Question about Sony VAIO Digital Studio PCV-RS410 PC Desktop
Sony Vaio PCV-Rs410, does not go past boot screen, and often goes into BSOD
Recently took off quick boot, and changed a priority load, reaches to loading screen and does not enter BSOD. Default BIOS = BSOD, no matter what I do.
  • Sony Master
  • 7,627 Answers
Have you done any Hardware/Software Updates/Upgrades? Have you tried a System Restore/Recovery? Reseat the Memory mods, Graphic Card, etc. Try to boot to safe mode, Open msconfig, select Normal Startup, reboot. Let us know what the results are.
Posted on Jan 10, 2013
leecom72
  • 4806 Answers
SOURCE: Sony Vaio PCV-RS710G wont start up
one of the files in the system32 directory in the windows folder is corrupt, the files in the system32 folder contains vital files for the boot procedure, try to start the machine in "safe mode" by pressing F8 after the sony boot screen, if it allows you into the operating system you will need to choose "system Restore" take the time back to at least a week before your problems started DO NOT CREATE A RESTORE POINT
Posted on Nov 14, 2008
Drachnem
  • 34 Answers
SOURCE: windows loads then screen goes blank
Press Ctrl+Alt+Delete then when task manager comes up, look under processes, if "explorer.exe" is running end the task.
Next, go to File>run and run "explorer.exe". This should bring up your desktop and icons.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_b78b4251cd160cd2
Posted on Jan 20, 2009
gabndan2
  • 35 Answers
SOURCE: sony vaio pcv-rs510 fails to fully boot
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
Posted on May 31, 2009
sandro_monte
  • 72 Answers
SOURCE: Sony vaio PCV-RS720G starts and runs just fine but
there is a software you installed in your system that might mislead some dll to function restart. try to removed some recent software you installed, do it at once. but first try to update your antivirus and scan the system.
Posted on Oct 10, 2009
nellis003
  • 5 Answers
SOURCE: Sony VAIO PCV-RS410 memory maxed @ 1G. Can I
You could, but to be honest you're probably going to spend more money and time than it's worth.
If you're having speed issues, one possible solution is to clear space off your hard drive and run defragmentation. Your hard drive should never be over 80% of its capacity; otherwise the system can't run at peak efficiency.
If the PC still isn't running to your liking, then I'd recommend shopping for a new one.
Posted on Mar 08, 2010
Vaio pcv-rs410 won't boot from usb
Have you changed the boot order in your bios? Many USB Keys are actually formatted as USB HDD or USB DVD. If you do have the USB device as 1st boot option ensure that the format is FAT32 and the software installed correctly (grub loader or windows boot image). Many sites such as Major Geeks will offer Optical Disc->USB boot conversion tools which make this a much easier process.
Dec 24, 2013 | Sony VAIO Digital Studio PCV-RS410 PC...
Sony VAIO VGN-FE570G PC Notebook bsod
Remove ALL media, DVD,CD,USB, Unplug, remove battery, plug in, reboot, Can you boot to Safe Mode? Try this in Safe Mode, or boot to Command Prompt: http://support.microsoft.com/kb/929833 Have you done ANY updates recently? Do you have a aggressive Registry Cleaner? take a look at this forum: http://answers.yahoo.com/question/index?qid=20090816162923AAJ3zvP OR this: http://answers.yahoo.com/question/index?qid=20060925192656AAl2M7O
Mar 08, 2013 | Sony VAIO VGN-FE570G Notebook
I cant get my sony desktop to boot up
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
http://net2go.blogspot.com/
Feb 16, 2011 | Sony VAIO Digital Studio PCV-RS410 PC...
My sony computerPCV-RS410 used hitachi hard dr.HDS22512VLAT20 tried to run the discovery disk.after start up disk disk one is working,but in 2'nd disk it coming only up to 22% then stop.How can I make...
You can try getting another set of recovery discs from Sony. Also try resetting the bios. then running the recovery discs again. You can access bios by pressing F2 repeatedly right after you turn on the computer. Then on bottom of screen it will say you could press F5 or another button to load default values. Do that then save and exit. If this does not work. See if you can get a regular windows xp disc and try reinstalling just a normal copy of windows on to the pc. It may not have all the VAIO utilities. But most of them are not needed.
Oct 11, 2010 | Sony VAIO Digital Studio PCV-RS410 PC...
Sony VAIO PCV-RS410 memory maxed @ 1G. Can I install different motherboard with more memory?
Mar 06, 2010 | Sony VAIO Digital Studio PCV-RS410 PC...
Where can I get a new DVD Cd for my sony pcv-v200g.
Hello
please check first the bios settings check the boot priority select the 1st boot priority to cd or dvd rom then exit and save while inserted the bootable cd..
Angel
Thanks..
Aug 02, 2009 | Sony VAIO PCV-V200G PC Desktop
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
Sony VAIO Digital Studio PCV-RS410 PC Desktop Logo
74 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
