Question about KitchenAid Refrigerators
Model # KSRS25RSMS01 front panel does not reset when the filter is changed.
The filter reset button on the dispenser front panel does not reset, to show how much filter capacity is remaining after the filter has been changed. It is staying on 0% left in filter when there should be a reading of 100% remaining after the filter has been changed and the reset button has been held down for three seconds. Do I need to replace the front cover housing which has the filter touch button on it ?
  • 958 Answers
SOURCE: how to remove housing cover in front of ice maker
hi,
here is a picture of your dispenser, i hope it would help you solve your problem.
http://www.partadvantage.com/catalogimage.php/IWZM5EII.gif?geometry(1000x1000)
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
woodchuck789
  • 4070 Answers
SOURCE: water dispenser will not dispense water
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Posted on Sep 30, 2009
aborcass
  • 2651 Answers
SOURCE: I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
Posted on Jan 27, 2010
SOURCE: water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Posted on Jul 09, 2010
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Unpluged the panel from ice maker . when i repluged it with the power on it start bringging ice out automaticly. now water dispener does no work . Is this an elctronic problem?
Check temp setting. Freezer temp in between -14 and +8*F. And fridge temp must be in between 38* and 46*F.
Make sure the dispenser is notlocked. Some models have a lock feature that deactivates the dispenser andcontrol buttons. The lock button is located on the dispenser front cover.This feature controls unintentional dispensing. Press the"Unlock" or "Locked" button to reactivate the dispenser andallow dispenser function. You may need to hold the button for2 to 3 seconds. A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced.
Thanks. Helpful?
Feb 17, 2011 | Frigidaire FRS3R5EMB Side by Side...
Where is the reset button for the ice and water after you have changed the filter
On models with a Filter Status or Filter Reset light/button, it is part of the water/ice dispenser panel. The button will be just above the light (usually to the left of the other buttons). Press and hold the button for at least 10-15 seconds until the green, amber and red lights flash.
Other models just use a sticker that should be placed on the front of the filter cup.
I hope this helps.
Aug 22, 2010 | Frigidaire FRS3R5EMB Side by Side...
How do i reset the filter light on my refrigerator msd278ge
Simply press and hold the dispenser lock and auto light buttons on the dispenser (at the same time) for four (4) seconds until the filter status indicator begins to flash, then release the buttons. On some Amana refrigerators, you need to press the dispenser lock and water buttons for four (4) seconds until the filter status indicator begins to flash, then release the buttons.
Also note that
  • Remove the old water filter from your refrigerator by turning the handle counterclockwise and pulling it out of the filter holder. The filter is located in the upper right corner of the refrigerator.
  • Step 2Slide the replacement filter into the filter holder and turn it clockwise.
  • Step 3Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • Good luck......
    Jul 29, 2010 | Maytag MSD2758GEB Side by Side...
    Trying to reset filer light after changing filter-locked up
    Here is a link to the manual for your unit. Copy paste into your browser.
    http://shop.amana.com/assets/pdfs/literature/12591321.PDF
    Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
    There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
    DISPENSER LOCK
    (SELECT MODELS)
    This feature prevents ice or water from
    being dispensed.
    To lock dispenser:
    ➢ Press and hold DISPENSER LOCK
    button for 3 seconds. A green
    indicator light above button confirms
    dispenser is locked.
    To unlock dispenser:
    ➢ Hold DISPENSER LOCK button for 3
    seconds. Green indicator light above
    button will go out.
    Filter reset
    The filter status indicator light
    serves as a reminder to replace the
    water filter. A green light indicates that
    the filter is in good condition. A red light
    indicates the filter should be changed.
    Once light turns red, it will remain red
    until function is reset.
    To reset indicator:
    ➢ Press and hold both DISPENSER
    LOCK and WATER buttons
    simultaneously for 4 seconds. The
    green filter status indicator light will
    flash 3 times when the function has
    successfully reset.
    Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
    "change water filter" continues to flash when dispensing water
    I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air
    Press and hold the light and lock buttons until the change filter light flashes.
    It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
    Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
    Mar 05, 2010 | Jenn-Air JCB2059G Bottom Freezer...
    Turn off the change filter light on maytag refrigerator
    For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
    Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
    Water Filter Indicator
    I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
    Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
    Refrigerators Logo
    42 people viewed this question
    Top KitchenAid Refrigerators Experts
    John Tripp
    John Tripp
    vince
    mike cooper
    Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
