Question about Dell Inspiron Computers & Internet
What is the CMOS clock? - Inspiron Dell Computers & Internet
  • Dell Master
  • 7,627 Answers
Here's more than you ,most likely, want to know about the CMOS : http://en.wikipedia.org/wiki/CMOS , RTC: http://en.wikipedia.org/wiki/Real-time_clock
Posted on Jan 10, 2013
M863g v5.1a sempron cmos clock error solution
Hello here is the mainboards homepage:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=343&CategoryID=1&DetailName=Manual&MenuID=1&LanID=0
For downloading the manual.
The solulion is, to renew the cmos battery on the mainboard.
The battery is a cr2032 watch type:
Press the lid to release the cmos battery, and insert the new the same way.
Restart the pc, and you probably get this message:F1 or F2 for setup, or press the delete button to enter the bios.
You have to setup the bios, like clock,date,and boot settings for your drive.
Look in the manual, for detailed setup configure.
Good luck
Jan 19, 2012 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Inspiron laptop clock occasionally reverts to July 2008
There is a small 3 volt battery on the motherboard which is the backup for the circuit clock .So if the battery has gone low in voltage the clock will be reset as the CMOS setting will be reset. The clock will then go back to the time of the laptop set-up which is in july 2008.
Replacing and then correcting the CMOS set- up on booting will set the clock to work to the current time/date.
Sep 16, 2011 | Dell Computers & Internet
Hi, I have a dell studio 1535 and the bios clock runs very fast. In one hour the clock pass few days. I try updating the bios, set to default values and nothing changes. This is a CMOS...
I dont think it is a cmos issue because i replaced the cmos battery and it did not help my clock. I also had dell fix the motherboard and it worked for bout 7 months unfortunately after my warranty was up. Til this day my clock last no longer then a few hours until it reverts back to the time i changed it to.
Dec 27, 2010 | Dell Studio 15 Laptop
Dell inspiron 1545 laptop (Time- of- date clock
This could mean two things: a problem with the cmos battery or the motherboard itself. Try to remove the cmos battery first and install. If not,then replace the cmos battery.
Oct 12, 2010 | Dell Inspiron 1545 Notebook
Bios clock has stopped on Fujitsu T4215 tablet pc. Have tried: 1) updating bios 2) re-installing cmos clock Clock starts again once in Windows (but from static date in bios) and can synchronize clock from...
I thik your CMOS clock (HH:MM:SS ) SS digit not moving forward. If it is then just unplug your CMOS Battery and 5 min later reassemble it ...your problem will be solved.if your BIOS whole setup reset including clock and SSS digit moving forward then replace your CMOS battery...if your not expert to open laptop then take a expart help to open it and run this procedure..
May 14, 2010 | Fujitsu LifeBook T4215 Tablet PC
Cmos setting wrong on start up
are you able to enter the cmos to make changes?
depending on the brand, you may hit one of several keys to access the cmos. del, f2, f10, f11, f12.
then try resteseing the cmos to defaults.
Jan 06, 2010 | Intel Computers & Internet
Clock not keeping correct time
The CMOS battery keeps the laptop configuration stored in the CMOS chip and the main battery has no effect on the CMOS.
If the date and time drift off, it indicates the CMOS battery is nearly flat and needs to be replaced.
If you had ticked the Daylight saving box in the Time Zone tab in Control Panel - Date and Time setting then the time would automatically adjust for Daylight saving.
Apr 05, 2009 | IBM ThinkPad T40 2373 Notebook
OVERCLOCKING FAIL/CPU FAN ERROR
First approach shold be the CMOS utility, check in FAILSAFE DEFAULTS that the error settings for shutdown are either null for overclocking or disabled if you don't have the failsafe defaults on your CMOS utility then set your settings to best performance (should be found on the main page of the CMOS utility). If you are unsure of touching the CMOs then you could try to remove the CMOS battery (small 3 volt battery about the size of a 20 cent coin) located on the motherboard this should reset the CMOS and fix the problem. hope i could help,thanks:)
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Computers & Internet Logo
121 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
