Question about 2wire 2700HG-B Router (2700HGB)
I have a two wire router trying to hook up to run my laptop
Dsl comes into my vonage phoneline box then out to my desktop computer,i dont know how to hook it up the right way.can you help?thanks. router is a 1701hg gateway wireless.
    Scholar:
  • 140 Answers
You need to run from the DSL modem into the ethernet port at the very top of the 1701hg. Use your other 4 ports below to send one the computer and one to your vonage. You will no longer need to "jump" though your vontage unit. Other than connecting the power cables, you are all hooked up.
Posted on Jan 21, 2009
My desktop has a local area connection with limited to no connectivity. I had my desktop pc connected to a netgear n900 router and a vonage phone connected to the router's lan1 port. This caused i
Did this connection ever work before? I have a similar setup with Iristel and once in a while it goes down (Hurricane Leslie generated the problem last week).
Check whether the setup works without the Vonage device. This will tell you whether the problem is with your router or the Vonage box. If it works without the Vonage, the problem is in the Vonage box, you may find a good time to call Vonage for support.
I don't know whether the Vonage box (in my Iristel case it's a mediatrix 2 something) has to 'call home' before it lets your router set itself up.
If your router does not work without the Vonage, you have a simpler problem, the router is the issue. You can reconnect the Vonage and if the phones work, this confirms that the router is the problem. At least you can use the phones.
With the router, you need to log in to the admin screens and poke around until you find the problem. It is always a good idea to only change one thing at a time and always remember what changed immediately before the problem was noticed.
Sep 16, 2012 | Gateway Computers & Internet
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Vonage told me to install my D-Link router between the vonage adapter and the computer and I don't know how or which wires go into which ports.
First of all: it would be good to know which vonage device you are using. This would help to be more specific.
But anyways:
  1. Connect a normal Ethernet cable form your DSL or Cable modem to the Internet (or WAN) port of your vonage router.
  2. Then connect another Ethernet cable from one of the LAN ports of the vonage device to the Internet (or WAN) port of you D-Link (The one that is separated from the 4 LAN ports.)
  3. Make sure that the D-Link is set to DHCP (Dynamic IP Address), so it can get it's IP address from the vonage router. (Look at page 14 of your manual. If you don't have one, you can get it here.)
  4. Connect your computer to one of the LAN ports on the D-Link.
If you have any more questions or this desciption is not clear to you, just come back here and leave a comment - I'm happy to help.
May 18, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Hi! I use bellsouth dsl on my Medion desktop. Got a small Acer notebook id ike to add to the dsl network but - do not know how to do it. Can two wires (cables) run from one modem to both computrs? Can iT...
You will need to connect a router to the Westell in order to use more than one computer with your dsl. That modem will need to be put in bridge mode in order to allow it to work with the router.
Call ATT/Bellsouth support and tell them you need to setup your modem for bridge mode and connect your Linksys router.
Mar 15, 2009 | Computers & Internet
Trouble with paradyne or linksys
Just saw your post, so please accept my apologies for being almost a month late in responding, as I only joined this service on March 26th.
1. When a modem has both usb and ethernet, only ONE of the two should be used as most isp modems will allow one or the other.
2. Your Vonage should be discreet and not intermingled with the rest of your system. It would be better to connect the Vonage to a router, and not the router to the Vonage. iow, do not connect the Vonage modem between the isp's modem and your router.
3. denigration of service or slowdown is typical with VOIP if more than 2 systems whether telephone or other systems are connected, due to the ringer voltage splitting that occurs when you put more units on the Vonage, or any other Voip modem. One ISP solves this by providing separate outputs for Voip and Ethernet.
Observation of these rules should speed up your system.
Mar 01, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
Trying to hook up a Linksys Wireless -G 2.4ghz Broadband Router. Want to link my dsl and my xbox and then later down the road a lap top. Dont know where to begin. Do I take the phone line thats inthe wall...
first you connect the wire from the wall into the wan port in the back of your dsl modem. next you connect the outsource wire from your dsl modem into the wan port on your router. next put another rj45 wire into the number one port in the back of your router and the other to your computer. put another wire into number 2 and then to your xbox. everything need to be unplugged while you are hooking it up. once done power cycle...meaning plug up the dsl and wait for the lights to stay lit. then the router. the start your computer. if you want to go wireless just get a usb wireless network adaptor and there you are
Oct 19, 2008 | Computers & Internet
Hooking up Vonage to Time Warner Roadrunner(dsl): Do I have to buy a Linksys Wireless device for my Vonage to work?
You just need a router. and then plug the vonage device onto the router.
Note: make sure you have internet with the router before pluggin the vonage device to it.
Aug 15, 2008 | Linksys Wireless-G Broadband Router
No internet connection on my laptops
Please understand as I get very basic to start but things very obvious to you I cannot see.
Generally when including a router in a home network starting from the cable (tv) or the phone socket (dsl) in the wall with a phone wire plugged in. The next box is generally provided by your internet service provider and is a modem/something that connects to the phone line or cable. Then sometimes when only one computer exists computers are directly connected to the modem with an ethernet cable (looks like a fat phone wire with oversize connectors) or a USB cable (small flat retangular ends).
When you want to add a router for multiple computers. The computer gets disconnected. If a USB cable was used it is often replaced with an ethernet cable and that cable connects to the WAN port (probably separate from a block of 4 lan ports) of the router you bought (tell me if you have two routers -- that is a different problem). If your service comes from a cable (tv) company your router may already be properly configured. If however you have DSL service from the phone company the chances your router is correctly configured are less. To finish with the cabling story -- your computer then hooks to one of probably 4 LAN ports all in a block. Now if you are lucky power on all devices and boot up your computer and see if you have internet access. If you do great if not please provide me the name of your internet service provider or a link to their help/support website and I will see what I can do to assist in completing the router setup. Until your wired computer gets access to the internet your girls wireless connections will not work either. Once we get the wired connection working we will address the wireless connections.
If necessary unplug the router and plug the computer back into the original cable until we get the router working.
Dec 26, 2007 | Linksys Wireless-G WRT54G Router
2wire 2700HG-B Router (2700HGB) Logo
138 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
