Question about Kocaso 7" Capacitive Touchscreen Tablet Android 4.0
Need driver and firmware for kocaso M750b
Won't go past the android screen
Kocaso M760 stuck on android screen
Try Restarting Your phone....(removing your battery).
otherwise it is a software problem & re-installing is the only solution.
Mar 05, 2014 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Froze on black screen that says android have tried holding down power and volume still froze
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Support Troubleshooting Guide
Feb 23, 2014 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
When starting up, my tablet won't get past the screen that says ANDROID.
Holding down the power button for ten seconds resets the device. After resetting two or three times, be patient because it will definitely load on the third time.
Oct 22, 2013 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Android tablet m750b KOCASO problems loading
Turn it off completely. Either by reset or shutdown.
Leave it off.
plug in charger and leave it alone for 4 hours.
Power it back on.
Jun 03, 2013 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Kocaso m750b too many attemepts
The web site at http://mymidpad.com/firmware/files/ has the firmware for the Kocaso M750 as well as many other of their models. You can also call them. Their toll free number is 1-866-777-0079. Hope this helps!
Feb 15, 2013 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Download firmware for m750b tablet
Be aware you need a working tablet to update. the program must be in working order and the processor must run. Once you start the upgrade, there is only a small routine running, to put the new program in the right place in the Flash memory. You don't get a second chance, if anything goes wrong, because even the routine to update can't be put in place or run.
An update is NEVER a solution for a bricked tablet.
Please check some forums what to do with your problem, but please don't brick the device with an update you can't get in place.
Dec 28, 2012 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Kocaso 7" Capacitive Touchscreen Tablet Android 4.0 Logo
139 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
