Question about Intimus Simplex se Shredder
Only reverse works - not forward
Machine will not shred any paper feed into it. However, reverse action only does work!!
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
How do I fix my auto feed, which has stopped working?
Use a flashlight to examine the shredder from the top and look for a shred of paper blocking the slot. The shred may also be blocking the sensor. If you don't find anything, turn the shredder upside down to examine the shredding mechanism from the bottom.
Mar 05, 2015 | Staples SPL770M Shredder
Fellowes P35C works in reverse but not forwards
In forward operation, a detector senses the presence of material in the feeder and turns it on. Reverse operation is selected by switch position; no sensor is involved. I would bet that if you remove power and turn the shredder upside down you will find bits of shredded paper clogging your shredder, particularly in the center area where the detector is located. After thorough removal of debris, you should be back to normal operation
Feb 03, 2013 | Fellowes P35C Black Cross Cut Shredder...
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
Runs only in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Royal 9 x cross cut shredder wont go through even two pages thick
Put some shredder oil on the paper you are shreding...shred a number of sheets with oil on them so that the oil gets down into the cutting shafts/teeth.
Jan 12, 2009 | Royal Office Equipment & Supplies
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
Intimus Simplex se Shredder Logo
Top Intimus Office Equipment & Supplies Experts
ray gallant
Lonnie Arks
Tom Chichester
Are you an Intimus Office Equipment and Supply Expert? Answer questions, earn points and help others
