Question about Toys R Us Tabeo
Tabeo volume too low hard to use and freeze up.
Tabeo app problem
Are you running low on memory. Check your settings and check your memory usage. Delete your cache. This should help.
Jul 03, 2015 | Toys R Us Tabeo
How do I recover my lock screen password for my tabeo tablet
Not possible to recover your password just factory reset back to when new! Press power for 30 seconds then press power and volume+ buttons together until reset screen comes on then move to factory reset option using volume buttons and select using power button!
Dec 26, 2014 | Toys R Us Tabeo
How do i reset tabeo 1 with out entering password
For factory resetting your Tabeo tablet, you have to go to 'settings' page. In this menu, youcan find an option for 'hard reset'. If you click or tap this menu, you can get a new optionswhere you will find option for hard reset. In this list, you can also find the option for hard resetting. If you select that option, the tablet will ask for confirmation.
Once you confirm, the tablet will perform factory resetting. Factory reset or hard reset will wipe of the data present on your tablet. So, it is very much necessary that you take back up of the data present on the tablet before heading for resetting. It is a good idea to keep the back up of all the files regularly so that you can go for hard resetting at any time, if the tablet gives any problem.
Dec 16, 2014 | Toys R Us Tabeo
I'm locked out of my Tabeo tablet. How can I reset it?
go to you tube and type in hard reset a the brand and model and a page of videos that should help you sort your problem .
Aug 13, 2014 | Toys R Us Tabeo
Tabeo reset pc unlock
If any problem arises in computer, we are habituated to format the PC. The same applies to laptops also. But when there is any problem in your tablet PC, there is no other option except factory resetting. It is similar to formatting. When your tablet gets infected with some virus, or when you got it locked accidentally, or if you feel that your tablet PC is running slow, you might have to go for hard resetting or factory resetting. You might opt for hard resetting due to various reasons, but theprocedure of resetting is similar in most of the tablets. First of all, when you are going for hard resetting of the tablet, you have to check whether the manufacturer of your tablet has mentioned any specialprocedure for it.
In most of the cases, the procedure will be same on all Android tablet, unless specified. You can check the official website of your tablet manufacturer or can also go through the manual book given at the time of purchase of the tablet. If nothing is specified, you can carry out the generalized process. For factory resetting your Tabeo tablet, you have to go to 'settings' page. In this menu, you can find an option for 'hard reset'. If you click or tap this menu, you can get a new options where you will find option for hard reset. In this list, you can also find the option for hard resetting. If you select that option, the tablet will ask for confirmation.
Once you confirm, the tablet will perform factory resetting. Factory reset or hard resetwill wipe of the data present on your tablet. So, it is very much necessary that you take back up of the data present on the tablet before heading for resetting. It is a good idea to keep the back up of all the files regularly so that you can go for hard resetting at any time, if the tablet gives any problem.
Feb 21, 2014 | Toys R Us Tabeo
Tabeo tablet
either the charger need to be replaced or the adapter on the tabeo need to be replaced
Jan 28, 2014 | Toys R Us Tabeo
Unit frozen cant charge stays on no movement already reset
Tabeo Support allows you to Live Chat, Email, and Call them 24/7.
  • Live Chat
  • Email: tabeo-support@supporttechs.com
  • Phone: 1 (888) 477-0888
There is also a firmware update that was released Oct. 24, 2012 to fix some bugs. Downloading it may help. You can find the latest Tabeo updates here: http://www.toysrus.com/shop/index.jsp?categoryId=13311977
Dec 17, 2012 | Toys R Us Tabeo
Toys R Us Tabeo Logo
Top Toys R Us Tablets & eReaders Experts
Bill Boyd
andrewcahoon
micky dee
Are you a Toys R Us Tablet and eReader Expert? Answer questions, earn points and help others
