Samsung le32c350 submenu channels on air - Televison & Video
Should have specified. My Samsung S380C screen won't brighten up. Is there a way to do it? It's way too dark for me to see.
If you go into the settings menu, look for a submenu called "display" with an option called "Brightness"
Nov 04, 2013 | Samsung Cell Phones
I have a 46" flat screen samsung TV which I bought
change your tv configuration channel type is probably cable instead of air
Nov 09, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
My t,v. jusrt goes to 6 stations and i have cable. instead of it being on cable as usual it says air where it usually says cable. It is a apex t.v. and apex control, thank you joyce.
Which model of APEX TV do you have?
In general, if the TV has had the source changed, you will need to switch it back from Air (OTA) to CATV (cable). Newer TVs may have the choices of Air and Cable for the TV source.
To change the setting, press Menu (on the TV (if present), on the original remote (in TV mode) or on a substitute remote with the Menu function). Use the up/down arrows to select the TV submenu. Select this menu with the right arrow. Then go down through the submenu to the Source line. (It may read CA-TV/Air on an older TV.) Use the left/right arrows to toggle the setting. Then press Menu to save the setting and return to the previous menu. Then go to the CH Scan option in this menu to rescan the available channels.
Note: I've gone through the directions for an older Apex TV (AVL-2076) with an analog (NTSC) tuner. The directions will probably be similar for other TVs but the menus (and sub-menus) may have different names or be in a different order.
I hope this helps.
Aug 04, 2011 | Directed 434MHZ Remote Control
I have a tevion flat screen tv how can i find out what model it is, i cant get any chanels, how do i search for different channels
For model see tc back cover carefully. If u cant find you need to open the cover but be careful may be there is info on the circuit board of inside the case. For seaching channels go to menu from your remote and find the submenu like tv guide or tv channels.
Mar 20, 2011 | Televison & Video
I have a samsung hd crt that I bought in the US. I have it connected to my sky hd box but I will only show a 520 image and the image is offset. Why will not show a 720 image, without it being offset
Dear sir,
Here is the some settings for best view in Samsung HDTV
try this
Picture menu
Mode: Movie
Cell Light: 10
Contrast: 84
Brightness: 54
Sharpness: 0
Color: 54
Tint: G50/R50
Advanced settings submenu
Black tone: Off
Dynamic contrast: Off
Gamma: -1
Color space: Auto
Flesh tone: 0
Edge enhancement: Off
xvYCC: Off
Set the offset as per your requirement
White balance submenu
R-Offset: 24
G-Offset: 25
B-Offset: 25
R-Gain: 29
G-Gain: 20
B-Gain: 19
Picture options submenu
Color tone: Warm2
Digital NR: Off
HDMI black level: Normal [grayed out]
1080 Full HD Motion Demo: Off
Film mode: Auto1*
Blue only mode: Off
--Setup menu
Game Mode: Off
Energy saving: Off
i think it helped.
if you have any problem regarding this issue,leave a feedback we will glad to assist you
Have a nice day
good luck.
Sep 12, 2009 | Samsung Televison & Video
I have a Samsung HL-S6186W 61" DLP HDTV I could get the hd channels over the air with an antenna before but now I can't get any thru cable without going thru my dvd recorder tuner first which degrades the...
Select TV input, Press Menu, Select Channel, in menu Antenna=Cable (for you), (then perhaps, Auto Program with Cable or Air+Cable), tweak Channel List, turn on LNA if needed, shouldn't be.
Somewhere there may be different modulations, some offset the channel a fraction and are important for channels above 13. I'm basing this on my non-cable Samsung HL-T5687.
BTW, I had an HLS until it gave trouble, paid for an upgrade to LED from bulb when I got HLT. Very pleased, until it fails. -Ken
Jul 15, 2009 | Samsung DLP HL-P5663W 56" TV
I have a Samsung 27" TV and need to set it on channel 73 to get a picture from my Satelite Dish. The highest channel the tv goes to is 69.
Set the TV to cable tuning mode and use that channel 73. You have it set for air now so it can only tune to channel 69.
Apr 26, 2009 | Samsung TXN2771HF 27" TV
Hitachi cp-s235
Did you clean the air filter? You should vacuum it or use an air dusting can to clean it out.
Afterwards, reset the time in the menu. In the manual, it says you have to go in the menu to the OPTION submenu. Go down to FILTER TIME and hold the right arrow down for 3 seconds. It will then go into a mini-submenu that, when you press the up arrow, will reset the filter time to 0. The key is to hold down the right arrow initially for THREE+ SECONDS to get into the reset filter time menu. This is NOT the submenu that has RESET - EXECUTE. That is a different thing that doesn't reset filter & lamp time.
Here's the manual online:
http://www.hitachi-homeelectronics.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/01CP-S235-OG-ENG.pdf
Oct 07, 2008 | Hitachi CP-S235 Multimedia Projector
Programming channels
Hey abshee,
In order to program the channels for this TV, you'll want to press the "Menu" button on the TV itself. Once in the main menu, scroll down until you see an option called "Setup." From here, press the right arrow key to enter the submenu. Before going any further, you'll want to make sure that the tuning band is correctly set to "Air" or "Cable," which will depend on how you have your TV connected.
Once the proper input has been selected, you can then scroll down to "Auto Ch Search." If you press the right arrow key on this option, your TV will automatically search for all available channels.
If you'd like step-by-step instructions (with pictures of what you should see at any given step), I'd suggest checking out the link I've provided below to Insignia's online owner’s manual for this model:
http://www.insignia-products.com/skins/skin_1/Topics/Documents/NS-LCD22_press.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
RCA MM61110 Television
I had the same problem sometimes when my Gold Plus would reset itself and include all the channels but only those Over-The-Air channels. The only way I could change the programming was to completely shut down the power. Not just turning the tv off but completely unplugging it from the wall outlet. When you turn your tv back on you'll be able to choose from Antenna/Cable option. As for Guide,if you don't want to use it, don't set it up, it won't effect anything else on the television.
Aug 08, 2007 | RCA MM61110 61" Rear Projection Television
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
