Question about Samsung ML-6510ND Mono Laser Printer Page Printers Mono A4
How to Reset Samsung ML-6510ND to Factory Defaults?
Hi there, The login details for the SyncThru web-admin was lost. Attempted> I tried using the following account details to no avail: username: admin password: sec00000 username: admin password: admin username: *blank* password: *last 8 digits of mac address* Also contacted Samsung Support and tried the following suggested fix but to no avail: ***** As per our chat conversation today, please turn off the power switch at the back of the unit, plug and unplug it. Once you have done this, kindly try to the printer reset again. If you will reset the printer, you will lose all pending faxes, preset settings and speed dials etc. To do this, please follow these steps: 1. Disconnect the power from the device. 2. With the power disconnected, hold down the ''Stop'' button. 3. While holding down the ''Stop'' button, plug the power back and do not let go of the ''Stop'' button. 4. Once the display screen shows ''Australia'', you can then let go of the ''Stop'' button. 5. Then press the ''Start'' or ''Enter'' button. It will then say clearing memory. ***** Any ideas? Thanks in advance.
  • Dakota Jan 10, 2013
    Sorry about the formatting - can't seem to edit the original question to see if I can fix it for the sake of readability.
  • Dakota Jul 29, 2013
    Hi folks,
    Figured out (all thanks to Samsung Customer Support) to reset the printer back to true factory defaults (resets syncthru webadmin login as well).
    Go to menu > network > clear setting.
    This resets your printers hostname, IP configs, etc. back to factory details.
    I then used admin / sec00000 to log into the printers syncthru web-admin.
    Success XD. Thanks to everyone that contributed to this journey.
4 Suggested Answers
SOURCE: installation samsung 4300 printer in ubuntu 8.10LTX
did you checked port settings on linux control panel and printer settings ?
Posted on Jan 07, 2010
SOURCE: Default login for samsung syncthru
the username is
Admin
Password is
sec00000
Posted on Aug 06, 2010
  • 1570 Answers
SOURCE: I have a Samsung SCX-482FN
Hi
Did you try to set up again the printer once more if not, please set up or add the printer once more.
Please let me know if you need more help.
Posted on Apr 29, 2011
How do you do a factory reset on a Samsung ml-2525w printer?
If you have the install disc for the printer , you could delete from the hard drive and reinstall, If the Data is not installed in the printers memory this should work.
Mar 14, 2015 | Samsung ML-2525W Wireless Mono Laser...
I forgot admin password
To reset the SWS (SyncThru Web Service) password:
  1. Press the Menu button.
  2. Press the right or left arrow until Network appears, then press OK.
  3. Press the right or left arrow until Clear Settings appears, then press OK.
  4. Select Yes and press OK.
  5. After the printer finishes clearing the network settings, unplug it for a few seconds then plug it in again.
  6. All network settings (including the SWS password) will be reset. If you had manually configured IP info or were connected to a wireless network, you will need to re-enter those settings now.
  7. The login will default back to admin and the password will be sec00000.
Note: If you did not change your password or this is your first time trying to use the SyncThru service, the default SyncThru user/password is admin/sec00000.
Dec 17, 2012 | Samsung SCX-6345N Printer
I lost my access code
If you lost the wireless access key you can find it by logging into your router. Using an internet browser type 192.168.1.1 into your address bar. A login window should pop up. The default login is username: admin password: admin . If these do not work then you need to reset your router to factory defaults. If this does work then look for the place where you can change the key and change it. You may need to reset the router after this for settings to take effect but after that it should work.
To reset to factory defaults, look for a button on the back that says reset. Press and hold this down for 30 seconds. Everything should reset to factory defaults and you should be able to connect without a password.
May 12, 2011 | ASUS RTN12 IEEE 80233u IEEE 80211bg...
I don't have my security key for my belkins router?
In order to rest your password or if you forgot it you need to reset the router.
  1. Locate the reset hole on the router. The button will be on the back or side of the router.
    See images below:
  1. Leave the router powered on.
  2. Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  3. Remove the paperclip.
  4. Wait approximately one minute for the router to restart.
The settings for the router have now been reset back to their default.
---------->>>>>>> OR:
Restoring the router to default using the web interface
Symptoms
You need to restore the factory defaults using the web interface. This may be because the router is not performing as expected or you wish to remove all previously configured settings.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  1. Click on "Restore Factory Defaults" in the left-hand column under the Utilities heading.
  2. Click on the "Restore Defaults" button.
  3. A warning box will open that says, "Warning all your settings will be lost, are you sure you want to do this?" Click OK.
  4. The router will begin the restoring process. Once the restore is complete, the router will reboot.
    Note: This may take several minutes.
Your router has successfully been restored to its factory settings.
Nov 07, 2010 | Computers & Internet
How can I find out my password?
Unfortunatly there is no way of recovering you password "Sorry" However you could always reset your router to default settings also this will tell you step by step how to secure your router as well:
google_ad_client = "pub-4145730283403556"; /* TE - Post Content - 300x250 */ google_ad_slot = "9003666386"; google_ad_width = 300; google_ad_height = 250; google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
Linksys WRT54G Reset Button Location
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter "192.168.1.1′ in the address bar.
  4. For the login, leave a blank ID and enter "admin" as the password.
Through the Web Administration Pages The second method involves logging into the Web administration pages of the router. Use the following steps to reset the router using this method:
  1. Open your Web browser and enter the IP address of your router. By default, the address is "192.168.1.1′.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn't, the default is no ID and "admin" as the password.
  3. At the top of the Web page, click "Administration" and then "Factory Defaults".
  4. Beside "Restore Factory Defaults", click "Yes".
  5. Now click the "Save Settings" button at the bottom of the Web page.
Oct 05, 2010 | Linksys Wireless-G Broadband Router
I fotgot my password to my router can you give me advice on how to get it back?
Can't get yours back but you can press the reset button will put back to factory defaults, login: Admin with no password
Feb 06, 2010 | Linksys Wireless-G WRT54GS Router...
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
Redrose90049@yahoo.com
Reset There are two ways to reset the Router’s
factory defaults. Either press and hold the Reset
Button for approximately five seconds, or restore
the defaults from Administration > Factory
Defaults in the Router’s web-based utility.
How to Access the Web-Based Utility
To access the web-based utility, launch the web browser on
your computer, and enter the Router’s default IP address,
192.168.1.1, in the Address field. Then, press Enter.
A login screen will appear. (Non-Windows XP users will
see a similar screen.) Leave the User name field blank. The
first time you open the Web-based utility, use the default
password admin. (You can set a new password from the
Administration tab’s Management screen.) Click OK to
continue.
Jan 04, 2010 | Linksys WRT160N Wireless Router
How do I reset my router's ssid and wep settings. Also, I don't remember my router user name or password
There are two ways to reset the Router's factory defaults. Either press and hold the Reset button for approximately five seconds, or restore defaults > Factory Defaults in the Router's web-based utility. I suggest just press the reset button will be the best option since the router username and password cannot be retrieve. 81ddc0b.jpg
Router default IP address is 192.168.1.1 Password screen pop up by default username <blank> password admin.
Nov 21, 2009 | Linksys Wireless-G Broadband Router
the username is
Admin
Password is
sec00000
Aug 11, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung ML-6510ND Mono Laser Printer Page Printers Mono A4 Logo
177 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
