Question about Philips SA3025/37 Flash MP3 Player
My USB cable can't be read
I have a Phillips GO GEAR SA3025 2GB, i plugged my USB cable and my pc doesn't read it i don't know why because it was working a few minutes ago, please i need help....i installed the device manager but nothing is happening :( please help what can i do
  • 8,596 Answers
Upgrade the firmware by downloading the latest version of the Philips Device Manager from www.usasupport.philips.com and clicking on the Update tab.
-Tha Mp3 Doctor
Posted on Feb 01, 2009
My Phillips MP3 Player hangs
Philips SA30XX MODEL GO GEAR NOT DISCONNECT AND NOT WORKING NOW ONLY SO OK TO DISCONNECT
May 16, 2013 | Philips GOGEAR SA6045 MP3 Player
What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about...
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Audio Players & Recorders
Don't know how to recharge
Just use the combined USB/audio cable. Plug the standard USB side in your computer, or even in the back of some modern TVs, and then plug the other side with the smaller USB plug into the speaker.
Sep 29, 2012 | xMini X-Mini II Portable Capsule Speaker -...
Download from lg800g to computer
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging.
Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected).
The connector will be labeled at the micro usb end.
When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
Dec 13, 2011 | LG Cell Phones
I don't know how to connect a printer (HP 970 Deskjet Cse) to my lap-top HP Pavilion dv7
Go to the website below, select your OS, and download the drivers. Than install the drivers and follow the instruction. It will ask you to plug the printer via usb at some point.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=60097
May 03, 2011 | HP Pavilion dv7-1132nr Notebook PC
Dont know how to add music to my phillips go gear
plug the usb into the computer, wait for it to install... go to my computer , then click on your mp3 player icon.. then drag music into that window....or if its not reading your mp3 go to the phillips website and get the drivers from there.
Nov 12, 2009 | Philips Audio Players & Recorders
I can't get my computer to recognize my Garmin 255w on USB cable.
Change the mini usb cable. Some mini usb cable are for charging and not data. It happen to me and used the externo hard drive usb mini cable and zapppppp my computer nows read the gps and gave it a drive (h:\). hope it works for you.
Jul 15, 2009 | Garmin nuvi 255W GPS Receiver
Phillips go gear stuck on Repaired all contents cleared!!!
i held the volume+ button in while i plugged the usb cable. the computer recognized new hardware was found. i opened the phillips device manager and hit the repair tab. it automatically ran a repair through the mp3. then i installed new firmware through the phillips device manager. i lost all my contents but windows media 11 sync all my music back. THANKS ANYWAY!!!!
Jun 27, 2008 | Philips GoGear SA178 MP3 Player
Usb problem
You shouldn't need the USB driver 2.0 from mercury because windows installs this with SP2. Suggest you un-install what you installed from mercury & update your version of windows (completley), through "Windows Update". Once windows is all updated & you have finished with a reboot. Plug your pen drive in a opened usb port. Open windows explorer. Scroll down & you should see an icon (left side of explorer), thats named like, Removable Disk. Give windows time to see the device. After a few minutes if your pen device does not show up try another usb port. One you know does work. If after a couple of minutes go by & you still don't see the device listed in explorer I would say the device is defective. Your Mp4 uses a cable to connect to the usb. Try connecting to another PC's usb port. It is possible the cable is dirty or bad.
Jan 13, 2008 | Mercury P4VM800M7 Motherboard
Philips SA3025/37 Flash MP3 Player Logo
115 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
