There is a red shadow around the objects on the outside parts of the toshiba projection screen tv . Looks like the very middle is fine though . When tv first gets turned on it works fine then after 10
    Genius:
  • 1,669 Answers
It sounds like the projector lens is getting hot and warping. Check to see if the cooling fan, openings, or dust collecting is inhibiting air flow. Also make sure you do not put stuff on top or close to the sides of the case!
Posted on Jan 10, 2013
SOURCE: tv repair
My aquos plat screen tv was pushed over by my three year old. The screen is damaged but everything esle works. Is this problem fixable?
thank you
Posted on Nov 24, 2008
SOURCE: dark shadow on lcd tv
u need to replace the tv backlight. it can be done by urself but its kinda complicated its better to just tak eit in to a repair man. shouldnt be that costly.
Posted on Jun 13, 2009
  • 15 Answers
SOURCE: sony bravia tv screen broken
you might can find a tv repair person that needs the parts or has one with a good screen but bad electronics....sorry you need a new tv.....
Posted on Sep 20, 2009
milkburp
  • 416 Answers
SOURCE: Plasma tv was working fine, but when I turned it
Does your picture look really, really, dark? If so, your Z-SUS board (right side with the back cover off, attached to the panel by wide copper ribbons) has failed. You can simply replace the board and be on your way. You should use the PN found on the part (white sticker with a 2D barcode). It will look something like this: 6871QZH033A
Posted on Mar 15, 2010
SOURCE: Hitachi LCD TV, Problem with the image
I am having the same problem with my 50v500 as well. Please let me know if you find a solution.
Posted on Apr 25, 2010
I have a tz61v61 toshiba rear projection. The bottom half of the screeen is ghosting red, blue and green. it looks like 3d without the glasses. top half of screen is fine.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 24, 2011 | Toshiba TZ61V61 61" Rear Projection...
The picture on my set looks like the blue bulb casts a shadow that extending down from the top of the screen in horizontal arc through the middle of the screen. I took the magnifying lens off and looked...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Oct 15, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Toshiba rear projection tv has red and blue on the tv
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 24, 2010 | Toshiba 42H81 42" Rear Projection...
Yellow circle in the middle of the screen. It has
Not sure if this will help...
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 06, 2010 | Toshiba 42H83 42" Rear Projection...
Green and purple shadows in the left upper corner
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Mar 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
NEED TOSHIBA TN43V71 CONVERGENCE CIRCUIT PART NUMBER
Projection TV2_bing.gif sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Mar 04, 2010 | Toshiba TN43V71 43" Rear Projection...
Green wavy images on the screen? Convergence is fine but there is a warped green image of everything on the screen.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Sep 27, 2009 | Toshiba 65H82 65" Rear Projection...
Sony 43 inch rear projection tv, I have lined up the convergence but still seeing red and green around edge of the tv on the images, seems fine in the middle of the screen though.
Always start at the vary center of the screen with Green. Position Red over Green, then Blue over what now will look yellow. If all is perfect except the outside, you will need to adjust "Mid-Size" until the middle is just as far off as the outside lines. Then adjust the main "Size" adustments to match. Go very slow or you can make a mess of it.
Mar 06, 2009 | Sony KP-51HW40 51" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Picture problem Model Toshiba 61H71
Hi, convergence circuit has failed, IC`s and probably 1 or 2 precision resistors will have to be changed, not really something you can fix if your not an electronics tech, BMW Rider
Jan 09, 2008 | Toshiba 61H71 61" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
