Question about Video Game Consoles & Games
Halo4 tritons won't let me talk to other people but I can hear them
You can't hear yourself talking in your mic through with the halo 4 trintons, though others should hear you. If this function is not working call the manufacturer. If you want a headset you can hear yourself, buy the turtle beach.
Posted on Jan 10, 2013
P11 wont work
take out it from cpu , clean it and use it , it will start working
Jun 08, 2013 | Radio Communications
My triton t90z has no water coming through
If you hear the pump pumping as normal then it is most likely the solenoid. Try phoning www.dublinshowerrepair.com
0872885385 they'll give free advice and stock Triton and Mira parts
Jan 12, 2013 | Home
I can hear only one side of the sound coming out from Korg triton extream keyboard. It's not the cable problem for sure. i tested both the earphone out put and the Left and right out put. Did a
So you're saying with headphones you also only hear one side? I would suspect the internal amp is panned all to one side. There are also several other settings in this unit where pan can be set so you may have to check several areas. If you don't have any specific custom settings made I would try a restore to factory defaults. If that doesn't resolve it you likely have a hardware failure which is likely not repairable. I strongly suspect a panning issue though.
Aug 18, 2012 | Korg Music
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
When I power up all I get is the Magellan Triton screen. My pc does not recognise the device also
1.Ok, if you have tried the manual update and it won't work then the thing to do is download this file:
http://www.lenwoodcc.org/triton/t500tfat2.zip
To download the file just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
2.And then connect your GPS your computer and start it in the developers mode - which should make it connect to your computer as a USB driver.
To start your GPS in developer mode ,simultaneously press and hold the POWER - LIGHT - UP ARROW buttons as you start the GPS.
Want to get out of this mode, you can reboot the unit by simultaneously pressing and holding the POWER - SELECT - ESC buttons or just take out one of the batteries.
3.Next unzip the T500TFAT2.ZIP file to a directory on your hard drive. Once you have that unzipped go to "My Computer" and access the TFAT directory on your Triton and erase all of the files on it. Then copy all of the files from the T500TFAT2 file that I sent you. Once you have the new files in place then disconnect your Triton from the computer and reboot it and see if it works.
If you need further assistance please feel free to contact me.
Feb 07, 2012 | Magellan Triton 400 Handheld GPS Receiver
Is there a filter in Triton100x
If you talking about the Triton Hot Water on Demand Propane Heater? No there is no water filter. No filter of any type.
Mar 18, 2011 | Heating & Cooling
Magellan gps Triton 300 series Jamed up; Reads when turned on ; Internal Error Your Triton has encountered an unexpected error and must shut down. Please wait while your data is saved.
The problem with your magellan triton is that there is a file missing in the support file that allows the triton come on properly hereby leading it to jam.
The solution is for you to get your triton connected to a computer, then you back up the software on the computer, format the triton then you restore the software and maps on the triton. Then your triton will be in good condition once again.
Hope this information helped.
Jan 03, 2011 | Magellan Triton 300 Handheld GPS Receiver
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
My Ford F150 XLT Triton driver's side power window
window regulator failure. Check window regulator guide for damage. If damage replace!! Hopefully this helps
Jul 20, 2009 | 2004 Ford F150
Video Game Consoles & Games Logo
35 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
