Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The copper line under my s. b. s. fridge keeps freezing
I have a whirlpool fridge side by side and a copper line undernithe it in the front keeps freezing is still cold could be colder the ice and water disp. are not hooked up?
  • James Gibson
    James Gibson Jan 21, 2009
    thank u 4 your help
  • 700 Answers
The line that you ae seeing is the suction line . It sounds like the defrost timer may have gave up the ghost on you and the unit is not going into defrost. Take the model Number and make to the local parts house and have thenm get you a timer. They are real easy to replace and that should take care of the problem.
Posted on Jan 21, 2009
I have a two year old whirlpool side by side refrig and it is freezing things in the refer side no matter what setting it is on. Can you tell me where to start to troubleshooting?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Good luck in solving the problem......
May 12, 2011 | Whirlpool Refrigerators
Fridgerator is freezing everything even at lowest setting it is an whirlpool energy star side by side
Check the plastic air deflector at the top rear of the frig had been knocked off. I replaced it and all is OK. I thought you might add this to your suggestion list. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Hope this helpout in solving your problem
Aug 01, 2010 | Whirlpool Refrigerators
Ice/water forming under fridge hydrator.
The tray slides out, take it out and dump it, clean it and replace it every year. This is where the coils drip to when the humidity is high or it is working hard to keep cool, like if you just had a party and everyone was in the fridge.
Aug 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Fridge and freezer not getting cool enough
Yes, the larger line should be cold and the small one should be hot. Handle the small one with care, depending on how much load the fridge is under it can get very hot.
Jun 29, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Whirlpool S20BRSB21: The fridge side keeps freezing
call a repair service , the air damper control needs fixed, if you have lowered the control value all you can
Mar 04, 2018 | Whirlpool Refrigerators
Water leak at filter
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
Dec 02, 2008 | Whirlpool GS6NBEXR Side by Side...
Frigidaire GLRS264ZAQ5 fridge freezes up
does the ice maker have to have the copper tubing?
Aug 16, 2008 | Frigidaire GLRS264ZA Side by Side...
Refrigerator drip
My SZ 550 (fridge over freezer) dripped constantly. Turned out to be a frozen drain tube, located 6 inches above the refigerator floor, centered on the back wall (cold side of refrigerator). Remove both trays and the lower glass shelf to see it. This tube runs down, behind the freezer, dumping refrigerator condensate in the pan below the freezer. If it's frozen the condensate leaks out the front of the fridge, down and onto the floor.
The fix, suggested elsewhere (not my idea) is quite simple and elegant. Thaw the tube (this will take an incredibly long time.) Fish a string (I used a piece of yarn) from the refrigerator (cold) side of the tube, down and out the other end, under the freezer. I was able to use a vacuum to suck the yarn through. Be creative. Once the fish line is in, tie a piece of nylon fishing line to the yarn and pull it through the tube. You have replaced the yarn with a stronger fishing line, which you can use to pull a piece of copper wire (I used common 14 gage romex, stripped of insulation through the drain tube. Leave the copper wire in the tube. If you wind the bottom end of the copper wire around some of the warm evaporator coils under the freezer the heat will be sufficient to keep the tube from freezing. I did this about a year ago and have had no problems since. Good luck.
Mar 08, 2008 | Refrigerators
Auto defrost not working correctly
the tray at the bottom which collects defrost water usually has its own heater or a section of the main heater runs close to it. check this part of the heater has continuity. an old trick as well which sometimes works is to wrap some copper wire round the heater and lead this to the drain hole. conductiuon of heat thro the copper helps keep the drain clear. this is a common problem across all makes
May 08, 2007 | Whirlpool 18.2 cu. ft. Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
160 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
