Blue light blinks on frout of tv and sound like a relay switch is clicking
Philips Model 50PL912D/37
    Problem Solver:
  • 11 Answers
Plasma tv z-sus vs supply volt shot, remov z-supply wair then chack it, and replay me
Posted on Jan 10, 2013
Slinteriors
  • 8617 Answers
SOURCE: 4 blinking red lights
From what I am able to find out there is a problem with the main power supply or thermal shutdown when the lights are red flashing. have you tried to reset it?
Posted on Apr 11, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Philips 51PP9200D/37 not comming on
Check the site www.TvRepairKits.com. They have put together a couple of kits to fix the chirping set/dead set condition. If you don't see your model listed send them and email and they will build a parts kit for you.
Posted on Feb 05, 2009
SOURCE: Philips Projection 60PP90200D/37 NO PIC NO SND 6X/1QF
I had the same problem. It is error code 61 which is a power supply fault. Had a bad LSB board (pn: 313926719011 from MCM Electronics) which blew out on of my CRT. If you have any observed arcing in your CRT's, they are bad and will need to be replaced. I went to Ebay and found a used compatible Philips brand to replaced the CRT. Do not isolate the high voltage lines of the bad CRT to troubleshoot with a bad LSB. The LSB will short out another CRT (it did on mine). I bought the service manual an learned the set does not tolerant of power line surges. If you fix it, invest is a good surge protector.
Posted on Oct 16, 2009
SOURCE: on philips model 37pf9431d/37 no
On ebay locate the store for user techfetch .
At time of writing this response it is
http://stores.shop.ebay.com/Dallas-Electronics-Liquidator
Look for item containging 310432847531 or 310432838621 - those are the power boards models used in your TV.
They offer trade-in service for $99 and it works. We tried it and are very happy with the result.
Posted on Oct 31, 2009
toyladi3
  • 597 Answers
SOURCE: My Philips tv 60PL9200-37 has
When your television actually flashes the front blue light, it is passing a message that there is a problem inside the unit. There are 2 things you should check but my best bet is that it is the t-con board of the television that is bad. The other component you can check is the lamp, but if the lamp is faulty you will not be getting sound therefore the problem is from the t-con board.
It is located by the middle of the main panel of the television, once you get it replaced, the television will be in good shape.
Take care and good luck
Posted on Jan 02, 2011
Philip tv no picture no sound
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 30, 2011 | Philips 52PFL7422D/37 TV
Philips tv model number 50PFP5332D 37 wont power up
JUST A SUGGESTION..
Oct 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
17" Philips LCD TV has sound, faint blue flashes and blinking pwr
GP151001, Typically these cable/wire connectors fall into a catagory called HIGH DENSITY INTERCONNECT connectors or similar type. I should think that the whole assembly should be available somewhere ****!!! It's just this kind of thing that really gets me P.O.ed louie12fix
Apr 15, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
42pf9956/37 philps plasma
I don't know why but this got my TV on.
I took off the back cover and found the source of the clicking.
Two blue plastic rectangular relays in the exact middle.
When I pushed the power button, I felt the top relay click, and I saw a flash from the bottom one. (they are right next to each other)
I took a hair dryer and placed it over the two relays for about 1 minute and tried the power.
It clicked only 4 times and then came on!!!!!!!!!
For some reason heat helps the relay.
If anyone is a tech and can explain this, please do.
Good luck!!!!
My tv is on and it didn't cost me anything.
I just can't turn it off now!!!
Sep 25, 2007 | Philips Magnavox 42MF521D/37 Television
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
