Question about Road Mice 2002 Ford Mustang V6 RM-08FDMGKXA 2011 Mustang GT Wireless C
2002 mustang orifice tube location please - Road Mice 2002 Ford Mustang V6 RM-08FDMGKXA 2011 Mustang GT Wireless C
Orifice tube location on a 2002 chrysler 300m
2002 Chrysler 300 has an expansion valve instead of an orifice tube which is used to meter the flow of refridgerant. It is located on the firewall attached to the AC manifold hose assembly 4e13a00d-e237-447d-9c7e-ef4684c71d0b.jpg 452a74e8-1d11-479f-9e19-3d118dc43633.jpg
#10 is expansion valve and #3 is the hose assembly..follow AC hoses from compressor to the firewall and it will take you to the expansion valve
Jul 13, 2014 | Cars & Trucks
Can the orifice tube on a 2002 mustang be repaired with kit
You do not cut & splice into any A/C System
You replace with the oe type parts only when
they fail/leak
The orifice is a screen inside the hose connection
& can be cleaned,not necessary to always replace
Jan 09, 2013 | Cars & Trucks
Where is the orifice tube located on a 2002 chevy cavalier?
The orifice tube is located inside the tubing leading to the evaporator -- this picture will probably help.
Feb 10, 2012 | 2002 Chevrolet Cavalier Coupe
We are trying to either get a diagram for an 2002 chevy impalas ac system,or the location of the orifice tube.please help.
It is located inside the condensor tube running to the evaporator.
Here are the removal/installation instructions as per alldata:
TOOLS REQUIRED
J 39400-A Halogen Leak Detector
J 26549-E Orifice Tube Remover
REMOVAL PROCEDURE
-Recover the refrigerant. Refer to Refrigerant Recovery and Recharging.
-Remove the air cleaner assembly.
-Remove the vacuum brake booster.
-Remove the condenser tube.
-Use J 26549-E in order to remove the expansion orifice tube. IMPORTANT: DO NOT use any solvents or chemicals to clean the porous plastic inlet filter of the expansion orifice tube.
-Inspect the expansion orifice tube for the following conditions and clean or replace with a new tube as indicated:
-Broken plastic frame (1); replace the tube.
Inlet filter (3) damaged or plugged with fine gritty material; replace the tube.
Inlet filter (3) coated with metal chips, flakes, or slivers; remove the coating with low pressure shop air ONLY and reuse if the filter is cleaned satisfactorily. Do NOT reuse the O-ring seals (2).
INSTALLATION PROCEDURE
IMPORTANT: Lubricate the new O-ring seals (2) with mineral base 525 viscosity refrigerant oil.
If you reuse the orifice tube, install new O-ring seals (2).
Carefully grasp the edge of the expansion orifice tube (1) without touching the inlet filter (3) and insert the expansion tube into the condenser tube until fully seated.
-Install the condenser tube.
-Install the vacuum brake booster.
-Install the air cleaner assembly.
-Evacuate and recharge the A/C system. Refer to Refrigerant Recovery and Recharging.
-Leak test the fittings of the component using J 39400-A.
Aug 20, 2010 | 2002 Chevrolet Impala
2002 ford mustang ac will not come on. Problem is intermittent. I have checked the low and high pressure switches and fuses. what else is there to check?
When the ac acts up,test voltage at the ac clutch,if there is voltage(12 volts to 14)then the clutch is the problem,also,try and wiggle the low pressure switch ,to see if it tries to come back on,,,have some one put some ac gauges on the ac system and let the ac run,and watch to see if the low side falls down to 25 psi or lower,if it does,then the orifice tube is stopping up.If this was at all helpful,please rate,thank you.
Jul 19, 2010 | 2002 Ford Mustang
Orifice tube 1998 mustang
did you find the location? Let me know one way or another so if I can help anymore ,I will
Jun 04, 2010 | 1998 Ford Mustang
How do I change the orifice tube on a 1998 Ford Mustang base model?
THE SMALLER LINE GOES TO THE EVAPORATOR, i HAVE CHECKED WITH MY FRIEND AT FORD ON THIS PROBLEM AND HE SAID U HAVE TO REPLACE THE SMALLER AC LINE (HI PRESSURE LINE, THE ORIFICE TUBE IS PART OF THE HIGH PRESSURE LINE, HERE IS THE PART NUMBER FROM A SITE CALLED ROCKAUTO.COM
MOTORCRAFT Part # YF2227 {#F6ZH19N651AD, F6ZZ19835A}
factory installed AC High pressure refridgerant line.
Location of orifice tube,2002 ford taurus sel
location of orifice tube/2002 taurus
May 14, 2010 | 2002 Ford Taurus
2002 Ford Expedition Eddie Bauer 5.4l Dual A/C Are there 2 orifice tubes in the split unit? Where are they located? Is there a diagram available showing the tubes in the system?
There is one orifice tube for the font air. It is located in the a/c line coming from the condenser to the evap. core. the rear a/c has and expansion valve attached to the rear evap. core. Hope this helps.
Oct 07, 2009 | 2002 Ford Expedition
Where is the orifice tube in a 1994 mustang
The A/C evaporator core orifice is located in the condenser to evaporator tube
Oct 07, 2009 | 1994 Ford Mustang
Road Mice 2002 Ford Mustang V6 RM-08FDMGKXA 2011 Mustang GT Wireless C Logo
Top Road Mice Computers & Internet Experts
sonofspy
Level 1 Expert
Bill Boyd
John Mangan
John Mangan
Are you a Road Mice Computer and Internet Expert? Answer questions, earn points and help others
