dryer
Reattach part to close dryer door
Attach part to close dryer door
Rubber gasket around window on door of dryer is coming off
It sounds like it is worth a try to re-attach the existing gasket. I would try some silicone based adhesive. It sticks to most anything, remains flexible and can take high heat. Maybe something like this:
https://www.lowes.com/pd/E6000-CLR/50149282
Jan 15, 2018 | LG Washing Machines
When dryer finishes it just keeps on beeping
Instructions
Open the door to the dryer and remove the screws in the hinge. Lay a towel on top of the dryer. Place the dryer door on the towel with the inside facing up.
Remove the screws from the inside of the dryer door. Disassemble the dryer door carefully, removing the cover on the right side of the innermost section of the door and the shield and hinge from the left side of the innermost section. Reattach the side cover to the left side of the innermost part of the door. Install the new shield to the right side of the door section, with the flat side against the door and the notches facing up (they will face into the dryer). Attach the hinge on the same side as the shield.
Set the top section aside. Rotate the remainder of the door 180 degrees so that the handle is on the left of the upside down door. Check that the latch aligns with the cover before screwing the door back together. Screw the hinge into the corresponding holes on the left side of the dryer door frame. Remove any stickers that might be blocking the holes.
Check the alignment of the door by opening and closing it several times. Loosen the screws on the hinge and nudge the door slightly until the fit is correct. Tighten the screws into place.
Jan 10, 2013 | Haier HDY6-1 Electric Dryer
Can't get the door back on
Instructions
Jan 09, 2013 | Dryers
Need to reattach the oven door
most doors lift off. there should be some stops on the hinge .set them before remmoving door . but you have already got the door off so you will have to reset the hinge lever till the stop will hold then insert the hinge into slot and fold the door down . release the stops and door work work properly . mm .
Jul 16, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Diagram for setting up belt on drum tenion
Replacing the Belt
  • Step 1 Put the dryer door-side down on the floor. This allows easier access to the back.
  • Step 2 Locate the center pivot suspending the dryer drum. If held by a clamp, removed any nuts or screws retaining the pivot axle.
  • Step 3 Move the pivot out of the bracket and slide the new belt inside the bracket.
  • Step 4 Replace the drum pivot in the bracket and reassemble the bracket.
    Looping the Belt
  • Step 1 Flip the dryer up so it is once again sitting upright.
  • Step 2 Locate the groove or wear mark the previous belt left in in the circumference of the drum.
  • Step 3 Wrap the belt around the drum in this groove or wear mark, with available slack at the bottom of the drum.
  • Step 4 Wrap the belt around the drive wheel located on the drive motor in the lower corner of the dryer.
  • Step 5 Insure the belt is snug but not biting the drive wheel. This indicates the proper size belt is installed.
    Reassembly
  • Step 1 Reattach any clips or wires to the back cover.
  • Step 2 Reattach the back cover using the six-sided sheet metal screws removed earlier.
  • Step 3 Reattach the top cover. Close tightly so clips secure the cover.
  • Step 4 Plug in the dryer and turn it on to test the belt repair.
  • Step 5 Reattach the dryer vent conduit
  • Feb 06, 2010 | GE Dryers
    How do I attach the oven door back on to the stove? When I try to prop open the brackets, and reattach the brackets snap back closed. George V
    Usually there is a hole that you open the hinge and put a nail in on each hinge to hold them open until you get the door in place.
    Nov 21, 2009 | Maytag CWE4800A Electric Single Oven
    Maytag DE 412 Door switch
    Attach the white to the common and the yellow to the NC, which means "normally closed". Normally, the circuit is closed which allows the dryer to run.
    Nov 02, 2008 | Maytag PYE2300AY Electric Dryer
    Kenmore dryer
    IF THE DRYER COMES ON BY ITSELF WHEN THE TIMER IS SET AND THE DOOR IS CLOSED, THE PUSH TO START SWITCH IS SHORTED. THIS WILL CAUSE THE END OF CYCLE SIGNAL TO BUZZ WHEN THE TIMER IS IN THE OFF POSITION(END OF CYCLE).UNPLUG THE DRYER, REMOVE THE BACK PANEL OF THE CONSOLE, AND REMOVE ONE WIRE FROM THE PUSH TO START SWITCH. ISOLATE IT SO IT ISN'T TOUCHING ANYTHING AND PLUG THE DRYER BACK IN. SET THE TIMER AND CLOSE THE DOOR. IF IT DOESN'T START UP OR BUZZ, UNPLUG THE DRYER AND REATTACH THE WIRE. PLUG THE DRYER BACK IN AND SEE IF IT STARTS BY ITSELF. IF IT DOES, THE PUSH TO START SWITCH IS SHORTED AND WILL NEED REPLACED.
    Apr 01, 2008 | Kenmore 62602 Electric Dryer
    GE Profile Harmony DPGT750GC Gas Dryer Logo
    220 people viewed this question
    Top GE Dryers Experts
    Dave Harrison
    John Tripp
    John Tripp
    vince
    Are you a GE Dryer Expert? Answer questions, earn points and help others
