Question about HP iPAQ RX3715 Pocket PC
Wi fi connectivity
I used to be able to connect to the internet via wi fi on my ipaq 3715. now when I try to connect I get "cannot connect with current connection settings. To change your connection settings, tap settings". The next screen askes me to add a new modem connection or set up my proxy server". I don't have a clue how to do either. Also, the wi fi sometimes turns green but most of the time after it turns green, it goes to amber. I have gone in to play with the settings but I think I made things worse. What can I do at this point? Thank for anything you can do to help...
    Problem Solver:
  • 15 Answers
Refer to
http://www.fixya.com/support/t189947-ipaq_rx_3715_internet_settings
for a potential solution, as someone else had the same problem.
Posted on Mar 01, 2008
SOURCE:
My M800 won't cannot detect any wifi or network and i can't get online
try to connect via lan cable.if u get online then look for wifi switch !
Apr 09, 2015 | Computers & Internet
How to activate facebook without wifi?
Accessing Facebook needs internet connection. Without any active connection, you will not be able to connect to internet.
Internet connection option for such devices:
Mobile phone:1. GPRS - settings will be coming from your mobile service provider, data rates will be deducted from your load credits.2. Wi-fi connection - needs active wireless connection from your modem/router/gateway. Charges will be applied via ISP 9internet service provider)
Laptops / computer / PSP:1. USB Dongles - this will use the gateway connection via BTS for its using the internet connection like the protocol of ISP.2. Wi-fi - Wi-fi connection - needs active wireless connection from your modem/router/gateway. Charges will be applied via ISP 9internet service provider)
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
Dec 01, 2011 | Myphone Computers & Internet
HI...CANT CONNECT MY IPAQ HX4700 WITH INTERNET(WIRELESLY)I CAN SEE MY NETWORK ON SCREEN,BUT DONT WANNA ACCEPT NETWORK KEY.IAM SHURE THE KEY IS CORECT.RESULT OF WI-FI SELF TEST SAYNG:YOUR WI-FI IS NOT...
Are you sure you got the key correct? You sHure have problem getting your spelling coRect. If you are sure, check if you got the encryption protocol (WEP, WPA, WPA2) and sub-protocol settings correct, and check your SSID, key number (1-4), etc.
Jan 17, 2011 | HP iPAQ HX4700 Pocket PC
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
IPAQ Rx 3715 Internet settings~ conectivity problem
I have a few thoughts.
Occasionally, for no apparent reason, the ipaq will "forget" your password. Try re-entering it.
The other option is to try a program called Kasuei Hitchhiker. It is a more powerful and easier to understand interface than the normal ipaq one. you can download it here.
http://www.freewareppc.com/communication/hitchhiker.shtml
Hope it goes well! I'll try again if this does not work!
Aug 29, 2007 | HP iPAQ RX3715 Pocket PC
Connecting a Ipaq RX3715 to a wireless router
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Mar 05, 2007 | HP iPAQ RX3715 Pocket PC
HP iPAQ 3715 - screen problems
Return it as faulty. WiFi should not impact your screens ability to stay on.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
Hx2410 general wi-fi questions
Have you been able to connect through your router at home? I'd get that set up and running first. Then doing it on the road will merely be variations on a familiar theme. If you've tried at home but it hasn't worked, let us know something about your home network (what kind of router? using security/encryption?), and about what you've already tried so we can try to help.
Sep 08, 2005 | HP iPAQ hx2410 Pocket PC
Ipaq 4705 wont connect to internet
Try running through this WI-FI setup tutorial, its very helpful. http://wifi.aximsite.com/
Sep 08, 2005 | HP iPAQ HX4705 Pocket PC
Connect to the Internet
There are many things to look at when setting up WI-FI to work with your iPAQ. Here is a good link that walks you through the WI-FI setup, with helpful screenshots. Its a good place to start, hope it helps! http://wifi.aximsite.com
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
204 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
