Question about Dell Latitude C810 Notebook
Laptop fails to load despite correct password hard disc not found
  • Dell Master
  • 7,627 Answers
Remove HDD, test , replace if necessary.
Posted on Jan 10, 2013
Get error message "no Bootable disc"
You need to check the BIOS settings to see if they've been changed. Easiest fix once you're in BIOS is to choose "default settings" and then reboot. If the settings are correct (choosing the internal hard drive as the primary boot device) and it still won't boot, your hard drive may have failed.
Sep 22, 2014 | Gateway Computers & Internet
A505 S6970 Toshiba laptop HDD#1/SDD#1 password
Maybe you mean log on password. If you never enter a password to log on, but suddenly when turning on the computer, you are prompted to enter a password to log on, but always failed. You try to log in using an administrator user but failed. Chances are, the operating system is infected with viruses.
So, the operating system has controlled the virus.
solution:
Install the new operating system (not repair the operating system)
Nov 27, 2011 | Toshiba Satellite A505-S6970 Notebook
Reset password
You can't reset the password if this is a PC or laptop (you failed to give that information), you must format the hard drive by using the factory/recovery restore disc. If you don't have the restore/recovery disc's you can purchase them for a small fee (less than $25.00) from the parts dept of the PC/Laptop manufacturer. If this is not a computer please let me know
Nov 22, 2011 | Gateway Computers & Internet
My pavilion dv7 is saying "boot device not found". It is saying there is "no hard disk". Any suggestions appreciated.
I would want you to tell me if your Laptop feels hotter than usual.
If so... this in combination with the Boot device not found message means you may have two problems.
1: The hard disc is failing
2: Your cooling fan isn't working
Either one could cause the other to fail. If the hard drive is overheating the cooling fan may not be able to keep it cool enough to function properly,
If the cooling fan isn't working properly or the cooling vents are clogged the hard drive and/or the intergrated circuitry could be overheating
If you do not sense any over heating.
You hard drive may have crashed, if you have another one you can put in the laptop to see if it is recognized.
Would help to have some sort of disc you can boot off of that would recognize a hard drive such as a Linux live CD or Hiren's boot CD or some sort of PE disc. Maybe a Windows install disc. to try and find out the cause.
Good Luck
Jun 26, 2010 | HP Pavilion dv9000z Notebook
Had to replace hard drive and after loading from
that is some thing i could fix for you if you came into my shop. i have cds that will let me roll back your system and remove the password. really sorry i can't help you here.
May 20, 2010 | Computers & Internet
Black screen ask for password
Black screen with "Enter Password" in blue box. - BIOS password.
To reset: take the CMOS battery out then place it back again.
Black screen with Enter password in the upper right left corner - could be hard disc password.,
If you set up the password before, you can only bypass that by entering the correct password. If not, it will render the hard disc useless.
Jan 30, 2010 | Toshiba Satellite A55-S1063 Notebook
Hi, my laptop is having problems starting up it loads up the the loading screen before u put your password in and it just stops there, i've tried a toshiba reboot to out of box state and it still doesn't...
If you hav ethe Toshiba reinstall disc, check to see if it has any kind of diagnostics loaded with it. Try starting the computer, and keep tapping the F2 key, this should load the setup BIOS screen. Go to the section in setup where you can change which boots first. Set it for the CDROM to boot first. Save the settings, and restart. Once the computer loads the disc first, look for hard drive diagnostic tools. run the diagnostics to check the hardware on the computer, it should tell you what is good, and what is not. If it is the hard drive that has failed, than that is an easy fix. The only hard part is having to shell out the cash for the new drive. Hard drives on laptops are easy to get to. They are under a door on the underside of the computer. There is probably a couple screws, and the hard drive compartment will open up. Just remove the old one, and plug in the new one. Hope this helps!
Jun 04, 2009 | Toshiba Satellite A200-0ET00X Notebook
NO OPERATING SYSTEM FOUND AFTER I JUST LOADED XP HOME AND ALL THE UPDATES FOR IT ?
Put your windows disc in the drive and reboot. It should allow you to boot from disc and then you can install as per on screen instructions.
You have basically erased the hard drive and the OS
For future reference, just put your install disc in and reboot, you will be given an option of upgrade, or install. By installing you will automatically format the drive.
May 07, 2009 | Computers & Internet
I cannot load windows xp pro
Go to BIOS and disable "NATIVE SATA SUPPORT"
Mar 20, 2009 | HP Computers & Internet
Mac notebook
The most likely cause is a bad hard drive or a corrupted file. Start up the computer in safe mode. (Hold down the shift key while starting) that will force the macbook to run extended tests on the startup drive. If it finds any errors it may be able to correct them. If that fails use the startup disk that came with your laptop and start from it (hold down the C key during start up) that will allow you to use disc utility to try repairing your hard drive.
If the macbook fails to boot to the DVD or into safe mode. Try reseating the RAM chips. Hope some of that helps.
Aug 06, 2008 | Apple MacBook PC Notebook
Dell Latitude C810 Notebook Logo
19 people viewed this question
Alun Cox
