Question about Panasonic HDC-SD80 Camcorder
Fix screen panasonic hdc-sd80
Need to change the screen
HDC-SD80K camcorder does not turn on when I open the screen
If it is brand-new, or near-new, and it is defective, then exercise the warranty to get it repaired or replaced.
Mar 15, 2014 | Panasonic HDC-SD80 Camcorder
Tip
Convert/Edit Panasonic HDC-SD9/HS700/TM700 to Mac, iMovie, FCP. FCE
Panasonic HDC camcorder family has a great number of High-Definition Camcorders that satisfy different people who want to record their interesting daily life, now, You can check the list of popular Panasonic HDC series camcorder as follows:
Panasonic HDC-SD Series: Panasonic HDC-SD9, HDC-SD10, HDC-SD60, HDC-SD100, HDC-SD200, HDC-SD700, etc.
Panasonic HDC-HS Series: Panasonic HDC-HS250, HDC-HS300, HDC-SD60, HDC-HS200, HDC HS100, HDC-HS700, etc.
Panasonic HDC-TM Series: Panasonic HDC-TM10, HDC-TM20, HDC-TM60, HDC-TM50, HDC-TM30, HDC-TM200, HDC-TM300, HDC-TM700, etc.
Most of Panasonic HDC Series Camcorders record video in AVCHD MTS/M2TS files, for example, Panasonic HDC-SD9 records 1080i 17Mbps video in M2TS files; Panasonic HDC-SD700, Panasonic HDC-HS700,
Panasonic HDC-TM700, these three types store videos in MTS format and all offer Full HD 1,920x1,080-pixel resolution at 50 frames per second. For Mac users, if you cannot import Panasonic HDC video to Mac to enjoy, or cannot directly edit Panasonic AVCHD MTS/M2TS files in iMovie, FCP, FCE, you need to convert Panasonic HDC videos to MOV, MP4, 3GP, M4V, H.264 for Mac and then you can edit converted AVCHD MTS/M2TS video with iMovie, iTunes, FCP, FCE, etc.
Mac Panasonic HDC Video Converter, a professional AVCHD Converter, is designed for converting videos collected from Camcorder Panasonic, Canon, Sony, etc to MP4, MOV, MPEG, 3GP, M4V, AVI, etc to Mac, then you can play AVCHD MTS/M2TS, videos on Mac, iPad, iPod, iPhone, PSP, Blackberry, and any other mobile phones.
How to convert and edit Panasonic HDC video to Mac?
Step1: Import Panasonic HDC Video to AVCHD Converter for Mac
Click "Add File" to upload your Panasonic HDC video to Mac AVCHD Converter after you launched it.
Step2: Set Output Video Format for Mac, iMovie, FCP
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, iMovie, iTunes, iDVD, FCP, FCE, etc.
Step3: Convert Panasonic HDC Video to Mac, iMovie
Click "Start" button to convert Panasonic AVCHD MTS/M2TS files for Mac. After conversion finished, you can enjoy converted MTS/M2TS files on Mac or edit these converted AVCHD video with iMovie, FCP, FCE, iDVD, etc as you like.
on Oct 19, 2010 | Computers & Internet
Card unlock SD80
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 12, 2012 | Panasonic HDC-SD80 Camcorder
I just got my Panasonic HDC-SD80 in the post. I am charging it but tried to turn it on just for a quick look. The camera turned on and I could scroll through the menus on the touch screen and stuff but...
sometimes this happens if there is a fault with the memory card. switch the camera off, take the battery and memory card out, leave it for 2 mins, put the battery in (DO NOT PUT THE MEMORY CARD BACK IN) wait for the message on screen saying no memory card detected. switch off camera, put memory card in, switch on the camera, this normally cures the blank lcd screen issue
Aug 22, 2011 | Panasonic HDC-SD80 Camcorder
Is there somewhere i can get a hold on a manual for panasonic hdc-sd80
You can download the manual from the manufacturer's web site at
http://service.us.panasonic.com/OPERMANPDF/HDCSD80-MUL.PDF
Jul 15, 2011 | Panasonic Cameras
I have had my Panasonic HDC-HS20 for a while now and finally filled the hard drive. I have only recently transferred all the footage onto my PC. When i play the videos back the image is good for stills but...
On the PC, if You Tube plays good HD videos then the problem is either the format that the camera is putting out or the Codecs in the computer. See if Panasonic have computer software to put on the computer. It is usually on the disc that came with the camera, or available online.
found this.Looks like it needs converting.
https://www.avforums.com/threads/panasonic-hdc-sd20-hd-camcorder-help.1314662
AV Writer software
found this helpful answer from camera and video technician on JustAnswer...
Panasonic Download
https://panasonic.ca/pcs/FAQ/english/CAM_WIN7_comp_EN.pdf
Panasonic HDC HS20 Google Search
Jul 03, 2017 | Panasonic HDC-HS20 High Definition AVCHD...
Panasonic HDC-SD80 Camcorder Logo
24 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
