Question about Samsung 55" UA55C7000 MULTISYSTEM LED 3D TV FOR 110-220 VOLTS 2 pairs of glasses and a movie
BROKEN SCREEN 3/4 OF THE THE SCREEN IS OK EXCEPT, MAINLY THE TOP LEFT WHICH IS BLACK WITH COLOURED LINES STRAIGHT ACROSS THE SCREEN AND ALSO STRAIGHT DOWN, AND ALSO SHADOWS THE PICTURE AND FLICKERS ( SO AS IF IM WATCHING DUPLICATE ON SAME SCREEN WITH A FAST RAPID FLICKER ) ITS AN INCH OR SO ABOVE THE PICTURE WHICH IS STILL AN NO FLICKER
  • STEVEN BUTLER Jan 10, 2013
    KngJake you wouldn't happen to have Samsung contact number handy in front of you would ya ? cheers
  • Back2life Electronics Jan 11, 2013
    A new replacement panel for that set could easily cost $800 and up.We shot a video showing just how fragile LCD panels arehttp://www.youtube.com/watch?v=8uZnc98n6...
  • Samsung Master
  • 933 Answers
You now have a 55" parts unit !!! A replacement 55" panel will most llikely cost as much as a new set !
Posted on Jan 10, 2013
    Roughly how much would the panel cost???
  • 103 Answers
SOURCE: samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Posted on Mar 05, 2008
SOURCE: Black 3-4 inch wide Stripe
Contact Samsung and demand a replacement television. With my situation, they had me take it to a repair shop and get an estimate. I was originally going to get nothing, then after several correspondence, only the parts for free since it was out of warranty (not too far out of warranty) and pay for labor. They decided it would be too expensive and difficult to find the part. They ended up letting me pay 350 for the same tv but 2 years newer. It is definitely worth the price since the labor alone would cost that.
Hope this helps!
Posted on Oct 26, 2008
romsky79
  • 822 Answers
SOURCE: 3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
Posted on May 25, 2009
  • 58 Answers
SOURCE: 50 inch samsung plasma that is 3 years old
not necessarily, sometimes the connectors that feed the screen get old and dirty
If you have some electronic skills, open the TV and clean the connectors around where you see the symptoms and you may have a good chance to get if fix by doing that...
good luck
Posted on Jul 15, 2009
sodeep
  • 3267 Answers
SOURCE: screen has black horizontal lines across the
panel needs replacement, better go for a new tv
Posted on Dec 25, 2010
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
How to fix blank spots on the screen that get worse when you touch the screen?
do you still have a complete picture ?,are the lines coloured,?
do the lines go from left to right or do they spread out from the blank spot in a circular direction like the suns rays?
from your description above i am sure you are describing a broken lcd screen,if i am right there is no repair feasible for this set..
Len
Aug 31, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Red and yellow horizontal lines on the last third of the screen
3 Options
LCD damaged
Flex cable from MB to LCD
Graphic card damaged
First try to connect the laptop to a external screen...its ok???
Remove the lcd and try another one...its ok???
If not....change the flex....its ok?
If not...only one option...graphic card (GPU)
Feb 26, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Coloured lines across the computer
Hook a spare monitor to the video output, if picture okay the LCD panel display will need to be replaced, go to www.ebay.com type make and model of laptop, refine search to screen. But if both show the same symptom it is the video graphics card.
Jun 03, 2012 | IBM ThinkPad T40p 2373 Notebook
When i try to use the screen display a get a blank white screen with a series of straight vertical lines on the left hand-side of the LCD Screen as well as one staright horizontal line going across the...
Sounds like your LCD screen might be broken. Try PhotoTech Repair in NYC. They are manufacturer authorized to do repairs.
Here is the website:
www.phototech.com
Mar 29, 2010 | Fuji FinePix S5700 Digital Camera
Samsung u600 different coloured lines on screen??
sounds like your ribbon is broken,it happens to sasungs often,get it replaced
Jul 14, 2009 | Samsung SGH-U600 Cellular Phone
26PFL5520D/50 DVT PROBLEM
If the lines across the screen are made up of coloured blocks, then the problem is likely to be a weak signal.
Digital channels are broadcast in groups called multiplexes. Sometimes one multiplex may have a weaker signal than others, and so you experience problems with up to 6 channels when all others are ok.
If it is only one or a few channels then just wait and see what happens, because it may be transmitter works.
If you have problems with all channels it could be a connection or antenna problem.
If the lines are just straight lines, then try resetting the TV as follows:
Switch on the TV
Press and hold the menu button on the side of the set. The settings menu will appear. Hold until the menu disappears again.
When you release the button, the TV will take up to about 90 seconds and then reset.
The TV will then show the original screen when the TV was new.
Press ok when shown.
Set language and country settings.
Move down the list and press ok to re-install all channels.
Feb 22, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Samsung 55" UA55C7000 MULTISYSTEM LED 3D TV FOR 110-220 VOLTS 2 pairs of glasses and a movie Logo
135 people viewed this question
Jerry Greenberg
Jerry Greenberg
