Question about Samsung DV419AEW 7.4 Cu. Ft. Electric Steam Front Load Dryer - White
Samsung steam dryer VRT DV419AEW stopped spinning/lights come on
We heard a "clicking" noise when the dryer was in cycle drying a load- so my BF went to see what was going on , stopped the cycle and turned the drum when he heard a loud noise. The lights power on but the drum will not turn and nothing else comes on. Only the lights come on with the cycle minutes left in the cycle we were running. He suspects the belt came off? Could there be something more serious? Our problem is moving the unit to even get to the backside (in a very tight space). Thank you very very much
  • josiepk Jan 12, 2013
    Hi Hunter19, thank you for the details! are you describing my exact samsung model in your description? or is it a general?
  • josiepk Feb 03, 2013
    We fixed our dryer!! so happy!! First We ordered the dryer belt with part # Samsung Dryer Belt 66002-001655. I got it off Amazon at a good price $11-13 athttp://www.amazon.com/gp/product/B001KGX... THANK GOD we ordered it just in case because it turned out the belt had NOT slipped off but was SHREDDED apart. The BEST ADVICE to this particular model Samsung VRT steam dryer DV419AEW came from a commenter to another thread . Follow this thread if you have Samsung VRT steam dryer with model # DV419AEW= this threadhttp://www.fixya.com/support/t1210394-sa... The comment at the BOTTOM of the reply made by "dumb-stump". He describes how you take apart this particlar model. I also watched the youtube video on belt placementhttp://www.youtube.com/watch?v=obaoSDbzY... This shows how to place on pulleys etc once you get belt around the drum.
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I was drying and heard a kind of banging pop noise
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Posted on Jan 04, 2011
Macmarkus
  • 2605 Answers
SOURCE: the drum stopped spinning on
Welcome to FixYa.
Yes it does have a belt. I'd say your assessment is almost bang on, based on your description and my experience. I've seen this many, many times...though the belt usually doesn't break it just comes off. Very common for Samsung dryers for whatever reason.
**Unplug the unit before proceeding...safety first**...
The good news is if it's accessible from the back you can simply remove the small panel around the exhaust tube as shown here,
if it's not you'll need to go from the front...do-able just a little more involved, let me know.
Once in the back the belt should look like this when routed properly, with the "V" grooves towards the drum and motor pulley.
i.e.
Hope that moves you forward...or even better, to the finish line, lol.
Let me know what you find. If this is something you think is not within' your scope of expertise please call a pro.
I will try to help in any manner I can of course as well. Good luck.
Regards,
Macmarkus :)
Posted on Mar 28, 2011
Macmarkus
  • 2605 Answers
SOURCE: Put full load of wet in, had set for heavy dry,
Hello Scott,
Welcome to FixYa.
Based on your description and my experience, I'd say possibly the belt has come off,( hence the big "thud" ) thus activating the "kill switch".
The good news is if you can get to it from the back you can simply remove the small panel around the exhaust tube as shown here,
if it's not accessible from back you'll need to go from the front...that's do-able too, just a little more involved. Let me know.
i.e.
Hope that moves you forward...or even better, fixed up.
Regards,
Macmarkus :)
Posted on Apr 03, 2011
SOURCE: Samsung front load dryer will turn on but not
I was cleaning mine and doing the same thing last night. Washed a load of clothes tonight and went to dry them and everything works on it except it won't spin or heat. Heard the same type of popping noise last night cleaning it out. Have you found any solutions? Mine is just over a year old. I did some reading and thing that the dryer belt came off its assembly possibly. Have you found a solution?
Posted on Apr 14, 2011
Samsung Steam Dryer has power but only displays a flashing smiling person. The dial will not turn and will not start cycle??
Maybe you press lock button, simply unlock it again try this one
? What is the "Child Lock" function?
• If you press the "Child Lock" button (Spin+Option button) longer than 2 sec during operation, this
function is selected.
• If once this function is selected, no change can be done until the end of laundry.
• Press the "Child Lock" button (Spin+Option button) longer than 2 sec to cancel the function
Jan 19, 2015 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
Dryer makes a thumping noise even when no clothes are in the drum
check the drum glides and the felt for worn out areas. then check the roller wheels or pully. tensioner ect
Aug 25, 2014 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Model dv209aewxaa timer counts down but nothing else is runing
Belt came off?? see We fixed our dryer!! so happy!! First We ordered the dryer belt with part # Samsung Dryer Belt 66002-001655. I got it off Amazon at a good price $11-13 at http://www.amazon.com/gp/product/B001KGX...THANK GOD we ordered it just in case because it turned out the belt had NOT slipped off but was SHREDDED apart. The BEST ADVICE to this particular model Samsung VRT steam dryer DV419AEW came from a commenter to another thread . Follow this thread if you have Samsung VRT steam dryer with model # DV419AEW= this threadhttp://www.fixya.com/support/t1210394-sa... The comment at the BOTTOM of the reply made by "dumb-stump". He describes how you take apart this particlar model. I also watched the youtube video on belt placement http://www.youtube.com/watch?v=obaoSDbzY... This shows how to place on pulleys etc once you get belt around the drum.
Jan 29, 2013 | Samsung Dryers
Samsung dv210 will not turn
Belt come off/damaged? Same thing happened to us and the clicking noise was our shredded belt flapping around hitting the drum. see : We fixed our dryer!! so happy!! First We ordered the dryer belt with part # Samsung Dryer Belt 66002-001655. I got it off Amazon at a good price $11-13 at http://www.amazon.com/gp/product/B001KGX...THANK GOD we ordered it just in case because it turned out the belt had NOT slipped off but was SHREDDED apart. The BEST ADVICE to this particular model Samsung VRT steam dryer DV419AEW came from a commenter to another thread . Follow this thread if you have Samsung VRT steam dryer with model # DV419AEW= this threadhttp://www.fixya.com/support/t1210394-sa... The comment at the BOTTOM of the reply made by "dumb-stump". He describes how you take apart this particlar model. I also watched the youtube video on belt placement http://www.youtube.com/watch?v=obaoSDbzY... This shows how to place on pulleys etc once you get belt around the drum.
Jan 20, 2013 | Samsung 7.3 Cu. Ft. Electric Dryer
Samsung WF231ANW VRT Loud and aggressive spinning, banging against the wall
You have to make sure the load size is the exact match to what size your load is.
Aug 22, 2012 | Samsung WF231ANW 3.5 cu. ft. High...
Samsung front load dryer will turn on but not spinning or drying. I was wiping it out and turning the drum I heard a snap sound.
Jan 10, 2011 | Samsung Dryers
Samsung DV419AEW 7.4 Cu. Ft. Electric Steam Front Load Dryer - White Logo
398 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
