Question about Roper RTW4300SQ Top Load Washer
My roper top load washer model RTW4300SQ is draining but not spinning.
When I manually turn the shaft it is spinning. Since it all appears to be off the same motor shaft, I'm struggling to understand. Additionally, when on the spin and drain setting, it's making a very load noise that sounds like a motor not working properly. To be very clear, it's not the bumping,etc.... type noises. The fact that it is draining is what's confusing me. I'm also trying to verif what OHM readings should be.
  • vince Jan 21, 2018
    ck for parts here,,https://www.repairclinic.com/RepairHelp/...
    not your model enter the correct one in search area
  • 807 Answers
Sounds like a bad timer contactor, Rotary cycle switch is bad.
Posted on Jun 15, 2017
4 Suggested Answers
  • 1073 Answers
SOURCE: Roper Washer RTW4300SQ
if the drive coupling is ok then the transmission is the problem verify for sure that the coupling is good
Posted on Apr 19, 2008
SOURCE: everything works-no spin-motor sounds like it won't engage
Machine will not spin but just makes a grinding sound instead.
Posted on Jun 27, 2009
oldTech2332
  • 2341 Answers
SOURCE: Hello Everyone, I have a Roper
that sounds like you have done all you can and i appriciate a well written question stating exactly what you have already done(some times questions here is "it dont work") so then back to your washer. There are 2 more possiblities
1) the motor capiciator is bad and not giving the motor a bump in power to start it. To check that,its black and round and going to be on inside right side of back panel.To check it use a meter set to HIGH ohms rating.place one meter lead on each of the 2 terminals (each terminal may have 2 wires but only 2 two terminals) and the needle should swing up and drop back if cap. is good and the needle will stay at or near zero if cap. bad. If using digital meter the numbers will constiantly be in motion jumping from 10 thousand to 200 back to 5 thou. and so forth if cap is good and again the display will stay the same and never change if capiciator is bad
If capiciator checks good the motor is going to be the problem
Good luck,i have i have been able to help you fix your washer,
Gene
Posted on Aug 18, 2011
Roper washer rtw430sq will not agitate, spin or drain only makes a humming noise>
this unit has what is called a drive coupling under unit... if you gain access to underside of unit,,
you will see it between the transmission and motor assembly... it has two plastic pieces and a rubber piece between them each piece has three teeth that interlock intothe rubber piece...alot of times these break and that is what runs the unit... the motor turns and turns the transmission check this piece.... inexpensive part....hope this helps
Jan 21, 2011 | Roper RTW4300SQ Top Load Washer
Roper washer water flow is good but will not fill up washer. Water will just keep running.
Drain hose too low to ground. Must be 30 inches or more above floor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 05, 2011 | Roper RTW4300SQ Top Load Washer
I am trying to pull pump off of washer and it will not come off, the washing machine will not spin so this is why i'm pulling the pump off, what do i need to do
If the pump has been slowly leaking it will be stuck to the motor shaft. I have had to physically break the pump till you get to the shaft of the pump impeller which you have to break . To replace the pump you must clean the motor shaft with a file or sand paper till the pump slides on over the shaft easily.
Nov 17, 2010 | Roper RTW4300SQ Top Load Washer
I have a Roper washer. It filled with water to wash, but when it came to draining the water to rinse, it just stops. It will add water on rinse cycle, but it will not drain or spin.
Sounds like the lidswitch. As a safety, the tub will not spin if the door is up (open). In turn, it will not drain if it wont spin. This is a common problem with whirlpool washers. You can go to searspartsdirect.com to get the breakdown and order the part.
Feb 17, 2010 | Roper RTW4300SQ Top Load Washer
Clothes come out very wet after the spin cycle - even when I spin them 2 or 3 times, still not much better
If the pump can not drain throughly then there is some water at the bottom at the tube causing this problem.
Jan 06, 2010 | Roper RTW4300SQ Top Load Washer
I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Nov 01, 2009 | Roper RTW4300SQ Top Load Washer
Washer quit spinning
Sounds like the lid switch has failed. This switch will not allow the drum to spin if it senses that the door is not locked. Have it replaced and that should take care of the problem. Hope this helps. Good luck.
Jul 23, 2009 | Roper RTW4300SQ Top Load Washer
Apr 18, 2008 | Roper RAS8244KQ Top Load Washer
Roper RTW4300SQ Top Load Washer Logo
93 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
