Question about Haier HDY6-1 Electric Dryer
When dryer finishes it just keeps on beeping - Haier HDY6-1 Electric Dryer
  • 314 Answers
Instructions
Open the door to the dryer and remove the screws in the hinge. Lay a towel on top of the dryer. Place the dryer door on the towel with the inside facing up.
Remove the screws from the inside of the dryer door. Disassemble the dryer door carefully, removing the cover on the right side of the innermost section of the door and the shield and hinge from the left side of the innermost section. Reattach the side cover to the left side of the innermost part of the door. Install the new shield to the right side of the door section, with the flat side against the door and the notches facing up (they will face into the dryer). Attach the hinge on the same side as the shield.
Set the top section aside. Rotate the remainder of the door 180 degrees so that the handle is on the left of the upside down door. Check that the latch aligns with the cover before screwing the door back together. Screw the hinge into the corresponding holes on the left side of the dryer door frame. Remove any stickers that might be blocking the holes.
Check the alignment of the door by opening and closing it several times. Loosen the screws on the hinge and nudge the door slightly until the fit is correct. Tighten the screws into place.
Posted on Jan 10, 2013
End of cycle keeps beeping even after clothes are finished and removed
this could range from a simple processor hanging problem to a defective pcb
please start from a hard reset by leaving the unit plugged off from wall power for one night
Jul 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire electric dryer (FEQ1442CES) keep flashing and beeping even after cleaning lint filter.
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, keeps beeping and flashing lights. I also see that you have cleaned all the lint out and your appliance will not run more than about 10 seconds. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the lights to flash and the beeping, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer beeps during dry cycle
if the dryer is beeping on it's own most likely you have a bad board part WP8563974
Oct 28, 2017 | Whirlpool Cabrio WED6400SW Electric Dryer
How do you turn off the beaping on a Haier Clothes Dryer?
The responses here miss the issue: The beeps described by the Poster are NORMAL and signal a finished load. However, the beeps are very loud, persistent, and extremely annoying, therefore the Poster wants to DISABLE the beeps. The question is how to disable the annoying beeps.
Jul 09, 2012 | Haier Dryers
MY ELECTRIC AMANA DRYER HAS 3 SETTINGS .ON THE LOW HEAT IT WILL TURN ON BUT DOSENT GET HOT . ONT THE OTHER TWO SETTINGS IT JUST BEEPS AND WONT START.REPLACED THE HEATING ELEMENT AND THERMAL FUSE BUT STILL...
I would keep my patience and use the warm settings and use the cloths airer to finish the dry ing.
sorry for my late answer but I have not been feeling wellfor the past months-OK now or almost.
good luck
Kolbrun
Nov 22, 2011 | Amana NED7200TW Electric Dryer
Maytag Neptune dryer beeps a lot and does not run.
what is the model number,sounds like you have a bad computer board but the problem is alot of parts for the neptune are no longer available
Sep 16, 2017 | Maytag Dryers
Dryer keeps beeping
the beeping is an indication of a problem with the drier, you are going to need a reapir person to look at it, until the problem is fixed the beep will continue.
Aug 26, 2009 | Kenmore 67082 Electric Dryer
I have a FEQB4000FSO dryer that continually beeps, running or finished. The lights flash and I can't reset it...HELP! it makes me crazy!
first see where the beeping is coming from you might have a load finish alert setting on your dryer as in when it finishes the cycle it beeps but the contacts might have gotten stuck together so they are making the noise always try first unplugging the dryer for couple seconds than if that doesnt help  get the wiring schametics its usually on the inside bottom pannel your panel should have two or three screws on bottom of the bottom panel and check on the wiring schametics if you have the buzzer (probably name used in the schametics) if yes than try to see where it is so you can just disconnect it
but easiest thing to do is just unplugg it and plug it back in after 30 seconds
Jun 07, 2009 | Frigidaire FEQ1442ES Electric Dryer
Haier HDY6-1 Electric Dryer Logo
117 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Haier Dryer Expert? Answer questions, earn points and help others
