Question about Vacuums
My Hoover s5620 central vacuum is not sucking. I cleaned out the canister and vacuumed the inside bag in the canister. The hose is clear as is the central vacuums tubing. Any suggestions ?
    Genius:
  • Vacuums Master
  • 1,669 Answers
Try getting some compressed air source and blow back whatever is stuck in the hose.
Posted on Jan 10, 2013
Hoover not sucking
Remove all filters and try the suction on your hand, NOT THE FLOOR!
Filters are vital to keeping the motor working.
Most vacuum sucking probs are a result of a clogged filter or filters. Sometimes, hoses also. Or a full bag.
Remove all filters, clean them thoroughly, check hose for obstruction.
Use another vacuum to remove dust/dirt (or an air compressor) from the dirty filters.
That's first step.
Feb 26, 2015 | Hoover Vacuums
How do I unclog the vacuum? The canisters are clean but the bottom has no suction.
Hi, it's Allie from Crucial Vacuum!
There are a few potential solutions you should try. Start by checking your unit's brushroll and clear it of any tangled hair strands or debris that my be blocking the airway. Follow by checking the internal hose for any blockages.
If the unit's suction is still not normal, the problem could be related to your filtered bag. Bags should be changed frequently and should not be left unchanged and half way filled for a long period inside your unit.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/hoover-elite-rewind-belt.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 14, 2014 | Hoover Soft Light Supreme U4262-930 Bagged...
Miele not sucking
1. Check if the bag is full. Yes. Change bag.
2. Check the head. Clean head.
3. Object stuck in the hose. remove hose from the vacuum. Remove extensions from the Head end. Poke garden hose down the hose from the handle end.
4. If all else fails. Read the destructions.
Jul 05, 2014 | Miele S318 Bagged Canister Vacuum
It is not cleaning the dust properly. it make too much noise.
It would help if you gave us more detail. What type of vacuum. Does it have a long hose and then terminate in wand and power vacuum head with a beater bar brush arrangement? If so, did you check your hose for obstructions? Disconnect the hose from the wand to see if it is sucking air. Do the same at the canister, disconnect the hose and see if it pulls air at the canister. I assume that you replaced the bag from inside the vacuum and cleaned up any dirt that may have accumulated inside the compartment where the bag goes. Or is this a bagless type vacuum.
It would be best if you give us the make, model number and a descrption of the vacuum.
Jul 31, 2011 | Vacuums
If my system is stopped up will it make a noise inside when i plug in my hose it makes one out side at canister but not at my wall hose
Yes. A clog will cause the motor to work harder resulting in a higher pitch. To prevent the motor from burning out the clog needs cleared ASAP.
This could be something as simple as cleaning the filter, but it could also be a blockage in the hose. This will be more difficult to clear, but if you can attach the handle end of the hose to the vacuum and turn it on, it may clear it. If not, you'll probably need to take it to a repair shop.
Jan 13, 2011 | Broan-NuTone VX475 Bagged Central System...
How do i fit the hoover bag
If you remove the top of the vacuum via the clips on the side you will see the empty bucket. Where the hose connects is where you will fit the bag from the inside. On the bag you will see a hole with cardboard around, this will then push over the outlet.
Apr 08, 2010 | Henry Numatic "" Canister Vacuum
I sucked up some toilet paper in my central vac, and not it has almost no suction. How do I remove the block?
Toilet paper shouldn't clog a central vacuum system. There was probably already something in there that caught the toilet paper and made it worse. Here is a good resource that might help:
How to unclog a central vacuum system
Nov 06, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
My henry hoover has stopped sucking
screw the pipe off and clean with cold water.
check dust bag or change,
check that nothing is abstructing the suckstion from the head & neck. of your hover,
Oct 29, 2009 | Numatic Henry Bagged Canister Vacuum
Troubleshoot a problem with central vac - not in the vac hose
The only thing you can use really is a plumbers snake.
Not sure if thats what its called in the States. Its a long flexible metal spiral spring that plumbers use to clear blocked drains
Rob in the UK
Mar 07, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
Kenmore Cannister Vacuum Model 26312
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=109396&thid=552260
Kenmore Canister Vacuum Model 26312
Posted by Alecia Rojas on Apr 28, 2008
Kenmore 23612 Progressive PowerMate Canister Vacuum
Vacuum is not sucking. It is just over a year old.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds like you have a clogged hose or a full bag, or dirty filter. The best way to check your electric hose id to run a marble or steel ball thru the hose and if it goes thru all the way then check the bag and filter, most times it is the vacuum hose. If it id the hose you can try to pull apart the clog from both ends using another central or canister vacuum. If not and the ball stops mid way thru the hose then you can use a broom handle with a round hook on the end so that it does not puncture the hose is any place and the round hook can loosen or break up your clog and then your suction will return, if you poke a hole in the vacuum hose there are repair kits that go on the outside of the hose that will slide over the hose and then you use a heat gun and shrink the hose repair kit down to size therefore plugging the leak. (Hose repair kit). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuums Logo
64 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
