Question about Tomtom GO GPS Receiver
Does not show max speed allowed it is 6mths old
It only started this the last 3weeks also is slow picking up side roads
  • 74 Answers
I have found that the maximum speed is not known for all roads so only the speed is displayed.
Where the max speed is known for a particular road it should always work for that road. If not then there could a problem with the GPS.
Peter
Posted on Jan 28, 2009
Evinrude 120 vro outboard floods easily on startup , could spark plugs be wrong type
No,check vro fuel pump diaphragm.if primer bulb doesn't get hard when priming is a sign of needle and seat not sealing or a hole in fuel pump diaphragm.
Sep 08, 2013 | Sierra International 18-4310 Marine...
I have AMD Athlon(tm) II P320 Dual-Core Processor. When I try to play a game named Counter Strike Global Offensive it lags too much. My computer config is fine for it exept for the Processor. I seeked in...
Flashing is dangerous and not guaranteed. Check that out.
You are better off upgrading the video card to get the game to play properly.
Results will be better than what you are attempting to do and it will work.
Aug 21, 2017 | HP Computers & Internet
Loss Control while on curves
Slow down everything has limit.
Feb 24, 2013 | 2007 Toyota Corolla
Seems to be stuck in a programcan't change speeds won't incline.have reset numerous times with no luck.
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
Press either incline key and the incline will calibrate automatically
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Press the Stop key once and remove the safety key.
Jun 11, 2010 | RTO Image 15.0R Treadmill Walking Belt
Will not move belt
Press either incline key and the incline will calibrate automatically.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 27, 2010 | Proform 560hr Treadmill Walking Belt
Car shaking and pop nosie from passenger side wheel
Why drive side bearing could be a bad other.balance yes, tie rod could be bad.
Mar 16, 2017 | 1996 Ford Windstar
92 Chevy Suburban Electrical Fuel System
Check fuel flter at fuel pick-up intank (looks like a small wire sock). Remove fuel filter and fitting at fuel rail. Blow out fuel lines w/about 35lbs air press. Ck electrical @ relay - should be 4 connectors - one is key on hot/one is always hot/one is ground and last is hot to fuel pump. Good Luck
May 03, 2009 | 2002 Chevrolet Suburban
Bonneville that sputters with acceleration
my pal jojo had this problem just 3weeks ago and his fix was plugs and wires.hope this helps.
Mar 21, 2009 | 1995 Pontiac Bonneville
1994 olds cutlass 3.4 dohc
have you changed the fuel filter lately a plugged fuel filter will cause this concern
did the power loss start all of a sudden or did you start losing power over time ?
Oct 22, 2008 | 1994 Oldsmobile Cutlass Supreme
Tomtom GO GPS Receiver Logo
112 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
