Question about Microsoft Xbox 360 Console
Xbox 360 3 flashing lights
Tried the eraser fix on the memeory chips and no luck. My memory chips did NOT have the rubber tape on as stated would be there. Used double stick gummy tape and a red "pink pearl" eraser and no success - after all that!Refuse to try the "towel trick". Any other ideas or things to look at? Please help.
This Raheeeb is really expert
Posted on Aug 31, 2007
  • 20 Answers
Sorry your chips need reflowing ... Raheeeeb
Posted on Aug 08, 2007
  • 32 Answers
Spawnpa: Did your 360 fell??
Posted on Jul 03, 2007
I have the E 74 error how do i fix it?
Basically, this problem is caused by overheating, which is often an issue with most high-powered electronic devices.
As heat levels rise inside your Xbox 360 the connection between the motherboard and the video scaler (HANA/ANA) chip is damaged due to the expansion and contraction of the metal connectors.
Once you have experienced the red ring of death e74 once on your Xbox 360, it will continue to happen over and over again until you fix the problem permanently.
The process of repairing the Xbox 360 red light e74 involves opening up your console, removing the hard drive and disk drive (as these get in the way when you are navigating around the narrow confines of the case) and then locating the video scaler chip.
You then remove it from its seating point and clean the connections; an eraser works well for this. It then has to be seated correctly back in its slot. Once this is done and the hard drive and disk drive are re-installed you can put the case back together.
When you turn your console on again it should be free of the e74 error.
Good Luck and have a nice day.
Jun 07, 2010 | Microsoft Xbox 360 Console
Tip
Temproray fix for xbox 360 E74
<span>Take two bare ends of a Q-tip stick them in the fan slots (make sure hard drive is out / memory unit(s) or games) . Then wait till your xbox 360 turns off or has 2 flashing red lights. Then wait 30 minutes for it to cool down. Then put hard drive/ memory unit(s) back in then turn on xbox 360 then it will work. (This will not be a permanent fix) and there you go </span><br /><br /><span> Good luck,</span><br /><br /><span> Damian128</span>
on Mar 12, 2011 | Video Game Consoles & Games
I have code error 74
Code E74 1 red light flashing and error message on screen right? It is the scaler chip, it happens because the scaler chip starts overheating. If you stop the heat build up on the chips then you should be fine.
You can send your Xbox 360 back in for repair or fix it yourself with a good Xbox 360 Repair guide
Oct 28, 2009 | Microsoft Xbox 360 Console
1 red ring flashing on xbox 360 elite e73 stated on the tv tried xbox customer service centre unconnected all accessories reconnected one by one still a problem got this feeling it is the ring of death is...
e73 is a simple one to fix, ive done loads and they are the exactly the cause or the same as the e74 and to fix you need to strip your machine down and re-heat the solder points especially concentrating on the back end of the motherboard near the ANA chip and ethernet chip.
ive been warned not to provide guides on helping you but just to say you can find step by steps on the internet free.
Sep 28, 2009 | Microsoft Xbox 360 Elite Console
Guitar Hero Flashing Sensor Lights
Im guessing due to needing batteries that your Guitar is the Wireless type ?!
Have you correctly Synchronised your Xbox 360 with the Guitar controller ?
to do this, Turn on the Xbox and Guitar press the round "sync" button on the bottom of the guitar, next to its Ethernet port, and also press the small round sync button on the Xbox 360 (located to the left of the memory slots on the front face) at the same time, the rings of light on both the Xbox and the guitar will Turn in a clockwise motion letting you know they are synching, after that the Xbox will assign the guitar to a controller slot. then it should work.
If this doesn't work then im afraid your guitar may have a faulty wireless chip, which would require you to get a replacement.
hope it gets sorted !
Oct 28, 2008 | Activision Guitar Hero III: Legends of...
THREE RINGS
I suggest using three copper pennies per Ram chip.
Use a slight amount of reusable adhesive to stick the pennies together and then to adhere to the ram chips.
Also use pennies made before 1983, they're %100 Copper and make better heat sinks.
Note: If problems persist, remove the black screws on the bottom of 360, but keep the silver screws.
Apr 30, 2008 | Microsoft Xbox 360 Console
No rubbery material on memory chips
To be honest, you shouldnt have opened your xbox 360 in the first place because now you voided your warranty. Also, i dont think it means anything.
Mar 30, 2008 | Microsoft Xbox 360 Console
3 red lights
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
this explains the codes
Dec 20, 2007 | Microsoft Xbox 360 Console
Xbox 360 red rings of death!
high hisham, i dont think its a maor ailure beacause if it was a maor failure then your xbox 360 can"t work . pencil eraser i think it is a nice solution for this please go further and do it . and we are there to help you . if your warranty is over then give me that pencil erasers serial no. so i can activate it send your serial no. on this email id. my email adress is purple_purpleoo7@yahoo.ca and if you have any problems more than we can solve it.
Oct 01, 2007 | Microsoft Xbox 360 Console
My xbox flashed a red light, and the screen goes black
I went with the eraser fix and it worked like a charm. Can anybody explain why using erasers changes things and makes the 360 work without the 3 red lights flashing? Just Curious!
May 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
65 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
