Question about Dell OPTIPLEX 745 PC Desktop
Setting up my computer and moniter says,drive 0 not found:serial ata,sata-0 hit f1 to continue,when I do nothing happens.
  • Dell Master
  • 7,627 Answers
Is the computer new? If so, return it. If not, Unplug from AC, reseat ALL HDD cables, reboot, If that fails remove the HDD , test, replace if necessary. Have you tried a system restore/recovery, If the computer does not ID the HDD, it's doubtful you can.
Posted on Jan 10, 2013
Testimonial: "Thank you,I found the problem. The power cord inside the tower wasnt even connected,lol Fixed and works great the power,lol"
3 Suggested Answers
mansnes
  • 50 Answers
SOURCE: drive 0 not found;serial ATA,SATA-0
are you SURE you connected up the power connector in addition to the SATA connector? If so, you may have hozed your drive.
Posted on Feb 06, 2008
melnavz
  • 1226 Answers
SOURCE: Dimension 3100 Won't Boot
Try remove the hard dirve and then fix it back. and if the system prompted you to strike F2 then go . In the bios setup. load the " setup bios default and press "F10" to save and exit. the computer will restart.
Posted on Jan 16, 2008
5kpl-vm asus mother board not detected new sata segate HDD how to resolve
The BIOS does not detect or recognize the ATA / SATA hard drive Tips and tricks for troubleshooting a Serial ATA or ATA/IDE internal drive that is not detected in the BIOS.
There are six main reasons why a system BIOS will not detect the presence of an internal hard drive. Here is a list of them. They are not in any particular order, but you can follow these steps one by one to troubleshoot this problem:
  1. Drive not enabled in the BIOS
  2. Serial ATA drivers are not properly installed
  3. Faulty or unplugged data cable
  4. Drive is not spinning up
  5. Incorrect jumper settings on the drive
  6. Faulty hard drive
Note: Sections 3, 4, 5, and 6 pertain to PC or Mac systems. Sections 1 and 2 pertain only to PC systems.
For more detailed step-by-step troubleshooting on this topic, please see the Seagate Serial ATA troubleshooter "Drive Not Detected" section.
After verifying that your ATA or SATA port is set to Auto-Detect or is enabled, if you find that your disk drive is not being detected (auto-detected) by the system BIOS, try the following steps to try and isolate/troubleshoot the problem.
  1. this link can be useful.
    System setup is where the date and time are stored and where startup preferences like NumLock or Passwords are defined. In addition, many hardware settings are defined in System Setup.
    In particular, hard disk drives are often controlled here. At the simplest level, hard drives are numbered in Setup as Drive 0, Drive 1, etc or sometimes as Primary Master, Primary Slave. Which ever way these are named, they have a basic ON / OFF setting (sometimes AUTOMATIC or something similar). If your drive is not detected it may be because it is turned OFF in System Setup.
    In most cases, the boot drive is Drive 0 or Primary Master. When you add a second drive to the system, it may be need to be enabled by turning it ON in System Setup.
    Sample screen shot showing a Dell System Setup section for disk drives:
  3. To be able to hit the F6 button, you must restart the Setup process, and watch the bottom of the screen after pressing Enter on the "Welcome to Setup" screen. There will be some moments of files being loaded, and then you should see a message appear that says "Press F6 if you need to install a 3rd party SCSI or RAID driver". This message will only stay on the screen for a couple of seconds, so press F6 as soon as you see it appear.
    (Click to expand)
  4. After this is done, you will see other messages appear, and it will act as though nothing is happening, but eventually a screen will appear that will allow you to install the drivers for the add-in SATA controller. The screen will look like the sample below:
    (Click to expand)
  5. After you press S, the driver install process will continue and the floppy diskettes will be needed. Further instructions will be furnished after the driver install process has ended.
    (Click to expand)
  6. Insert the floppy diskette containing the drivers for the add-in Serial ATA controller.
  7. Once the drivers are loaded, proceed with the normal Windows XP/2000 installation.
A few further notes on the driver diskette:
For the hard drive to be detected in a new installation, the drivers for the add-in SATA controller/motherboard must be loaded at the beginning of installation.
The drivers for the controller/motherboard can probably be found either on the CD that came with it or on the manufacturer's website. These drivers do not come from Seagate; they come from the motherboard manufacturer. Simply load the required drivers on the diskette and have it ready.
  • Document ID: 182453.
    Here are some images of Serial ATA cables. Click to expand.
  • The BIOS will not detect a hard disk if the data cable is damaged or the connection is incorrect.
    Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
  • The easiest way to test a cable is to replace it with another cable. If the problem persists, then the cable was not the cause of the problem.
  • For ATA drives, Seagate recommends using UDMA cabling with a maximum length of 18 inches. UDMA cables have color coded connections which require proper orientation when connecting.
    • Blue connector - always connects to the motherboard.
    • Grey (middle) connector - is used for slave devices on the cable.
    • Black connector - is used for master device connection.
    See this image:
    (Click to expand)
  • to determine whether it is providing sufficient electrical power to operate the drives and devices you have in your computer.
  • If the drive is still not spinning, connect it in another computer if possible.
  • Connect the drive in a SATA-USB enclosure or something similar if possible.
  • If the drive does not spin up after all of these steps, please visit the Warranty page to begin a warranty replacement order.
  • 48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA: It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used.
  • SeaTools for DOS (see the tutorial here) to test the drive. If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
  • The BIOS does not detect or recognize the ATA SATA hard drive
    May 08, 2014 | ASUS K8V-MX Motherboard
    What's your problem?a way to turn the SATA ports to ON in the BIOS
    You can go into the bios and on those drives that are not found you can turn them OFF or N/A. They are probably set to AUTO or ON.
    If that does not work I would say remove the power cord, remove the cover, then remove the main power to the motherboard then plug the main power to the motherboard back it. The main power will run from the power supply and the end of it will be about a 2 inch strip that plugs into the board. Press and hold the little catch on it then pull it out of the socket on the board. Put it back in firmly. Reboot and see what happens.
    Apr 04, 2012 | Dell Dimension 4700 PC Desktop
    After installing a sata drive with xp home i took my old hhd and put it on the cable with another hhd on the same cable . Now mthe primary hd 0 and 1 are not found and f1 to continue then it will load x...
    First, do you have a 40-wire or an 80-wire parallel-ATA ribbon-cable?
    If you have the 40-wire cable, you need to set the jumpers on both of the old drives.
    Set one disk-drive to 'master' (maybe also add 'with slave present').
    Set one disk-drive to 'slave'.
    If you have the 80-wire cable, you need to set the jumpers on both of the old drives.
    Set both disk-drives to 'C(able)S(elect)'.
    Is the new SATA drive just a "data" drive, or did you install Windows onto it?
    May 27, 2011 | Computers & Internet
    My computer starts on black screen... drive 1 not found: serial ATA, SATA-2.. strike the F1 to continue, F2 to run.. if i press F1 it says NTLDR is missing what di i do? I have the operating sys. disk..
    • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
    • Click to select any options that are required to start the computer from the CD drive if you are prompted.
    • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
    • Press 1 (One) to select windows XP and then hit enter.
    • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
    • At the command prompt, start typing
    COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
    COPY D:\i386\ntdetect C:\ (a file that may also be missing)
    Then rebuild the boot configuration boot.ini file by
    Attrib -H -R -S C:\boot.ini (if not found skip the next line)
    DEL C:\boot.ini
    BootCfg /Rebuild
    Feb 03, 2011 | Dell Dimension E310 PC Desktop
    Drive 0 not found Serial ATA, Sata 0
    Check the jumper settings on the primary hard disk drive and set to master. Also check that the cables and connectors are firmly in place.if problem persist, drive may be bad
    Sep 17, 2009 | Computers & Internet
    Drive 0 not found;serial ATA,SATA-0
    Feb 06, 2008 | Dell Dimension 3100 PC Desktop
    Sony Dual DVD +/- RW
    set the hard drive to master and the dvd to slave
    Jan 24, 2008 | Computers & Internet
    Make sure your HD Cables are all firmly plugged in, and that all drives are starting when you turn on the computer. You can tell with harddrives as they will slightly whine, and have a small, steady vibration to them. If they are all starting, and all cables are fully seated, check in your Setup utility that the drives themselves are Auto-Detect. If none of this fixes your issue, you may have to refer your computer to a computer repair shop.
    Hope this helps!
    -Backu
    Jan 16, 2008 | Dell Dimension 3100 PC Desktop
    Dell OPTIPLEX 745 PC Desktop Logo
    Alun Cox
