Question about Goodman GMS90703BXA Heater
My goodman will not lght when it get cold but when its like 55 degree it comes on
  • 700 Answers
Sounds like your thermpostat is either bad or just out of level. If its just out of level then you will have to level it if not then you are going to have to replace it. Get a digital thermostat and save some of your money by using the setback features. I personally reccommend Honeywell thermostats due to the fact of they are very reliable and the instructions are real easy to follow.
Posted on Jan 21, 2009
Problem for Goodman CKL60AR60 Air Conditioner, what should be the right pressure on low /high side
Hello my name is Heath it will be my pleasure to assist you. If you are talking about r-22 with an outside temperature of 75-80 degress farenheit it should be running between 62-68 on the low side and 200-225 on the high side but there are varibles to take into account like the air flow across the inside coil or a dirty evaporater just things to take into account these pressures are approximate if there are close it should be fine.
Aug 02, 2010 | Goodman CKL60AR60 Air Conditioner
What kind of freon would i need for a goodman cplt24-1a heat pump ? has not cooled the houuse for 2 years now, thought it may have been the compressor as the heating was not working either. But i was told...
R22 but it does not use it it is circulated in a closed loop, if the fan outside is running you may have to pull the brown wire at the split capacitor to see if the compressor is running. Also it is really important that the filters are changed and that the outdoor is clean allowing air to pass through. Turn off power before pulling the brown wire then reapply power for just a second listening for the compressor. If you hear it, turn off power, reconnect fan brown wire. Turn on power and feel if large line is cold to the touch like a good soda can should be around 45 to 55 degrees f. If not cold it need 3 to 4 pounds if the compressor is working which would indicate a leak.
Jul 06, 2010 | Goodman CPLT24-1 13 Air Conditioner
I have a 2 1/2 ton unit. If the outside temperature is 95 degrees. What should I expect from my unit in cooling my house.
If properly charged your unit should perform fine, having a dirty condensor at that temperature can cause problems not easily recognized.
A well insulated house should be able to maintain a 20 degree temperature difference whether its summer
or winter. No Mechanical cooling or heating involved
for at least 6-8hrs if not more.
If it never cools when it is 95 degrees outside the ambient outside temperature is not the problem.
At 95 degree out side air you should be seeing inside discharge air temperatures betwenn 48-55 degrees.
It is the load in the house that determines how long the unit will run at 95 degress.
Jun 21, 2010 | Goodman CKL24AR24 Air Conditioner
Freezer fine, fresh food 55 degrees max cold
Check for frost build up in freezer section. If frosting up you will need to check the heater and bi metal. If it's a ge ref. could be thermister or main board
Feb 25, 2010 | Refrigerators
I have a 2 ton Goodman heat pump. when it gets to the temp. it is set on it will not cut off. I can cut the thermostat back 2 degrees and it will cut off until it gets cold enough to come back on and then...
Heat pump have coeficient of performance. They are rated at about 60 degrees. So at 60 degrees you get 24,000 but the colder it gets the lower the rate 40 degrees18,000 and so on. Now on your Goodman depending how cold it is outside a heat pump reaches a balance where it runs all the time. That is if your heat pump is charged correctly. Your problem might be that it is a little low on Freon. Also your back up or auxillary heat to comes on to help keep up. On some tstats that is about 2 degrees behind the set temp. On digital tstats if the heat pump can not keep up it is about two minutes behind. I hope I have not confused you but it is better for the heat pump to run and pull 9 amps than the electric abck up to come on pull 9 plus 20 to 30 for the heat. Answer just have your charge checked ask for Service check special I have them with my company and it cost about 50.00 to check and clean systen Freon exrtra. Check your aair temp between the inlet and the closest outley should be at least 20 to 25 degree rise in temp. FEEDBACK WELOME Rus
Dec 05, 2009 | Refrigerators
I recently purchased a Goodman airconditioner 4ton 16 seer. I'm not sure air is coming out cold enough. What should the temparture be of cold air coming inside my home?
It depends on the air temp in the home. But you should be getting about a 12-15 degree difference between the return and supply Temp. So if your room temp is 78°F then expect about 63°F supply temp.
Jul 21, 2009 | Heating & Cooling
Have goodman unit, ac unit running 55 suction, 210 high side. cleaned condenser coils and charge to 10 degrees supercool. suction at 65, discharge 245, why did my discharge go so high
You should have liquid line filter/dryer that maybe restricted or there is a restriction in the orfice inside the evap coil normal operating pressures are 68/ 180
Oct 07, 2008 | Goodman Heating & Cooling
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
May 30, 2007 | Danby DWC283BLS Wine Cooler
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
