Question about GE GSL25JFPBS Side by Side Refrigerator
Water will not dispence in ge refrigerator model number gsl25jfpa bs
Refrigerator will dispence ice.
  • Gary Gorham Jan 13, 2013
    Ice will dispence, both cubed and crushed. Could line be frozen?
    New Friend:
Your line is frozen. Frozen water dispenser line is a problem with this model. There are number of solutions.
1. Contact GE 800 386-1215, option 5 and ask for WR49X10173 heater kit. There is a video http://www.youtube.com/watch?v=BdNX3LteJTw to help you install it. Try to get GE to send you the fix free.
2. Get a hair dryer and heat the dispensing box until the water dispenser works. This is not a permanent solution, though, and it takes 15 to 30 minutes. Hang a long beach towel or blanket over the open freezer to save the cold air.
3. Place a long, clean fishing line or weed wacker line up the water dispenser line. When it freezes, pull carefully to dislodge the frozen water.
4. Buy another brand of refrigerator and let GE know they make inferior products.
Posted on Feb 18, 2013
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: My GE side by side w/ water & ice maker
There are few Steps that you could Verify and narrow down the problem :-
1. Compressor - Make sure that the Compressor should be working. When you ON the refrigerator, you could hear a clicking sound from the Compressor.Compressor could be Hot but not enough to lay eggs on it.
Note - In case, you find that the Compressor is Clicking and Shut Down the machine every now and then, more often that's an indication of Faulty Compressors. With most Brands, they do come up with 5 Years Warranty.
2. Make sure all the Fans are Working. I have seen many times, that the Fans are not working and the people are Inspecting other Components in the Refrigerator.They should also be running at Optimum Speed.
3. Do you see any Ice in the rear of the Freezer? More often - Frost. ( Not Crystal Clear ). If yes, take a Blower / Dryer and melt it. You would see a complete Difference.
4. Make sure that the Condensor Motor is working. If you could hear Condensor Fan is running, it always indicate that the Motor is Fine too.
5. How many times we never clean up the Evaporator Coils? We are using it for Years and we never clean it. So, if this is the Case, time to Take a Vacuum and clean the Evaporator Coils.
6. It could be a Defrost Problem. There are many Components but How could you make sure?
The Best Way - Disconnect the Power Supply and Unplug the Cord. Take everything out of the Refrigerator. Keep the Doors Open for 24 hours. After 24 hours, plug in the Cord and then Turn ON the refrigerator.If you see that there is Some improvement, more likely you have faulty Defrost System.
7. On other Occasions, i have Found Overload Relay to be one of the reasons. I solved many Problems where the Customer Actually Test and Find that the Overload Relay is at Fault.
Note - There could be Freon Leak or Gas Leak which i am not considering right now. You need to contact a Licensed Professional t check these.
Above mentioned are few steps that you follow to narrow down the problem. Unless call a repairman to fix the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 24, 2010
  • 1456 Answers
SOURCE: I have a side by
Hello
If your ice dispenser is leaking water into your ice bucket or onto your floor, several things could be the source of the problem.Please Check the following items:
Check the water valve for leaks.
See if water is leaking from the fill tube extension.
See if the defrost water drain is cracked or overflowing.
Check for water on the exterior of the refrigerator case
See if the refrigerator is leveled and standing straight(not bent)
Posted on Jan 02, 2011
Problem with my GE refrigerator model # GSL25JFPA BS freezer nor frig gets cold but there is still electric to it
check the gaskets on the doors to see if they r sealin proplerly if they r than that means that it is low on freon and it is cheaper to buy another refridgerator.
Aug 23, 2012 | GE GSL25JFPBS Side by Side Refrigerator
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
GE model # GSS25JFMCWW has water to the dispencer,but not to the icemaker.
could be a number of thing,s The device that sends water to the ice/mak is different than the door water the ice maker has it,s own brain (circuit) water in/out some built into the frig itself . The ice /mah send siginal to water valve to send water.. to ice maker sorry icall appl man sorry
Mar 18, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My Fridge GE Mod# GSL25JFPA BS, does not dispense any water, I have replaced a bad water celinoide, I blow into the 1/4" tube and it seems to be cloged from the door to the dispenser on the door. is...
g.e. has had problems with the freezer door.when the foam is blown into the door if the water line doesn't get covered the line freezes.you can call them and tell them your problme,i've seen them send out a new door for free.also g.e. has a heater kit made for this problem part number WR49X10173 and it's around 30 dollars
Feb 15, 2011 | GE GSL25JFPBS Side by Side Refrigerator
GE REFRIG
Most likely your water control valve for the icemaker side, you can check the ice maker by filling with water and when freezes and if dumps then the water control valve. Part number WR57X10032
Sea Breeze
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Nov 17, 2008 | Refrigerators
Not cooling or freezing
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
Aug 28, 2008 | GE GSS20IEP Side by Side Refrigerator
GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Mar 02, 2007 | GE GSH25JFR Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
215 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
