Question about Goulds Pumps Goulds J15 - Convertible Jet Pump
My goulds pump J15 does not engage - Goulds Pumps Goulds J15 - Convertible Jet Pump
  • 3,287 Answers
These pumps can be wired to operate on either 115 or 230 volts. This shouldn't be an issue if it was previously working. If a new installation, make sure it isn't be connected for 230 volt operation and supplied with 115 volts - and of course; vice versa. Correct improper wiring before continuing. It is very possible that the motor has catastrophically failed due to incorrect voltage being supplied - hopefully this isn't the case.
Check and replace / reset any open fuses / tripped circuit breakers. and try again.
These pumps are often operated automatically via pressure switch. If the correct power is available to the pump it may be a problem with the pressure switch. There are many different types of pressure switches so it will be difficult to go beyond what I have told you already. You might want to see if you can locate a pressure adjustment screw and try varying it to see if it has been set too low to allow the pump to come on.
If no luck, tell me what the application for the pump is (point well pump, etc.) and what controls the pump (pressure switch, etc.). Provide the make and model of the control device and any visible settings. Do not remove any covers unless the power is first shut off.
I hope this helps & good luck!
Posted on Jan 10, 2013
Wire diagram 4 gould gt20
Wiring diagrams for pump motors are usually on the inside of the cover of the wire access cover or on the motor tag. If this is a 1/2 HP motor it could possibly be wired 125V or 250V. Be sure to wire for correct voltage.
Nov 06, 2014 | Goulds Pumps GOULDS GT20...
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Why does my goulds pump j5s draw water to the pump but it won't pump out, what could be wrong and can it be repaired?
you will have to prime the pump after working on the lines. You can get just the pump section but I doubt that there is much wrong other than priming the pump
Aug 05, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Why goulds septic pump buzzing
check for foreign objects jamming the impeller. have the motor tested for failure.
Jun 07, 2014 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
Pump doesn't reach pressure
Either it has an open outlet so there is nothing to pump against, a blocked inlet so there is nothing to pump or a bad impeller.
Aug 23, 2012 | Goulds Pumps Goulds Centrifugal Pump,...
I have a 1/3hp goulds pump not working i have changed the capacitor and the centrifugal switch but it still does not work; does not come on what must i look at next.
Check the continuity of the service wires. If they are good, check the resistance of the windings. You may have an open motor windings.
Jun 08, 2009 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Goulds Pumps Goulds J15 - Convertible Jet Pump Logo
204 people viewed this question
Top Goulds Pumps Plumbing Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
ray gallant
Are you a Goulds Pumps Plumbing Expert? Answer questions, earn points and help others
