I would guess that GM didn't hook these wires up to the factory stereo, as the factory stereo may not have the front back fade feature. They put the wires in to save you time if you decide to put another stereo in. Look under the dash, you will probably see the other end there. I'm not sure about this. Just a guess, but my tractor trailer is set up that way, and I only have 2 speakers, but wires are run to all possible speaker sites. Good luck.
SOURCE: 1998 Audi A4 Quattro rear speaker wiring
You can't use any of those - the large connector at the OEM speakers is because the rears are amplified. Your factory head unit puts out a line level signal to the rear speakers. There's an amplifier on the driver's side rear speaker (the box around the magnet that you can see from inside the trunk).
You need to either replace the head unit with an aftermarket one to drive your new speakers, or you need to tap into the amp connector and find the line level wires, break them out, put RCA plugs onto them, and plug them into an aftermarket amp, which you'd use to power your rear speakers. Doing it that way allows you to keep the factory head unit.
SOURCE: puttin new speakers i dont know what color the stock speaker wires are
2002 Chevrolet S10 Pickup Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Dark Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Violet/White
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
SOURCE: factory radio wiring color codes
Here ya go. enjoy!
2002 GMC Sierra C1500 Car Radio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Location: Under the center console.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
SOURCE: replace door speaker 2001 gmc sierra
pull your door panel off and unscrew the speaker and disconnect the connectors to speaker
SOURCE: my wiring plug to the back of the radio was cut on my 1990 4runne
fun fun fun.
1990 Toyota 4Runner Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Yellow or Blue/Black
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
